  1. Kind of like now I've got a air leak in the fuel system of the Beast (2002 Dodge). I can just bump the starter and re-prime the entire system using just the AirDog. Like shown above the mechanical pump would leave me stuck going through that entire re-prime process. One reason I don't really like the mechanical systems UNLESS now you do the extra plumbing to add the stock lift pump back for priming pump then add in the check valves so the stock lift pump can prime and then be bypassed after the mechanical pump is primed. I know I've got to replace the crossover tube o-rings and injector o-rings.
  2. Yeah the fan is loud when it does lock up the fan clutch. Just started this about two or three days ago. I noticed it on my way to Donnelly ID and it was up quite a bit and dismissed it. Now seeing the second time and not hearing the fan locking up I knew what my problem is. When I first got it running the old thermostat was sticking a bit and would trip the fan off and on. After changing the thermostat it settled down and didn't use the fan but to climb Goose Creek grade. Typically hit the top of the grade it would unlock shortly after. Hey @AH64ID is there any turbo options for this 2006 with the wastegate solenoid? I'm pretty sure you can spit out the wheel sizes to this stock turbo. It makes a good solid 30 to 35 PSI depending on what the ECM does for that wastegate solenoid. Eventually I would like to step up and get something that flows a bit better (exhaust) than this turbo gets hot for just having +50 HP injectors. It almost another 200*F hotter than my 2002 at 65 MPH. I know the stock timing is pretty retarded too which is no help for EGT's.
  3. Anything is possible but right now you proved the Quadzilla has internal issues with the boost fooler side. But yes double check the electric the best you can.
  4. I've seen a 1st Gen truck run over 8 hours with no other accessories running. Yup if the batteries are junk the time is going to be pretty short. If you got good strong batteries you could go for hours. Like Beast (2002 Dodge) I've got all LEDs lighting in the truck and reduced my electrical loads by a bunch. Each bulb is like barely 500mA. Just a feel... Here is the front marker lights I'm using...
  5. I've ran my AirDog 150 over 250k miles (17 years) before the pump motor failed (bearing failure). I've got a AirDog 165 GPH pump now its a 4th gen pump from AirDog and zero issues.
  6. Add another to this list I just remember on my second cup of coffee. I need to go get a new fan clutch. I went to Lewiston to restock on my days off and never the less Thor is overheating now. I made the climb up about half way on Whitebird Grade which is 7 miles of 7% grade for the first half about 6% on the last half up. By the time I was about 2 miles from the top I back down to about 40 to 45 MPH and in 5th direct and the temp just held steady at about 230*F. Broke over the top and the temp fell off. No fan heard. No codes for fan clutch either. Then got down to Lewiston ID (about 750 above sea level). Then made the climb back up Winchester Grade again 7% grade. This time I barely made it to the top and the CHECK GAGES came on as I pulled off. (Hit the 240*F mark). Let it cool down for about 15 minutes then packed up and headed home. Same with heading back over Whitebird grade again barely made the top and below 230*F or so. Already changed the thermostat about a month ago. 190*F NAPA. I know its not the thermostat and no you don't here the fan kick on any more. Monday morning I need to call and get a fan clutch order and installed. Keep in mind the dry weight without the tools and tool boxes is 9,200 pounds. I'm closer to 10,000 pounds now. Thor is not a light by no means with a heavy steel flat bed, Two 8 foot tool boxes, and lot of steel tools on board.
  7. Yes. Secret. When the battery voltage goes from 12.00 to 11.99 the voltage will drop to 8 and chime the CHECK GAGES light. In my truck the cigarette light is gone and I installed a dual USB port with volt gauge. It also shows the actual running voltage. No codes will be thrown till the batter voltage drops to near 10 volts then a low charging volt code will be thrown. After 8 volts the engine will die. None of the computers will function below 8 volts. I've got a 5A fuse on the blue wire. I've had the fuse work its way out and stop charging. Simply just squeezed the contacts slightly and re-install the fuse. Still in all the volt gauge will not be pointing at 14 any longer as soon as the fuse blows or in my case fell out. I've also got a 150A circuit breaker on the charge wire to the passenger battery. I've NEVER had that circuit breaker trip once yet. I've physically press the trip button and again the battery voltage drops from 14 (13.5 to 14.5 normally) to about 12 volts and continues to decline till either the circuit breaker is rest or the problem located. 431k miles and still rolling. The W-T ground wire mod and my PCM protection fuse has been working flawless for the last 2 to 3 years with no real issues.
