Head Leak
Just set it for level zero. Then watch the timing value you can build a tune to mimic stock timing. Also level zero is stock (Quadzilla is disabled).
Hello from Oklahoma
Double check the tone ring and be sure it's lined up with the sensor. Ive seen one member here that lost a carrier bearing and it shifted over to one side and was misaligned so no speed.
Head Leak
If they where studs then yes. Head bolts will just stretch more. This why you have to measure the total bolt length to verify if they can be used again. Biggest thing is make sure to use the limits on the iQuad. Warmup mode (at least 140F), boost limit (based on your turbo stock should be limited to 35 PSI), EGT limits (1200F suggested), etc. My mistake was reaching to far up in power with limits to high... EGT limit was set for 1400, no boost limit, warm up was set for 140. Basically from talking I built up too much drive pressure and lifted the head. Then coupled with high timing yup I blew the head gasket. Live and learn from my mistakes.
2015 Dodge Grand Caravan 3.6 P0306 Code 115K miles
Torque wrench is very much required. Like Dodge 5.9L V8 Magnum engines are very low torque numbers.
2012 Range Rover...... not foreign to me but a right POS
Just consider every jet flying in the ski produces more CO2 than any diesel vehicle. Heck a good forest fire creates more CO2 in one hour than my diesel truck will in its life time. Just DemonRats throwing global warming at all of us.
On my 1996 it was a intake manifold gasket was sucked out of place and created a lean issue on number 6 which change sparks plugs, even the fuel injector. But ultimately the intake gasket was the issue. After replacement I've not had any issues again.
Head Leak
First one was head curl after 350k miles. This next one we would say excessive timing, excessive drive pressure, and a heavy foot. Made 50 PSI of boost and died. Blew all the fuel rails out. Had to reprime the VP44 to get it started.
Turbo Help
If you need quicker turbo spool up start the timing at 13 degrees it will spool faster.
front ball joint time
All I've got is cheap AC Delco ball joints. Still going...
Need help with tune or injectors
Make a boost test cap. I can hook an air hose to it and turn up the pressure on the regulator and then listen for air leaks. You can mix up some soap water and spray all the air system.
Hello from Oklahoma
Yup. Your in the right place. Just get your threads started on different projects we will help you out. On the speedometer issue do you have an ABS and BRAKE lights on? Fix the speed sensors first. The is one in the rear differential that provides speed info. You might have front sensor issues too. Any CCD Bus issues? No Bus shown in the odometer then it a bus issue preventing the cluster from see the info.
What size generator to get?
Even my 2002 truck at 82 MPH is 2500 RPM. Then at 66 MPH is 2000 RPM. Also 3.55 gears with 30 inch tires (245/75 R16).
Turbo Help
Go to be added. I've got a China made boost controller for the wastegate. I know @IBMobile is using the same as me. The old school boost controller is a brass elbow with a set screw for adjusting how much pressure makes it to the wastegate.
Turbo Help
Sounds like this might be a weak wastegate motor spring or no boost elbow. There was a post about guys ditching the wastegate motor all together and just using a spring to hold the wastegate shut. If done right using a bolt with an eyelet and the right amount of spring tension you can control the boost pressure on that turbo by tightening or lossening the spring tension. The drive pressure will build enough to naturally push the wastegate open.
