  1. Block heater only needed below 0*F (-17*C).
  2. Smoothly? Like when my ABS gave up. The front sensor would show ZERO till 30 MPH and the jump up. This is a tone ring issue in my case. Being I'm going to assume its RWAL (Rear Wheel Anti-Lock). This is the only speed sensor there is.
  3. Some days I wish @Marcus2000monster just would come over the mountain to Idaho and let me look at it.
  4. Smoke color and being light grey is possible that the timing is a bit retarded on the low end. You could try my current tune a bit aggressive... 1500 - 16.0 2000 - 19.7 2500 - 23.4 3000 - 27.1 Max - 27.1 Max timing offset - 1.5 Low PSI Timing Reduct - 4 Timing Reduct Scale - 50% Light Throttle Timing Adv - 3 Light Throttle Load Limit - 30%
  5. First off. I would request that all brakes be inspected and the entire system bleed out with fresh fluid. Make sure the front calipers are not bound up. Then check there rears for any broken springs or issues. Rusting drums can cause the lockup you talk about you might look. Is your speedometer functional? Is it showing speed properly?
  6. Good time for upgrade to Quadzilla. Edge Products are not designed for larger injectors and do no give a way to change timing and fuel maps.
  7. Talk to @Me78569 he was the one building them.
  8. Be careful if you trigger 3 cylinder mode it will continue the same way as well.
  9. Totally normal. Once the mode is triggered and the switch is turned off. The ECM software is still flagged for that mode of operation till 165*F of coolant temperature is reached. Then the high idle is canceled. The other way to cancel is to turn the switch off. Then shut down the engine for 10 seconds to 15 seconds and restart. Then the high idle mode is wiped out on a fresh reboot of the ECM.
  10. Your looking for the 4 door extended cab.
  11. Master ground locations. Engine block Driver side fender near the headlight. Most all PDC stuff goes here. Driver side kick panel (inside the cab)
  12. In articles, under the 24V 2nd Gen the is wiring diagrams.
  13. Might have to do with the differences between the FASS and AirDog flow rates. Being we both have AirDog and @Marcus2000monster is talking FASS fuel system.
  14. I would assume a "Quad Cab" would required a "Quad Cab Cab Corners" An extended cab won't work because there is a no read quad door. Standard Cab wouldn't work either being the rear of the main door is the cab corner.
  15. That ground there is NOT a circuit ground or sensor ground. The problem is on some models the PCM is screwed to the plate on plastic nuts. What happens is the PCM is isolated from body ground for the case. The ground strap was added to give connect between the PCM case and the body that all. The ones with the plastic screw nuts without the ground strap, RF noise and other noise emissions could foul the PCM. The strap was added to prevent this. I repeat this is not a circuit ground or sensor ground. PCM actual ground is Connector #1 and pins 31 and 32 which head back to the passenger battery. PCM sensor ground is Connector #1 and pin 4 which service... Battery Temperature Sensor Fuel Level Sensor Transmssion sensors (governor pressure sensor and transmission temperature sensor)
  16. Mine did. I sent my first set of SAC injectors back with a miss and stalling issues. Less than 10k miles. Test out and sure enough couple where around 290 bar already. Then there was @pepsi71ocean 28k miles and around 280 bar with 28k miles. This is why I will not use the fuel module for suction and return both. This returns all the iar to the same confined space as the suction line. As for me I've got my return to the filler neck and the suction as a stand alone draw straw.
  17. Don't base it strictly on miles. Remember time as well. Like the 96 Dodge might only get 3k to 7k a year. If I based on miles alone the 96 would never need coolant change for many many years. Like 20 years.
  18. Newer the vehicle better the information. Like my 96 Dodge is extremely limited and most of the live data is odd. Like the 96 the MAP sensor is weird doesn't show real manifold pressures. So key on engine off it shows a weird minus pressure which should be vacuum but should be close +12.0 PSIa. Like the Cummins the MAP sensor doesn't report a real number either. I've documented that long ago.
  19. Tough one. I've only got the Dodge Ram FSM's. Sorry to say nothing for jeep per se.
  20. Simpler to just change the coolant and flush the block.
  21. Mopar tool if I'm not mistaken is brass like a brass cap of sorts.
  22. Bucking is typically too much timing advancement. You might want to post your timing settings.
  23. I was cutting my teeth on Mopar 318 and 360 CID for rebuilds and Chevy 350 CID for fun.