  8. Just showing me how old I am? Eh.... But thanks for the HF light and mag...
  9. Get a hold of me I've got a one wire kill that it will not start. Then if you have the Quadzilla and level it on level 1 (Valet mode) and then set valet mode for like 10% it will still drive but barely. Its top speed is 20 MPH on my truck. Even another member here had a Quadzilla and they stole his truck and abandon the truck because of lack of speed. (Valet mode). I just had Eileen's car broken into just a short time ago. We figured since her car has an alarm it safe. NOPE! They broke out the window and stole my camera out of the back seat and the alarm NEVER went off.
  10. OBDLink or similar. I've got only my Innova ODBII tool right now and it does live data well. https://www.amazon.com/OBDLink-Bluetooth-Professional-Grade-Diagnostic-Performance/dp/B07JFRFJG6/
  11. If you going camping and need air conditioning your going the wrong spot. I just had this conversation with friends. Like my last camping trip was OK. No hook ups at all. It got into the high 90's for temperature. We went out on a jet boat and went fishing for most of the day. I'm still OK to camp in that and don't require A/C. Still in all I'm looking to get above 5,000 feet elevation to get away from the heat. Being I'm working at 5,000 feet now for my job which isn't too bad. Then I reverse in the winter time head lower into the canyon to get to something a bit warmer. You sure wouldn't want to go to Death Valley in the middle of the summer to go camping just not a smart thing being it does get over 120*F down there. Might be super enjoyable going there in the early spring when weather is cooler. As summer get on around here we all just keep moving up in elevation to beat the heat. I've only been in a handful RV parks with full hook ups which is nice but not what I want. I don't want a neighbor so close I can reach out my window on knock on there trailer. Even at home I've got hundreds of feet between me and my neighbor. When I go camping I don't want neighbors. I don't want other people wandering through our camp spot. Most of my camping is dry camping without hook ups and without A/C. Even my last trip was out at Pittsburg Landing on the Snake River. The camping spots are spread out, but yeah everyone fired up generators and listen to all those engine humming away. Myself I closed the blinds and slowed down and go lazy for the day watching TV. The interior temp got to a mere 82*F bit warm but doable. I had a partial shade on the trailer through the day which helped. Rest of my power I just kept moving solar panels and pointing them at the sun. Thankfully I did NOT mount my solar panels to the roof being the roof was shaded by a tree. I do have a small 2kw generator I've packed on a few trips. Its a knock off generator that is super light and fair good with fuel consumption. Last year I had both of Eileen's grandkids out camping and took the generator being I wasn't sure how much solar power or sun I might get tuck in the trees. I brought a 100 foot cord and hauled the generator out as far as all my cord would give. I burned up over 5 gallons of fuel in just a few days. I do have a 4kw generator that will power the A/C but that thing is a beast of generator very heavy and it drink gasoline like a bar drunk. It will power my A/c no problem, water heater no problem, even the microwave, even all the above together on that 4kw. Now are you going camping to get away from it all? Me??? Absolutely!!! I'm will to give up the need for A/C. I'm will to give up the need for my cellphone and internet. Truthfully I welcome the idea being somewhere my phone doesn't work then I can turn it OFF!!! Could I go sit in a creek and play in the water? Absolutely. Could I take off on a ATV and go to a mountain lake and go fishing? Sure! How about grabbing a innertube and floating a river? More ways to cool off and enjoy your trip without the need for A/C.
  12. Unhook the Quadzilla and watch the MAP sensor with a live data tool and see if it drops. If not then the Quadzilla has a problem with the boost fooler or boost circuit. If it continues after removing the Quadzilla then you have ECM to MAP sensor issue.
  13. I never thought this day would come admitting my vision sucks and cant't do like I did when I was 30 years old ans soldering like a crazy man. Just need a magnifying light and steady hands. Yeah I guess I could pull that cluster out and reflow most of the board if I order a good solder gun like the last one. It was electronic temp controlled.
  14. Yeah if I had a soldering gun. Strange enough I bought one awhile back and was going to try soldering the high idle kits but being I'm past 50 years old and my vision sucks. I gave it to @Me78569 when his gun burned up to keep him producing high idle switches. I still need to get a heavy duty soldering gun.
