9004 to 9007
Most likely will happen. 100w bulbs pull about 14.2 amps. You would be best setting up relay kits to keep the wattage off the stock wiring. The other thing to watch for is the amount of heat the bulbs give off and will it melt the headlight housings. I know there is a few that upgraded to larger blubs without many issues.
DAP Injector Upgrade 7 x 0.010 @ 320 Bar
I finally got the 7 x 0.0085 @ 305 bar removed and the 7 x 0.010 @ 320 bar installed. What I noticed right off the bat is the idle is MUCH smoother. Without changing any of my tune on the Quadzilla I had it on level 0 for extended warm up. Then I flip back to my max power level of 7. Once it warmed up it was a bit smokey. Quickly changed up my timing and a few timing setting and cleared a bunch of that up. Enough power it to break the tires loose in 3rd or 4th gear. I've got to play with the tune a bit to clean stuff up for sure. +150 HP VCO 7 x 0.010 @ 320 bar are a excellent choice for Quadzilla Adrenaline.
AirDog 165 4G vs AirDog 150
I finally got my pump yesterday. Old version left 4G on the right. Got it installed I'll report more after the 7 x 0.010 injectors get installed.
No washer or intermittent wiper
Gamble. Try changing or trading the wiper relay out with something like the horn. Try again.
Trailer Wiring install '71 F250 Fummins
Mopar1973Man replied to Bacon Creek Metal's topic in Utility Trailers & Recreational Vehicles (RV's)Good guess... I gave it a honest try. But the wiring is still the same for the trailer stuff.
Mopar1973Man replied to Bacon Creek Metal's topic in Utility Trailers & Recreational Vehicles (RV's)I was assuming that @Bacon Creek Metal possibly had the PDC box under the hood. If so then from that point he could hook to the PDC for everything and run back to the bump or trailer socket. Yeah I knew it was a Fummins but not knowing how much there is under the hood it still would give clues.
Here is what I've got for wire map as well. Wiper motor failure. The park reed is most likely damaged. Most likely when you try turning them on and then switch then off but the motor couldn't reach park again. The motor was in a locked state and most likely burned the park reed.
Mopar1973Man replied to Bacon Creek Metal's topic in Utility Trailers & Recreational Vehicles (RV's)In the PDC there should be a 40 Amp fuse separating the truck from the trailer. Fuse #8 - 40 Amp As you will see the power lead for the brakes come from there, and power for the brake controller. Same 40 Amp fuse supplies the the tail light of the trailer past the trailer relay. Your trailer brake there is a blue plug under the dash this is the trailer brake plug. You can still get the pigtail from Dodge Dealer for this so it easy peezee to hook up the trailer brake.
Central Timer Module. It above your throttle foot in the dash. Near the power point plug. CTM takes can some cab functions like delay wipers, security alarm, etc.
some VP44 info
Other tidbits... Bosch requires fuel lubricity to be 460 HFRR or less. Since ULSD was released the lubricity went up to roughly 520 HFRR. The only fuel that meets the requirement is BioDiesel. BioDiesel comes at increased price over Petri diesel. Then typically has a warmer pour point and telling issues. Then BTU content is much lower compared to petro diesel.
Preferred U-Joints
For what ever reason I had replaced all the factory seal ujoint before 30k all had failed. Have very little trust in seal u joints.
If the wiper are coming on the fuse is good. There is a relay in CTM that comtrols delay. I'm not sure if you can fix the CTM. Might be a fuse for the CTM.
Big change in my life...
Absolutely. I'm going to challenge this and beat this down. I'm not going to give up. Managing my time is tough.
some VP44 info
Tidbits... Max timing is 32° BTDC. Optimal fuel pressure 14 to 20 PSI Filtration should be 3 micron. Double stacking filters is a good thing. Most error codes are electrical failures. P0216 code is typically mechanical failure and not capable of meeting commanded timing.
Like today made my appointment for my kidney check up on Friday. Then even with screwing up this morning and getting up late I still put in 9 miles riding in Payette and Ontario. Feeling good yet and still gaining my stamina. Getting easier and easier to climb grades.
No abs, no abs light. Help!!!
Some thing to try is pull the fuse for the ABS. This should trip the light and disable the ABS system. Worth a try. If it still locking then it's a hardware issue. Not an ABS issue.
Block heater
Like myself my truck stay in a unheated shop above freezing typically. Now once on the roll it cold start when I roll again. Like I've got 4 hours to wait in Ontario, OR before heading home. Block heater would be nice but no power available. No need for block heater at home with garage temps around 35 to 40 F. Add-on: It was only +3F in Midvale when I rolled through.
Block heater
This why I'm not in favor of the block heater idea because you might be able to have block heater when you are at home but when you get to where you are going it's going to sit out in the cold regardless. Then you end up firing up cold without the block heater. Like I made the comment above if its that required you better pack a generator and extension cord. When you get to the truck you better fire up the generator for 45 minutes to warm the block up before starting. I know no one will do this. But that is the point if a block heater is so required this is the only method you should use to start up. Like up here I see trucks sitting in distant parking lots for days if not weeks while the owner snowmobiles into a remote cabin and stays for winter vacation, Christmas, etc. No one has a generator in the bed of there trucks. Sometimes weather conditions can be as low as -20*F. Another great example. Logging company right in New Meadows, ID I roll through in the morning and watching the crew fire up. NONE of the trucks have block heaters and sitting there blowing white smoke as they warm up slowly. Again New Meadows I've seen temps as low as -40*F. Closest weather tower to me. https://lb.511.idaho.gov/idlb/rwisstations/rwisstation.jsf?id=9&view=state&text=m&textOnly=false
Preferred U-Joints
NAPA. I got mine pretty good price for the joint ball.
Quadzilla tunes for big turbo
Also going to be 7 x 0.010 injectors on HX35/40 hybrid (60/60/12). Bit smaller but should hold up fine.
In the high country. This is below 3k feet. Don't own one. I've had to give up computer time and make it a habit to ride my bicycle at least 1 hour a day. Yesterday between the for and the bicycle ride burned a bunch of calories. After getting home a bit of cannabis to dull the pain, hot shower and some dinner. I'm not the type to quit nor just lay down and give up. Here I slept for 4 or 5 hour and woke up just to check on the website at 1am.
I did something rather bold today. I got phone call from the fire chief. Grass fire in local neighborhood. Saved 2 homes and got the fire out before USFS got there. Needless to say... I'm a sore puppy after that.
6.7 2018 3500 with asin Tradesman
@Me78569 I've got to ask what do you have on the clock?
Fuel mileage sucks! Please help!
Clue. More boost you see going down the road means typically your burning more fuel. I've got to ask what is your engine load and boost pressure like at highway speeds? Boost you should be below 5 PSI for 65 MPH. Engine load should be around 20% or lower if possible. Injectors what are you running? What was the pop pressure at? How many miles on the injectors?
Block heater
Not to argue... But... if that is true you better keep a generator and cord in the bed of the truck anytime you go anywhere. Once you leave home what is going to warm it up when you away from power? Like myself I can stop at our morning breakfast stop in Weiser by the time we are done with breakfast on a single digit morning I can lose all the coolant temperature. I've seen this a bunch in minus weather. I gave up on the whole block heater thing and look for ways of generating heat when in the field. Hence the high idle kit. Too many time gone to fire calls and being in the middle of nowhere. Yes in Idaho there are still homes without power to this day. Yeah, power I create most of my own.
