  1. Basically don't let 3 cylinder high idle and Quadzilla 6 cylinder high idle run together. Being the ECM is calling to drop 1, 2, and 3 cylinders. Now the Quadzilla is trying to call for 1,200 on 6 cylinders. Yeah I can see where that can go very wrong.
  2. I'm there. Already got a bit more room with the Hybrid HX35/40. With the 7 x 0.010 injectors, you actually cutting back fuel more than adding it. The bottom end it cut pretty good starting at only 75% of stock fuel. I'm maxed out at 120% over stock. I'm not even using the last 30% of CANBus fuel for my daily tune. After the entire day of driving. I'm very impressed with the 7 x 0.010 injectors. My tune I'm working around to gain the most. Valuable information!!! I can say that you can detect low pop pressure with the Quadzilla. Like my old 7 x 0.0085 idled at 5% to 7% engine load. Then the new 7 x 0.010 @ 320 bar idle at 13%. There is a reason for this. As pop pressure is higher you have to command more fuel to overcome the pop pressure and get the idle to hit 800 RPM. Now with a wore out injector like my 7 x 0.0085 now those are so worn out and pop pressure is below normal range so the ECM commands way less fuel to make it idle at 800 RPM.
  3. Like the 7 x 0.0085 injectors I was set for 140% which was also slightly on the less side. That makes total sense. Being the 7 x 0.010 are exactly double the flow rate of 7 x 0.0085 injectors so the values hold true. Going from 140% for 7 x 0.0085 (+75 HP) to 180% for 7 x 0.010 (+150 HP).
  4. @Dieselfuture thanks for you tidbits. Gotta ask what MPG offset or you using?
  5. Any injection shop should be able to help. Any shop that rebuilds injection pumps like for example Industrial Injection.
  6. I'm currently rebuilding the tune. What I've got is for 7x0.0085 injectors. Now upgraded to 7 x 0.010 injectors.
  7. I've had alternator fail right out of the box. I always bench test before leaving the store.
  8. Kind of shocked at 80 MPH cruise set my EGTs float 650F to 700F. This while twisting 2,400 on the tach. Did awesome.
  9. Umm no... Gotta have my G-Force fix. WOT and feel it push you back in the seat.
  10. AC noise from the alternator most likely. It fouls the ECM and PCM. Look for the WT ground wire mod in the articles. Then have your alternator tested for AC noise.
  11. Cruise set for 65 MPH my average EGTs are about 500*F to 550*F on flat ground. I'm loving that purring lope. Very mild and doesn't last very long. Power wise this is crazy fast passing a semi and another car and look down I'm doing 95 MPH. Idle is very smooth.
  12. When your road and weather conditions are better just borrow a set of 245's for the rear axle and run it for a few days. If the ratio is too just doesn't suit you then there are the 235/85 R16 which is nearly 20 pounds lighter than 265's and just barely 1 mm taller than a 265/75 R16. Ran those for many years. 235's done very well for winter traction more penetration to the road surface than wide tire 265's. Gearing you would understand really well if you rode a bicycle. Like I've got 26-inch wheels and 21 gears on my bicycle. When the gear ratio gets too low in number the amount of stress placed on you and the pedals and cranks is multiplied big time. Now increase the ratio and/or make the wheels smaller reduced the stress considerable where you cranking fairly easy but even able to climb fair grades without a ton of stress on you. After you done this and rode at least 10 miles you start to understand gearing really, really well. It about finding that balance where your power is transferred to the road without making it too easy where you crank and crank and bare go anywhere vs too much and now you're struggling to get it down the road.
  13. No, I won't. There is a reason why I went DOWN in tire size. This prevents a build-up of torque in the driveline and also the smaller tire size breaks loose easier. This prevents damage like input shaft failure. Etc. A smaller tire does not trap torque like your 285's your running will trap much more torque and cause failures. Positive note the 245's are even quicker now with the 150's. only takes me a few seconds from 55 MPH to 90 MPH now. The final gear ratio is 3.69:1 at the wheels. so no stress on my driveline. Now looking at yourself. your heading the wrong direction. Yeah, you changed your 4.10 to 3.55 but with the 3.55 gears now and 285's tires your final ratio is 3.42:1 at the wheels you now starting to trap torque and add stress to your driveline. If your setup with my hardware your wouyld be more of canidate to breaking the input shaft. Just all because of an tire size... Strange but true...