Daniel Stern Lighting Sport Headlight Harness
Here is the stock wiring... Standard headlights... Sport Headlights... Now I'm going to remember the method I did my sport headlights... I've got to draw out the schematic. Take notice the bulbs are hooked to +12V to the common contact of the bulb and both hi and lo beams are ground wires. Please don't judge the artwork but that should be what I did years ago for my setup I managed to eliminate 2 relays and have 12V power to the bulbs on both hi and lo beams. DOTS are connections. I tried to ARC OVER other lines. As for stock 2 bulb system the stock head buckets are well junk and haze over and scatter light badly. As you can see I added 100w aircraft landing lights for booster to the crappy stock headlights. That was 45w/65w halogen headlights (Silverstars) and then four 100w aircraft landing lights. As for 4 bulb sport version you'll find the 2nd bulb is just a vertical band of light that does nothing for road lighting. The main bulb is more productive but again only as good as the reflector. I've ran these for barely 6 months and were no better than the factory two bulb set up. Still poor pattern and limited light. Now the Morimoto's... I paid $750 for this set of headlight already assembled and test ready for install. Now these headlight being they are NOT the H1 Mini's that most every gets I got the larger lens that cast way more light. These are the D2S lens and they cast at least 50 feet out both sides off the shoulder of the highway of the truck and can see as high as 50 feet vertically on hi beams at a 1/4 mile. No hotspot, no scattered light just even smooth pattern of light. Lo beams are even better being the cut off is flat and never blinding anyone. As for LED bulbs you only going to get a pattern as good as the quality of the headlight bucket. Another issues with LED's you'll be stopping more often in a snow storm to clear your headlights. LED's do not produce enough bulb heat to shed snow or ice on snowy days. You'll see that my PIAAs are brighter than my Morimotos but hotspot in the highway. Morimoto's are only 35W and the PIAAs are 15W. Morimoto D2S (Lo beam) and PIAA 530 LED Driving lights (Notice lo beams you can't see to the corner quite) Morimoto D2S (Hi beam) and PIAA 530 LED Driving lights (Hi beams you can see the corner and trailer in the distance on a side road)
I've done the relay but only used two relay to do the job. Problem is your working with switched grounds and trying to convert to switched positive. The whole relay thing was to hopefully increase power to the bulbs and convert to switch positive. Now give me some time in the morning I'll see if I can draw a wiring schematic of how to do it.
Turbo Help
Heck even back with my Edge Comp and +75 HP injectors on a HX35W turbo I was seeing 35 to 38 PSI.
Empty exported datalog
I made a wooden holder back in the day. Then I changed over to the cellphone and used a floor mounted gooseneck for my phone. Now I'll be switching over to magnet mount for my phone.
Remember everything is backwards. Hi and lo beam legs are negative to ground. The common contact on the bulb is positive. +12V -> Fuse -> Bulb <- Dimmer switch <- Headlight switch <- Ground (drivers side kick panel) Sport headlight won't gain you much. The second bulb is more of a vertical path of light. I didn't even keep mine for a 6 months and went to Morimoto HIDs Headlights. Way better lighting than sport headlights... I do mean way better. I even tried LED bulbs in my 1996 Dodge still in all the Morimotos win with more light with a bigger spread of light without hotspots.
Turbo Help
None here... I've only used a HX35W and HX35/40 Hybrid... Ummm... I'm not very smart about turbos... I know its got a spinny thingy that spins really fast and makes all kinds of weird high pitch noises. Just need a better hamster...
Head Leak
First head gasket was the passenger rear of the head with a coolant leak. Second was in front with a oil leak from around the push rod hole.
Turbo Help
Your going to have to give up that turbo mounted exhaust brake to give more options. Im in the same boat. I need a different turbo but selections that allow that exhaust brake is very small.
Brother's truck, drivers door functions and brake lights dont work
2000 heater blend door actuator
Your blend door is correct just got the pin in the wrong half for the black gear. As for photos you need to be using Google Chrome browser make sure it's the current version. I had a few settings wrong but working now. Google Pagespeed Module converts old school photos from GIF, JPG or PNG to modern formats that compress better like .WEBP which is faster to display and less bandwidth.
WHERE TO DRILL A CC/SB 4WD 2500 2001 FUEL TANK FOR A SUMP? WHAT BRAND?
ECM is at 50% duty cycle reducing the fuel pressure to typically 7 to 10 PSI while cranking which isn't a problem with a mechanical being the starter only rolls over at about 200 RPM. Starting pressure for a mechanical pump would be really low while cranking. No problem there. I've got an old video of cranking pressure and run pressure. You can see the pulsing power to the lift pump with a bouncing fuel pressure. Again since my AirDog is relay controlled I'm not worried about ECM issues. I will admit my location has really helped with gelling issues and debris issues. You can see the skid plate gaurds the filters. Helps a bunch on keeping snow and mud off the pump too.
