Alt. Ground mod?
This as simple as I can make it.
Who doesn't love a good pull
6% is for sissies...
Vibration after Southbend Dual Disc Clutch installed
Not normal. Something is out of alignment. I would send it back to the shop and have it reworked under warranty. Possible that forced the transmission into place and got it misaligned or possibly push out the pilot bearing (maybe?).
Fuse crimps
@pepsi71ocean Here is the fuse crimp for the PDC. https://www.mouser.com/ProductDetail/TE-Connectivity/881572-3?qs=sGAEpiMZZMvfFCidbTccAx7grAeSIDrq1vx0szo98wY%3d Here is an accessory PDC for homebrew. https://www.online-led-store.com/ols-12-slot-fuse-relay-box-for-bosch-style-relays-blade-fuses-pszacceps310h
Hmmm... I love good pulls when I'm seeing 45 PSI on my boost gauge. Even better when the tires are breaking loose in 4th gear.
42RE
Seriously... I would just pull the transmission and have it rebuilt and the torque converter replaced. I had a minor slip and 2nd gear starts. Sent it to a local shop and spent quite a bit. Ran good for 2k miles then the torque converter failed dumping its guts into the pan. Best service the whole thing out. Could be starting in 2nd gear. Try dropping to 1st and see if it shifts normal. Could be governor pressure sensor and solenoid.
Constant brake issues
That's the part I've got to ask why is the fluid this hot what is the cause? It's not normal. Even after all the miles on my own truck I've never had fluid temps that high. Even with all my 250 mile trip back and forth. Still in all fluid temperatures that high is not normal. That brings me back to causes. Like poor flow which is driving the pump to strain and return excessive at the pump own pressure regulator. Sludge, debris, damaged parts...
Alternator not charging: Getting Hot!
Don't do it... The external regulator will guarantee the battery life will be shorten for sure. The problem is that the location of the external regulator is extremely important. If you mount it somewhere where its too cold it will over-charge and boil the battery dry in a mere few weeks. If you mount it in an area to warm it will under-charge and leave you with a dead battery more often. You way better off having the PCM sent in and repaired. The battery temperature sensor keeps the batteries at a safe charging voltage and minimize the amount of water lost from the electrolyte. If you want to protect the PCM from this happening again you need to do two mods. Then protect the PCM... I've already been down this road and it cost me a total of $720 to do the repair correctly. Now I've got a 5 amp fuse on the field lead, 150 Amp charge breaker, and fresh alternator that passed AC noise test.
Actually, I would look into what is creating excessive heat instead of band-aid with synthetic fluids. Being I go through summer heat as high as 115*F and only used petroleum power steering fluid (SuperTech). Being larger tires and wheels tend to amplify this problem. Then offroad use at slow speed and turning the steering while not moving creates huge amount of heat. Again larger wheels and tire make it worse.
injectors
I know that SmartySupport.Com doesn't have there store together but they have access to BBI and Bosch injectors. You might want to talk to Brian over there. As for this, I'm not sure if they are truly new injectors. I know BBI are new injectors. Then some of the Bosch sold here in the are actually re-boxed reman'ed injectors from what I understand.
Power steering fluid should be changed every 30k miles.
P0016 - Crankshaft / Camshaft Timing Misalignment - Bank 1 Sensor 1
P0016 - Crankshaft / Camshaft Timing Misalignment - Bank 1 Sensor 1 Theory of Operation The Crankshaft Position (CKP) and Camshaft Position (CMP) Sensors are hall effect type sensors. The Powertrain Control Module (PCM) provides a 5-Volt supply to the position sensor and return circuit. A notch on the crankshaft gear is used to determine the speed of the engine by the PCM. As the notch on the crankshaft speed ring or the windows in the back of the camshaft gear move past the position sensor, a signal is generated on the position sensor circuit. The PCM interprets this signal and converts it to an engine speed. When Monitored and Set Conditions When Monitored: This diagnostic runs continuously when the following conditions are met: • With the engine running. Set Conditions: • The Powertrain Control Module (PCM) has detected that the CKP and CMP sensor values are not aligned and out of sync. Default Actions: • The MIL will illuminate. Possible Causes DAMAGE TO THE CRANKSHAFT POSITION SENSOR (CKP) OR CAMSHAFT POSITION SENSOR (CMP) DAMAGED TONE WHEEL MECHANICAL MISALIGNMENT OF THE CKP OR CMP MECHANICAL MISALIGNMENT OF THE CRANKSHAFT AND CAMSHAFT GEARS 1.DAMAGE TO THE CKP OR CMP 1. Visually inspect the condition of the tone wheel, CKP, and CMP for damage. Are any of the components damaged? Yes • Repair or replace any damaged component. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 2 2.MECHANICAL MISALIGNMENT OF THE CKP OR CMP 1. Verify the tone wheel is properly positioned relative to the locating pin in the front face of the crankshaft. Is the tone wheel properly installed? Yes • Go To 3 No • Repair the tone wheel installation. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 3.MECHANICAL MISALIGNMENT OF THE CRANKSHAFT AND CAMSHAFT GEARS 1. Check the mechanical alignment of the camshaft gear to the crankshaft gear. Refer to service manual for assistance. Are the gear teeth in proper alignment? Yes • Perform the INTERMITTENT CONDITION diagnostic procedure. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Repair the gear alignment. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
Wire tap to body ground on APPS wire
Ok, there is an add on mod for the W-T ground wire. This answer that question.
New Clutch
Nope. I just suggest going back to stock hydro personally. The upgraded hydro is a fight to get it right either hyper-extending the throwout bearing or undershooting and having the clutch dragging. All I can say back off till the clutch drag when pressed then ad back just barely enough to free the clutch with the pedal to the floor.
The Future of Trucks
Here is a bit on newer engines.
Monday Morning
Be careful of this. Like my OEM stock injectors are this way but the pop pressure was below 260 bar which is a complete failure. No blue smoke.
Let's Figure Out This 47re Problem of Mine.....
Should be up and running.
Big change in my life...
Surprising who you might encounter during normal life and what may happen.
Replaced Stock Injectors With RV275 Injectors
@pepsi71ocean need to drop a link here...
Any updates here?
Door switch or CTM?
Could you explain the 3 things...
Fuel Pressure Question
Like I'm an old school check ball and spring and just bending the spring wrong will create some wild up and down pressure swings when the check ball can't center properly. Yeah I've got to replace the spring again.
New Clutch
Throwout bearing issues. If you running upgraded hydro and over adjusted you could be hyper-extending the throw out bearing too deep in the pressure plate fingers. This why I do NOT suggest upgrade hydros this is more common than you think.
P0336 No Tach, Lack Of Power
Makes some sense...
47RE Help
The problem is the alternator get rather hot during grid heater cycles. This is why its best to start the engine and get rolling soon after starting to get the ECM to cancel the grid heaters. Now the alternator diodes get stressed from the grid heater and start to bleed AC noise. Being the ECM, PCM and VP44 ground is running parallel to alternator charge lead the AC noise jumps off to the ground side and messes with all the electronics. Here you can see the black/tan ground running right beside the black alternator charge lead. After the mod, the ground is on the driver side and the alternator is on the passenger side battery.
