Joined
Last visited
Currently
Viewing Topic: Who wants a plastic fan?
Newbie, which lift pump??
Yeah I got caught in the same boat... But I went with the AirDog 150 because the price was nearly the same for 100 series so I ponied up the extra few bucks and went big... http://forum.mopar1973man.com/picture.php?albumid=3&pictureid=5 So you got a pre-filter protecting the pump. Then you got a 2 micron filter protecting the VP44. More than enough fuel to feed a hungry VP44. Compared to the stock pump at 25 GPH... :eek: http://forum.mopar1973man.com/picture.php?albumid=3&pictureid=6 Here is the FASS compared to the AirDog (smaller of the two). http://forum.mopar1973man.com/picture.php?albumid=3&pictureid=12 http://forum.mopar1973man.com/picture.php?albumid=3&pictureid=13
What kind of vehicle(s) do you own?
Hmmm... I might have to add a few forum entries for some of you guys to include the ford and chevy's as well as a ricer area maybe? :confused:
The Official "Joke of the Day" Thread
Why your at it FAX me a cup I could use it...
Where's Einstien when you need him?
As for high mountain there is a peak up here at 9,900 Feet but I'm sure USFS wouldn't like the idea of a Cummins laying out in the woods... Worst part is it would most likely survive the fall and come back to haunt you! Valid idea... I just talked to a guy on the phone with fuel pressure falling to 0 but on a 5 gallon fuel can it runs fine... Is the stock pick up all plugged up?
Fuel leak
Lift pumps normally don't leak out the bottom. Unless the contector seals are shot... (Possible)
Come on gang...
I got to see pics of this!
Speed vs. MPG
Very good! :thumbsup:
Lost power steering and brakes
Interesting write up on that link! :thumbsup:
Ok how old are you???
I'm right behind you... :eek: Let me loose from the site, jobs, and other responsibility and you'll find a 39 year old guy raising more hell that most can't handle... :stir::6shooter:
Come on gang...
LOL! big??? This is small compare to some of the big boy sites like Cummins Forum, Diesel Bombers, etc...
Duh... Maybe I should vote too... 1. 2002 Dodge Cummins2. 1996 Dodge Ram 1500 - Gasser3. 1978 Dodge Magnum XE4. 1977 Dodge Jamboree Motorhome5. 1973 Dodge Charger SE6. 1951 Willys Jeep (Chevy 350)
5w40 full synthetic vs 15w40 dino
Dorkweed is the Supertech guru with engine oil... Give him a shout... But as far as what I've seen him post about Supertech oils he's been doing really well with his oil test...
What kind of vehicle(s) do you own? :confused: It's muliple choice on this poll...
Software Updates
Here is links to service packs for Win vista x64... Both are stand alone updates... SP1... http://www.microsoft.com/downloads/details.aspx?FamilyId=874A414B-32B2-41CC-BD8B-D71EDA5EC07C&displaylang=en SP2... http://www.microsoft.com/downloads/details.aspx?FamilyID=656c9d4a-55ec-4972-a0d7-b1a6fedf51a7&displaylang=en
With age comes wisdom... (Wise enough to know how to build up a truck without breaking it!)
OMG! Good morning... glad to see you on the cutting edge this morning...:eek:
Does a 12V really need 2-stroke?
I think the part about white smoke being gone is the fact that most all winterized fuel have extremely high cetane to aid in starting but not really needed after the engine is running so with the 2 cycle oil its pulling the cetane level back down a bit and reducing the white smoke effect. I got simular results too...
high speed miss
Should be fine... :thumbsup:
Unusual Charging problems
Well I did like I would to the house batteries... I setup a battery charger at 10 Amp charge rate and left it till the amp fell low and the electrolyte was bubbling. (15.5 volt) Then switch to 2 Amp charge rate and left it for the night. (14.5 volt). Fired up this morning not a problem... Good voltage and charge rate. all day long the voltage hung at 14.3 Volts on the SG II and slightly over the 14 mark on the stock gauge. lets see how the batteries hold over night...:rolleyes2:
BHAF filters...
For Information purpose... http://www.vulcanperformance.com/SearchResults.asp?Search=bhaf This is the best deal I've seen on the web...
CP3 Failure
I would say its on the supply line to the lift pump has a air leak. Being its all suction line from the lift pump back to the tank it really easy to over look a air leak because it NEVER leaks outward... So to verify this pressurize the fuel tank with about 1-2 PSI most and look for wet spots in the fuel lines...
Quadzilla Milage Max
Suggestion... "Keep your boost below 5 PSI and Pyrometer below 600*F" this will net you the most MPG's. More boost mean less timing given at the VP44 because as boost pressure rises the auto-ignition point of the fuel lower making it early. Then also with more boost means more fuel being added so... More boost mean retarded timing and extra fuel being burnt. Pyrometer just verifies this... More pyrometer temp the more fuel burnt...
Well then I guess you pump is shot... Double check the vacuum pump shaft is turning after you pull the pump.
A Dirty Word... Oil
Frantz Filter http://forum.mopar1973man.com/picture.php?albumid=3&pictureid=222 http://forum.mopar1973man.com/picture.php?albumid=3&pictureid=221 http://forum.mopar1973man.com/picture.php?albumid=3&pictureid=220
New Batteries
I'm in the same boat but... Alias my stock batteries from 2002 finally giving up...
