  1. NO ATF! Power Steering only. ATF is used in 2003 and up. This is because the Sagnaw boxes where replaced with Ford Steering boxes. So 2003 and up all use ATF for 2003 and up Dodge and Ram Cummins trucks with Ford Steering boxes. 1989 to 2002 is ALL Power Steering Fluid. NO ATF!!! These are all Sagnaw Steering boxes and require Power Steering fluid.
  2. forum.mopar1973man.com was dumped years ago back in December of 2013. Back before that date, I was running vBulletin 4.2 (forum.mopar1973man.com) and Joomla CMS (articles.mopar1973man.com). There was a single app solution back then so the software was split up and subdomain was used to address both programs. Now after that date I move over to Invision Power Board software and everything was under one roof so the subdomain (articles and forum) where dropped after that point. There might of been old links on other places like CF etc that you could have got it from.
  3. forum.mopar1973man.com doesn't exist. https://mopar1973man.com/ will work just fine.
  4. Yeah it gets rather difficult on the mobile device but much easier for the laptop or PC.
  5. With my average distance per year at 60k miles about every year or 1.5 years I'm changing coolant. Full block flushing with clear water and reload with fresh coolant. Basically, either test with pH strips or use a DVM and check for charge state in the coolant.
  6. Make sure to FLUSH your system BEFORE installing. So do the fluid flush now to clean the system. Blue Top labels the gearbox clearing stating that if you pollute the new box with debris from the rest of the system your warranty is VOID. Then make sure to allow the system to drain completely. Then when you assemble make sure to use the new o-rings on the hoses. EZ priming... Have the front axle lift off the floor. Now assemble the entire system again. Now turn the key to OFF to unlock the steering wheel and slowly go from lock to lock on the new steering box. Check the fluid often. It with naturally prime the system without starting the engine. This will push the majority of the air out and draw fluid into the gearbox. Once the fluid is fairly stable go ahead and start the engine. Like it run just a little bit and shut down. Check your fluid if it foamed up DO NOT drive. Allow the foam to settle and top off as needed. Once it cleared you goo to go. WARNING: If you drive with the fluid foam up it will not pump properly. It may cause pump failure too.
  7. Make you think. A/C performance I can hold a fairly constant 35*F out of the vents on a +100*F day. Heater performance 160 and better on 0*F day. As for heater core failures never happened yet in 366k miles. I replaced my OEM heater core when I found the solder joint of the brass weeping. I upgraded to aluminum heater core years ago at the same time replaced the evaporator that was leaking. As for heater core failure typically is because coolant is not changed often enough. Do NOT rely on the label of coolant stating some guarantee of 5 years or 100k miles. There is a problem with Cummins and the heavy current draw during cold start which is what causes the coolant to turn acidic over time because at 500-700 amp draw on the ground side through the block eventually you state to charge the coolant. This is why they say you can check with DVM for voltage in the coolant. As it start to drift in pH then the electrical charge starts. Now as the pH continues to drift now the coolant starts to eat everything. This is the thermostat housing on the 1996 Dodge 1500 which was factory filled coolant with distilled water which looked fine but the coolant was very low in pH and had a fairly good electrical charge on it. Yep it was eating everything including the intake gasket which eventually ruptured and need to be changed!
  8. 4K box has different hardware and software. It basically has timing tables to 4k RPM and rev limiter to match. Where the standard Quadzilla goes to 3.2k for timing (typically) and rev limiter to 3.7k. I've never played with a 4k box to see all the difference in setting but the little that I've seen it a favorite for track and dyno guys. It might be I'm not sure about the updating exactly from a older V1 box to V2. If there was wiring differences or anything. @Me78569 would know the exact answer. This is something I'm not sure if there are any boundaries that would prevent the upgrade.
  9. It would be funny to find out it was a previous member here...
  10. Correct there is the standard Quadzilla and then the 4K Quadzilla. @Ronniemx3 might of been better buying a new unit.
  11. @Me78569 was building them for a short time.
  12. You might have to search the map in your area and PM a few people get them started. I would like to encourage member building groups within there own areas.
  13. Yeah it's a V1. Ask @Me78569 he would k,ow the answer.
  14. Let me round them up and I have to get back with you on email and get your address. I've got like 2 or 3 of those floating around.
  15. Could a ship you a few of those have you mill it down Please?
  16. I use a old quart bottle with the measure window. I pour what I need close and dump in. typically pump about 15 or 16 gallons so 1 pint all I need.
  17. As far as I know 3200 is the bottom. You could ask @Quadzilla Power if they would be willing add that option for say 2700 rev limiter which would be like old 12V.
  18. Just found this video. Good information on fuel spray.
  19. I just use foam weather tape myself and made it thick enough as when the case is assembled that the plastic made contact with the foam weather tape. You can stack layers to gain the thickness required. Once it pinched in place it won't move.
  20. 2G (guessin') pump exact match on the OEM AirDog. I'm glad I pack the way I do. It made it super easy. Knowing there is no parts to fix the problem and tools are not needed. We had food, water, blankets for warmth and doing just fine. No issues there. Every single failure I've had there was nothing I could fix in the field without parts to replace the damaged part. Now being I did pack for survival even in a city it makes the wait for the tow truck so much nicer and tolerable.
  21. Sagnaw boxes with some mild upgrades from what I understand. All the guts. The only thing your don't see is the 22 bb's that go into the worm gear. Like this... For informational purpose. 2003 and up you notice that all Dodge / Ram truck use ATF this is because the Sagnaw box was replaced for a Ford power steering system.
  22. That's what I'm hoping for.
  23. Video suggestion. Make sure to turn your phone in landscape. Then the video will not have the left and right black bars.
  24. @JAG1 Is right. The high pressure line is snugged up first then the injector hold down. If you reverse that then the injector hold down is tighten first then the injector can't center itself and typically creates a leak inside the head in the return rail and it just runs out the return line at the rear of the head.
  25. Not a bad starter injector to upgrade too. Sad to say some of getting that terrible infection that you can't cure with stock power. You get addicted to the power and like a junkie gotta have more. Stock to RV275 Rv275 to Vulcan +50 HP Vulcan +50 HP to DAP +75 HP DAP +75 HP to DAP +150 HP I'm a very sick man... Stock ECM to Edge Comp +120 HP Edge Comp to Quadzilla Adrenaline +180 HP I'm seriously infected... Help! I'm not sure if there is a cure for this...
