  1. South side of Riggins and go up a dead end road for 17 miles. YUP! It's one hell of a drive.
  2. Funny part of this marriage. I had to have the cancer and the ostomy bag to meet Suzanna, my wife. If I'd been a healthy person, I'd never have met her. She enjoys the thought that I dealt with my depression with makeup artistry and cosplay. This helped me deal with the health crisis (bladder cancer and chemo treatments) I was dealing with at the time. I started making up artistry back in 2022 as a fun thing for the weekend. Now it's part of my daily dress code. Suzanna has enjoyed the interactions I get everywhere I go, hence why the photo above shows us both enjoying the makeup work, and will continue to grow together with our own art. The makeup artistry is what captured her eye that day, and why we are together. Being we both went through our own hell, we plan on holding the celebration next year in late spring or early summer. Hopefully, by July 25th 2026, we can be on top of Heaven's Gate, where you have to drive through Seven Devils Mountain to reach this mountain top.
  3. Injectors are back in, and Thor is once again running. I know I still have low compression in at least one cylinder, but Thor is running. Thor now brings more to the table for article building. I've got axle joints to do in the front axle soon. Winter is coming, and limited shelter to work in. Yeah, Mark said the front driver side wheel joint is shot. I'm enjoying Thor even though it smokes as it warms up, but a short ride down the road it smoothes out and runs well for the rest of the day.
  4. Im going to have to show off my setup. Not great but it is what it is.
  5. 4 4-inch exhaust will handle 600 HP easily. Mufflers of most brands of exhaust setups are simple pass-through muffler styles, non-restrictive. I just jumped for the diamond eye 4" exhaust system because the high-priced kits, the pipe might hold up being stainless, but the hardware, hangers, and the clamps are all steel and will fail anyways. (Salt country). Diamond Eye is aluminum coated steel pipe, and mine held up just fine for the pipe, but the clamps failed, and the tail pipe fell out.
  6. Like me, I use a 150-amp circuit breaker, and it can be reset at any time without the need to carry a second fuse in case of failure.
  7. I would have skipped the hotrod pump, being that it's a mechanical change in timing because of the blending HO and SO pump parts together. It's possible to produce more power without a hotrod pump because you don't have to calculate the offset of timing advancement. Kind of like changing pop pressure to lower numbers does the same thing, like pop pressure 300 bar vs 310 bar is about 1 degree advanced. Like me, I changed to 320 bar from 310 bar to retard 1 degree. This 1 degree can be made up in a Quadzilla tuner easily. Advancing timing is going to reduce boost pressure. Retarding timing creates more boost pressure by passing more expanding gases through the turbo. Advance timing consumes most to all the expansion in the cylinder providing little ot nothing for boost. Double-check the block to gear case gasket while you're there, and the VP44 is removed. Cam sensor replacement is super easy, even without pulling the VP44. Tappet cover gasket, just remember not to use any silicone. It was installed as a dry seal! Make sure your cover is not bowed or warped.
  8. Finally got a new radiator for Beast, and it's sitting in the back seat with the radiator cap. Just a matter of getting some good weather and getting the work done. Yeah, without a shop, and the weather is getting cold and wet here.
  9. Ok. DAP got the injectors retested and fixed up. Apparently, I did pass some debris through both the filters or created debris from the CP3 during the fuel filter issue, or both. Injectors are installed and have been working excellently for the last few hundred miles I've put on. I now have an oil leak I must fix fairly quickly, it seems to be on the passenger side, but I've not officially dug into this quite yet because other important things needed to happen, like being married. Yup, Mopar1973Man is now married. As for Thor, I need to look into the oil leak, and I've also found I've got a bad wheel joint on Thor.
  10. Hey Gang, Great News! @Tweety Bird and I just got married yesterday! (November 25th, 2025) We both opted to get the legal stuff done now so we can work as a team. Our full ceremony will be July 2026. I have to say, "We had to go through our 'Hell' to find 'Heaven' together." Our actual ceremony will be at 'Heaven Gate' in the Seven Devils' Mountain Range in July, hopefully the road will be passable by then. Suzanna and I met in a waiting room in the Portico West building in Meridian, Idaho. Suzanna was dealing with a surgical wound that was being stubborn to heal. I was dealing with my ostomy fitting and setup. The magic was that we met once, and I happened to change my appointments to 2 weeks earlier and wound up meeting Suzanna again on my second appointment. This is what we consider our anniversary date (July 25, 2024), which is rather strange, we got married on November 25th of 2025.
  11. Key on engine off Cold start and idling 38°F outside temperature. As you see ive done the low pressure light and hated that it requires more plumbing for 2 sensors. I upgraded to programmable gauge. My warning light comes on at 13 PSI or lower.