  15. No problem. The only thing the 02 had a small problem with is hard starts while nose up. Yup good old crossover tube o-rings and injector o-rings. This was from the fact of the head got cleaned up and both the injectors just dropped in and the crossover tubes had zero resistance I'm sure one or both o-rings are weeping.
  16. Thanks! That is what I was looking for... Well I guess I'll be calling Module Master in Moscow, ID and have them rework my cluster.
  17. My suggestion, don't drill for sump. So far I know of two people that have drilled for the sump and ended up hunting bone yards for a new fuel tank. Best not to drill or add any sump. I've been using a draw straw (outside the basket) for years. Just remember once you make a mistake of drilling or cutting into your fuel tank bottom there is no fixing after that!
  18. Stops the short circuit from burning up the PCM. 5A is quicker to shut down the short. 7.5A will still work but blows later. Basically in a nutshell the blue wire on the alternator is a tach signal controlled +12V power source. When the alternator field is shorted out on the blue side it will pull the max current which is 20A till the circuit tracer inside the PCM burns up. Which my PCM did so well that it was declared junk because it burned not only the tracers but the fibergalss board too. With no way to repair. This is why I opted for 5A fuse so if the short occurs then the fuse blow out super quick and no damage comes to the PCM. This is where the external regulator stems from because once the trace burns the alternator stops charging. So most installed external regulators. Now the problem is that all the external regulators from Mopar were temperature sensitive since 1962 or 1963 or so. As the under hood temperature would change the charging rate of the alternator would too. Common mistakes is trying the external regulator and either mounting it in a spot to hot (like near the turbo of exhaust) this will make it undercharge. Then I've seen a few mount in too cool of a place and now it overcharges and boils the batteries out. So the whole PCM protection fuse is to prevent damage from short circuit on the blue wire. NOTE: If the green wire was to short to ground it would charge at max rate. No damage comes to the PCM at all. Only the blue wire will do damage.
  19. Yes. Absolutely correct. Actually I'm running about 20 to 21 degrees at 2k RPM. I've ran as high as 23 degrees. Now as for gearing I'm 3.55 in both axles and running 245/75 R16 tires which brings the final ratio to 3.69:1 to the ground. Then my injectors are popped at 320 bar which makes them late so I must run higher timing in a cruise state to make up for the late injection event. The net result is better MPG and power. Fuel map wise on the Quadzilla I choose from 0 to 5 a defuel zone for launching. Then 5 to 15 PSI the fuel map is stock 100%. Now from 15 to 30+ fuel map both the wire tap and the CANBus ramp up together making some serious power up from there.
  20. Here what I mean on the tach. 65 mph. Then idling at lunch time with a/c on.
  21. Personally I'd love to put a 5 speed in my 2006. Even with 3.73 gear you need to row 5 gears (1:1 direct) to get 25 MPH. I might change my mind after towing a trailer but lot of hand shaking in a town with 25 mph speed limit. Ugh.
  22. It's true. Hx35/40 hybrid turbo (60/60/12) and +150HP DAP injectors (7 x 0.010) popped at 320 bar. Then the Quadzilla no issues it runs strong and smoke free. I do get a puff but clears up super fast.
  23. 2002 I finally had a driver side door lock fail me. I pull all the locks (passenger and driver) then the ignition lock and took them to George's Lock and Key in Lewiston ID and had them gone through. I've got the locks back in the truck and the linkage in the door was getting stiff from all the years. I power washed the inside of the doors and the latch assemble and lubed it up really well with silicone spray. Now I'm just waiting for a bit of extra funds I'm going to buy a new set of speakers for the front doors and a bag of door panel fasteners. Reassemble for the last time. I've pulled the panels off for window motor (passenger side), then added towing mirrors (Both sides came off), now the door lock issue with both sides off. I just want to put it back together for good. Still fun to drive but not comfortable resting you arm on hot sheet metal. As for the lock on the driver side somehow one of the wafers in the driver side lock got bent. It bent the holder just enough that even a new wafer didn't work so it was omitted from the drivers side lock and now it functions just fine. I've got a new fuel tank sender entire unit from DAP. I've got to find some time to pull the tank and install the new sender. I know its not fun but not hard either. I started gather up the filters for both trucks and getting a bit of free time to change fluids in both.
