P1694 and P1698, Diag help
Cluster codes are not p codes... Then the codes range from 900 to 999.. Only 3 digits. So if there is no 900 to 999 codes then I'm stay in on the CCD network being the issue. You got to figure out what is messing with the line voltage if nothing can be found you might have to send the ECM and PCM for testing.
Did you test the cluster? Hold the trip pin down and turn the key on. It should say Chek then release. The test will running at the end report error codes in the odometer.
"The Beast" Broke The High Mark 28.04 MPG On The Quadzilla!
If I remember right it's 137 liters to fill our trucks.
No. Tricks or short cuts. Just filled with fuel, drove the distance and filled again. I need to restock on 2 cycle oil again. I really think the 3.69:1 final ratio helps a bunch just like what I did on Thor getting back to 3.73 final ratio. Both trucks run right at ~2,000 RPM at 65 MPH. Way less energy to keep moving, easier on the engine being in the torque curve and not too low in RPM.
"The Beast" Broke The High Mark 28.04 MPG On The Quadzilla! Notify - @Quadzilla Power Yup! The old high mark was 27.2 MPG with +75 HP injectors (Vulcan Performance) and Edge Comp. Now I did it with a Quadzilla, +150 HP DAP Injectors, HX35/40 Hybrid Turbo. Netting 28.04 MPG hand math, fill to fill! So I filled up in Riggins, ID and then drove to Donnelly, ID to get my paycheck for my last 2 weeks of work. Now returned home which included sitting in construction in McCall for about 15 minutes idling with A/C running. Next morning I got up and drove to Lewiston Idaho. When I got to Lewsiton, ID I was shocked to look down at just below 7/8 of tank and 236 miles. After I was done shopping I racked up 263 miles and I filled up again at 3.509 a gallon which is cheap compared to 4.209 up here at home. With fuel at $4 plus a gallon at home this truck is going to be my eco-friendly diesel truck. All I did was drive normally light acceleration, CANBus fuel only no wire tap used, and set the cruise for speed limit. Nothing fancy. Fuel gauge when I hit Lewiston, ID Then the Trip in miles and my odometer is on the mark... It is calibrated for my 245's tires. Then the data in my fuel log...
Noticed Deteriorated Rubber Vac Line While Installing Injectors What Is It For?
Cruise control, exhaust brake (optional), HVAC controls. Keep in mind the later 2nd Gens are fly by wire for cruise control on a manual.
*Do Not Buy from CPP Diesel*
Give me a little bit longer I'll have the database tested and setup for everyone to fill in vendors and give reviews for others.
I've been getting some work done on the vendor listing. I'm building the database frame that gives structure to the database. I'm trying to include all the methods of contacting a vendor or getting products from a vendor. Then also include a comment area so you can give honest reviews of vendor performance and products.
Brake Light Switch..."DO NOT REINTSALL"
That tin foil between the VP44 and the block will do nothing. What does do something to keep fuel temp down is NOT pumping fuel from the sender basket. That is the hottest fuel and will soak the VP44 with even more heat. I pump fuel from the tank directly and return to the basket the fuel temps are roughly 20 to 25 degrees cooler this way. Even hauling my RV all the way to Arizona I never got over 140*F.
Replacing head gasket
They could be... I've done several truck where your just changing injectors and having problems getting started because of weak starter, bad starter cables (positive or negative), bad starter brushes, bad starter solenoid contacts, etc. Speed is key to re-priming the system with the starter alone. Yes I'll admit I've had to dust the mouth of the turbo with a bit of starting fluid to get the truck started. Must of been another member I just read about compression being low so that is my mistake...
Sled pulling
Failing sensor would of tossed a error code for sure if it out of range. ECT if the sensor is unplugged then the volts go high and gauge pegs out 240F. If its shorted to ground it will drop to -40*F. The only way to have number in the middle random if of the sensor failed IN SPEC. In other words showing random data all over the map but never going out of range. This could also be a bad ECM and/or Quadzilla.
My first explosive tire failure!
I'm not on the overloads yet. Again I'll get it scale here some day and find out.
Help; narrowing down on upgrades.