  12. Prices on everything is high. Just looking into my fuel pressure sensor. $80 Quadzilla Adrenaline 0 - 100 PSI sensor
  13. Mopar1973Man posted a blog entry in News
    Geez, when it fouls up, it dies well! 🙄 Now that I'm fixing the other parts of the server, I'm running into email problems with other members. Keep your email inbox in good repair and status. If I can no longer reach you by email means, then I have no recourse but to delete your account completely. I'm no longer going to hold on to accounts with broken email addresses. Again, if your email box is flagging our email as spam, I'll be forced to delete your account. I'll attempt to contact you by the listed phone number and/or PM you on the website, hoping to get a corrected email address. I'm no longer going to use my private email address for the website notifications. I've created a new no-reply@mopar1973man.com for all the notifications from the website. This email address will not be checked, nor will anyone respond from this address. If you need to be in contact with me, it should be worked out on the website in the forums or PM, depending on the nature of the issue. Checking email and website messages is just too much to chase, so we are going to keep the majority of the communication in the open forum. This way, if I'm not available because of medical reasons or traveling, then other staff and members can still help out till I return. Make sure to "whitelist" the email address of no-reply@mopar1973man.com this is required to keep communication going between Mopar1973Man.Com and yourself.
  14. Because they have a properitary design for the accuracy of fuel pressure readings. Strangely enough ISSPro sensors will work direcdtly with a Quadzilla display. Just shows why the problems of getting the sensor. Even the ISSPro EV2 pyrometer sensor will exchange on the Quadzilla. Just tidbits...
  15. This is why I installed ISSPro EV2 gauges and properly protected the sensor. Im on the road but there is a article on my fuel pressure sensor setup.
  16. Either the wiper motor park switch is bad. It could be the multi-function switch my 99 Minnie Van has this issue. Ground for the wiper should on the cowl drivers side above like clutch fluid reservoir.
  17. ISSPro EV3 gauges give both functions electronic gauge with Bluetooth ability to reprogram any settings in the gauge. Lights (color), warning color lights, set range of warning, much more. Might take a look at those.
  18. The fuel pressure below 14 PSI is lower return flow while the engine is running. Basically demand of the engine will take more fuel to the engine and less on the return from the VP44 pump. If fuel pressure is not stable then your demand volume is greater than your supply volume. Return volume is what remains after injection cycle occurs. This why is not suggested to below 14 PSI because the overflow valve is closed by 10 PSI and no return flow occurs.
  19. As for today, I got out between rain showers and removed the injectors and boxed them up and shipped them to DAP. (Check back in a week)
  20. Yeah @Tractorman is right. I just caught @Sycostang67 same thing.
  21. Sadly I'm not sure. I would say its time to pull the entire transmission out and check the clutches and bands. How many miles on the transmission? Any error codes or check engine light? When was the last time it was serviced (fluid change and filter)? With the 46RE, 47RE and 48RE are basically the A727 transmission with an upgrade of 4th gear. Now that being said, 1st, 2nd, and 3rd gears are all hydrualic shifts. THe 4th gear is "E"lectric shift. If there is no movement, I would start with pressure testing to see if the pump is producing enough pressure. You might want to stop by the DDownload section grab a service manual. 46RE, 47RE and 48RE 4 gears forward 6,7, or 8 the amount of torque on a scale of 0 to 9 Rear wheel drive Electric 4th gear shift. Here is my transmission book for the 48RE.
  22. Today I managed to get the passenger side shaft out. I ran down to Steve Crump Service Center in Riggins hoping to use his torch to cut the trunion out of the shaft. That way the cap just need to be driven through (inward) to get the caps out. The other part of this trick is the cap has been heated by the torch and the expansion of heat hopefully broke the caps free. Sadly Steve's torch was not working correctly and the cutting part of the torch not getting enough oxygen to cut I think the nozzle was plugged up partially. I got rained out and returned home and inside to stay warm.
  23. Thanks. I need to do the wheel joint super bad right now, the passenger side shaft is starting to wobble in the axle tube. Yeah, super good on the bearings and seals. Yeah, I know, but when you've been living off of 3 figures (small), you can't afford to buy much at times for repairs. Most of this was supposed to be done last year when I was shutting down the shop to the public for the winter, then CANCER for 2023 Christmas, and blew the entire priority list, and all went on hold. Then, toss in the mudslide and no tools for over 4 months, and trying to do even a brake job on the rear axle was super difficult without proper sockets or tools. Most of my funds went ot keeping me alive with food and fuel to make my chemo treatments. Everything stopped for Beast and Thor. I want to focus strictly on the website from here on out. I want to return to what I enjoy doing, even if it's just website work. I'm fine with that. Just yesterday's attempt at getting Thor's injectors out has me hurting pretty good in my lower back and hips. Yeah, I've lost a lot of strength from being laid up, and my ability to work for long hours is over. I cannot do 8 to 10-hour days any longer. 3-4 hours is pushing it. I cheat at times at get friends like Mark Hall to do some of the grunt work, pulling tires and heavy stuff to keep me safe. If I to lean over the front radiator support is hard on me because of my stoma location, and so easy to puncture my ostomy bag, which I did last week. Yeah to start walking around and wonder why your right pant leg is getting wet. Ugh! Being I lost the ATV in the landslide, we opted to keep me in a heated cab of a pickup to plow snow from the driveway. This is why I need to do the wheel joints on Beast because after we get the plow blade hardware, Beast will be used to keep the driveway cleared this winter. I wanted to use Thor, but Thor is going to need an engine rebuild in time since it has one bad cylinder for piston rings. (Ugh!) Yeah, this is so much to do with both trucks this fall, it's insane. Just remember, I lost EVERYTHING in that landslide (tools, supplies, parts, special tools, etc.) Then in the meantime @Tweety Bird and I are still trying to catch a break and get married yet!