  14. Yeah I'll play with it as well I'm might end up rebuilding my tuner a couple of times trying to get the fuel map the way I like it. Right now it a clean burn from 0 PSI boost to 45 PSI. It's crazy how much power comes on when the wiretap comes on about 10 PSI. You feel the whole truck twist up and the shoot off like a rubber band.
  15. 215k those injectors are done. Unscrews. Normal thread. The average price is about 9 to 15 dollars per injector. This just pressure testing and no adjustment,
  16. How many miles on the truck? Are these stock injectors? You might consider having the injectors pop tested. Then you might do a valve lash make sure the valves are not too tight or too loose. Worn injectors can do some weird things.
  17. A tuner would help you ton right now. You can clean up your current injectors a ton load if you had a way to control fuel and timing. That how I limped on those +75 HP (7 x 0.0085) with low pop pressure. I was able to crank up the timing pretty aggressive to get the fuel to light completely.
  18. https://mopar1973man.com/membermap/ Make sure you are running Google Chrome Browser. M73M is an HTML5 website you must be using an HTML5 compliant browser. Google Chrome is the only browser that meets most of all the needs. https://html5test.com/results/desktop.html My Google Chrome on Ubuntu Linux 18.04.1 LTS
  19. Always best to start small. You still have the HX35 turbo. You'll need to upgrade turbos to get up in bigger injectors. Like myself I'm at the end for this turbo its maxed out. 7 x 0.010 (+150 HP) @ 320 bar HX35/40 (60/60/12) Quadzilla Adrenaline ARP Studs 4 inch exhaust @Marcus2000monster You've got a few things going against you. Stock HX35W (54/60/12) 53 Block No tuner Stock head bolts The farthest I would go without a tuner would be RV275 or +50HP. This will stay fairly clean but MPG won't jump much being there is no timing. The 53 blocks are on the weak side and people have cracked them as well as some members here have run them a long ways. You are in the unknown spot being the mileage is low yet. +90 HP with 315 bar is a fairly safe bet.
  20. I've got to cut fuel back to 75% to keep the launch smoke gone. Now my max CANBus is only 120% instead of the 150%.
  21. Don't install the injectors till you get a Quadzilla.
  22. LOL. I thought at first the pump wasn't working. So damn silent I couldn't tell.
  23. Thanks @Dieselfuture ... I've rebuilt my fuel map so I'm starting at 75% and going only up to 120% max fuel. This will allow for a bit more out the wiretap without getting stupid or smokey. Now I'm going out for a test run and see what I get from it.
  24. Headlight switch, and multi-function switch. All on the ground side of the headlights. Then the wiring is bit on the thin side so I'm going to bet your voltage drop would be worse drawing heavier loads on that thin wiring.
  25. I made a run to town to just play, test drive and get my daily bicycle ride. I need to sit down and rebuild my fuel map. I'm going to cut my CANBus fuel back quite a bit and be able to get the wiretap in without the excessive smoke. I brought my timing back down to 14, 18, 22, 26. Runs like an animal. I've done a few low speed WOT runs. This thing is sick and crazy. Boost jumps to 45 PSI and the torque overwhelms the rear tires. Light bit an of pedaling and you can gain the traction back. I've got to focus on EGT control and fuel map. Now the beast has a purring lope now. I think its rather cool. Just as your slowing down with the clutch in she'll just purr and lope very mildly. Come to stop it idling smooth as glass. I know for sure the 7 x 0.0085 VCO are well below 280 bar for sure. These at 7 x 0.010 @ 320 bar are awesome! Neat trick learned today. If you're doing injector install and you don't want to lose prime. Take a small pair of needle nose vise grips and carefully clamp the supply fuel hose off. This will prevent the fuel from running back to the tank. I did my install. Then hopped in the truck and bumped the starter and then release the vise grips. No injector lines loosen. Now just cranked it was only about 5 seconds and it started. Now with the AirDog 165 4G pump. WOT run I can draw the fuel pressure fair 3-5 PSI drop now. Yeah, I'm flowing fuel and it shows on the fuel pressure gauge. Still holding above 14 PSI at all times. Idling at 19 PSI. As for the bicycle ride. It was windy and cold. I want to play so I managed to get 2.5 mile ride in. I'll make up tomorrow in Ontario, OR with a longer ride. I'll most likely do a long 10 to 12 miles ride again. Gotta tag @dieselautopower he'll want to see this... Tune as of right now... performance tune.xlsx