I've several guys around me with twins on the 24v Cummins. It just rather foolish for the ones I've seen. Like I know of one truck with RV275 Injectors with twins. Then there is a second truck like mine with 150 HP injectors and twins again. I still have lower EGT's at cruise either towing or empty. Neither of these have a Quadzilla those two truck are running Edge Juice. There is no timing adjustment... I typically cruise at 550*F EGT's at 65 MPH. I would consider twins if my truck was towing more often and long haul going cross country.
Suggestions for injectors, turbo, head gasket.
I would talk to the coating company and be sure it can with stand temperatures above 1,200*F and for long term. Not that you would drive that hard but make sure it can withstand way more temperature for long periods of time.
Well I can give this much my last fill up I netted 17.58 MPG on my 2002 Dodge (The Beast). I've got the +150 Injectors but running a Quadzilla tuner. The key here is getting the optimal timing for you use. Like myself since I'm running 245's for tires my RPMs are up and the cruise for 65 MPH is right close to 2k RPMs. Now the next trick is to find the best cruise timing for your application. Good starting point would be 19 degrees at 2k RPMs. But this truck sits mostly and doesn't get driven but on the weekends. This last tank included hauling firewood out of the national forest. This is out side the 24V realm but... Just the changing of the 18 inch wheels off my 2006 Dodge and going back to stock steel wheels with 265/70 R17 tires gave nearly a full 4 MPG. Don't forget about rolling resistance and rotational mass. In this case dropping the extra mass and getting the final gearing close to 3.73 is very optimal for all Cummins.
Few random questions..
You don't have too... If you have the valve spring compressor. What you do is run 1 and 6 up to TDC since they are running mates. Now the piston at TDC. You can compress the spring pull the clips out and change the valve seals on 1 and 6 without pulling the head. Then you run 2 and 5 up to TDC and repeat. Then 3 and 4 and repeat. The valves will sit on the top of the piston and not fall out. I've got the tool in my tool box and never got to use it yet.
I'll make you think a second I've never had to rebuild my own hydrobooster yet. 432k miles and still going. The biggest thing is keeping the power steering fluid changed every 30k miles. If you keep up on the fluid changes then you'll never have to rebuild the hydrobooster.
I remember back a few years I did a intake gasket replacement. I tried for quite awhile to get it to fire up and it was pumping fuel out of 1, 3, and 4. No dice on starting. I disconnected the grid heater at the battery and gave it a small shot of starting fluid and it fired right up. They are right if the starter is tired and not cranking fast enough it will struggle to fire up with air in the lines.
Help with testing an Edge Comp Box or the wiring diagram for the harness
Let me dig my old Edge Comp out I've still got mine in the shop somewhere and I'll dig it up and give you pins and wire colors and going to what. Mine is a 2002 edition of the Edge Comp so it might vary a bit.
Nationwide Weather
Here is the local global warming... So smokey that you can't see the mountain range towards home. Home is 20 miles ot the north of this picture and north is in the direction I shot the photo.
I need to hit the scales now with all the tools. I remember just the truck and flat bed was 10,200 pounds but that was years ago. I don't think so on the springs. I'll check when I get home.
Nationwide Weather
Normally the 100F to 110F weather starts in August up here but this year it started in July. Yes its normal for 100 to 110 in August and been seeing the same weather for years. We are already talking about a wet/snowy winter. Some of the locals are good at reading animal patterns and even insects. Like today it started at 57F here this morning and the rose to 97F now. No biggy... This morning when I ran to work in Donnelly ID it was mere 40F from New Meadows up into McCall and there was wispy fog in the valleys. In the past when I was running on the local fires and working wildland I remember times of sitting in a water tender without A/C and it being 100F to 110F. I even remember looking at the old school thermometer at Chevron back when I worked there for a summer and seen 117F.
Be aware there is China made Cummins heads running around out there and poor quality.
So the over head was 20.3 MPG, after filling up today it... 517 miles / 30.084 Gallons = 17.19 MPG This is way better than last week with the old tires. 420 miles / 30.505 Gallons = 13.77 MPG Stock sized tires and stock steel wheels are a winner in my book since I ditch the Fuel 18 inch wheels. Hankook AT2 265/70 R17 - $985 dollars worth of tires.
Somewhere back a page or two the author mentions that compression was like 320 PSI IIRC...
