Hello
I've got one out the side.
Pilothouse/RAM3500 build
Starting to look like a truck now. Compared to long ago with the body in cut pieces and trying to fab up the body. You are making good progress.
Quad struggles
Typically you open the EXE file on Windows OS and it should load the driver for Windows USB. Then you would plug in the Quadzilla module with a USB Mini cord. Then Ask the updates to find the module. If it can find the module then I press update and it will take off flashing the module. There were about 2 or 3 updates to the 2.7 firmware. Let say... I'm a Ubuntu Linux 18.04 user and can update using VirtualBox running Windows 7.
Hello
I've got the diodes in my basement. Just gotta grab one and stuff it in the small flat rate box. Make sure to check your diode and be sure of the BATT+ terminal design. I've got the one that is straight out the back not out the side.
Flashing WTS/ ECM replacement
Flashing WTS is a sign of a problem typically. I'm trying to remember but something about the ECM booting or software error IIRC.
Preferred U-Joints
Grease-able u-joints only here. I rather take the time and shot the u-joint with grease every oil change and push out the old grease, water, and salts, etc then replace with fresh grease. Sealed u-joint for me typically end a short life being there is no way to push fresh grease unless you press then all back out. Too much of PITA to do.
A/C blower conversion
Might look at the voltage at the blower. See how much voltage drop your getting. Check the voltage while running on HI and back probe the plug if possible.
Only 16 PSI?
I rebuilt plenty of Sagnaw boxes (Dodge and Ford). The only thing that is a pain in the butt is the all the BB's you have to work back into the worm gear. Sad to say people continue to save there photos on outside servers then kill the accounts. Then all the photos disappear.
Quad struggles
Are you sure you running the last app for your device? (iQuad 1.9.41) Are you running the latest flash for the Quadzilla Module? As for me, I do not list the double like you do that leads me to believe you not on the current flash.
Foglight wiring issues
Don't feel bad. @pepsi71ocean called me and asked about TIPM on another Dodge product. He found both headlight bulb was blown and the TIPM module needed to be hard reset. Now works fine.
42RE
Take notice debris in the pan. That will tell you what is happening. When mine ate the torque converter there was plenty of metal in the pan. Then you know you are going to be rebuilding.
Monday Morning
You only ask for a new VP44. Then @JAG1 proceeds to drop the intake manifold bolt down the engine side of the intercooler pipe. For an extra beer I would of do that gasket. But he never asked.
Only 16 PSI?
Rebuilding you can custom the nozzles and pop pressure and get them flow matched. New you are basically taking what random 6 injectors and no pop testing and flow matching typically. Wednesday I should see my injectors. DAP 7 x 0.010 VCO (+150 HP), popped at 320 bar.
Alt. Ground mod?
Lots of pictures...
Anybody running a mechanical locker?
. . . That one of the things. I'm an odd duck for reason. Longevity and performance are important. Now performance is not 1/4 mile or dyno queen stuff. It more along the line I want to pass the Ford in front of me. Matt the GO! pedal and I want it to hook up and pull right around the Ford before he's even got time to think about it. Then be able to set the cruise and let it sip fuel. Now like my 1996 Dodge 1500 that you have to have a clear mile to get around someone because it so slow to get up and go. You've got to mat that long and hard and fuel mileage shows. Either you drive like a Grandpa or suffer with the lower numbers.
Alt. Ground mod?
Basically in a nutshell. The alternator charger lead is completely removed from the alternator all the way back to the PDC. Then its cut much shorter and attached to a circuit breaker (150 Amp) and then to the passenger battery positive terminal. The Master ground is unwrapped down to the splice. The heavy gauge is cut off and leaving the small gauge wires. Now solder or crimp a ring terminal to those ground wires and bolt that terminal to the gear case near the VP44.
Constant brake issues
No PM box anymore. Gotta make a support ticket. We do have all the FSM in the Download area.
Let's talk about shocks.
Now cheap crappy shock is the Monroes I've got on the 1996 Dodge Ram 1500. Those are plain sloppy and rides like the shocks are nearly worn out. A bit too bouncy and leans excessively in corners.
Who doesn't love a good pull
Wire tap to body ground on APPS wire
I used a standard ATC fuse holder and installed right near the PCM. You only needing a 5 amp fuse so gauge size is not a huge problem. Like my fuse holder is 16 AWG. At 15 feet, 5 amp load, 12 Volt system 16 AWG wire is suggested. But the run isn't that long even.
One of the few reasons I love the standard open diff. It only spins one tire keeping the truck from sliding sideways on ice or slick surfaces. Whereas when its fully locked up it will now lose all traction drift sideways because both tires are spinning. Nearly 400k miles trouble free with good ol' Open Diff's.
Surprising how some people don't jump on the Bilstein wagon and go a totally different route. @98whitelightnin you got a point that over all the miles the coil springs get tired of carrying that 1,100 pound engine and tend to sag over the years.
Still, in all, the Factory shocks, I had lasted a 150k miles were just weeping oil. The Rancho's that I had last well over 150k miles and never leaked oil at all but lost the gas charge. Now on the KYB Gas A Just shocks and still doing awesome. I'll most likely ditch the shock sooner like 100k miles and freshen up. Shocks seem to degrade slowly and create issues without you really noticing.
42RE
I would say its moderate difficulty. All basic hand tools. It about just getting everything clean and re-assembled with fresh parts. The only thing that requires a special tool is the overdrive clutch which you need a press to release the snap ring and carefully release the spring pressure. @Dynamic is a storehouse full of information on this.
What belt with Mechman Alternator
Isn't there an RPM limit? Curious of how fast you can run the alternator?
