Filling oil filter when changing oil?
Talk to @IBMobile he's working on a smog friendly grid heater switch. Not enough heat energy to light off the fuel. Grid heater heat the air in the manifold. So when the air is drawn in there is now enough heat energy to light the fuel.
Spicer ball joints
The biggest thing is wheels and tires size. I've got 176k on my current ball joints and still tight.
Stock Carter Fuel Lift/Transfer Pump...Replacement Quesiton
I learned this stuff the hard way. I did the Vulcan Big Line Kit. Then relocated the stock Carter pump. Worked good but the pumps where junk. Then upgraded to AirDog 150 but ran in on the stock fuel sender but the pressures were very wild. Once I installed the draw straw I've had zero issues for 13 years and 250k miles. I've installed a few DDRP pumps for locals and all them failed the same way with pump failure. Calculated max flow at the open end of the stock banjo was like 50 GPH really sad to see performance 100 GPH pump pump choked to 50%.
At home I park in the garage which typically stays above freezing barely. Once on the road I could end up leaving the truck parked in subzero. I just cycle the grid heater twice and hit the starter. These are not Ford Powerstrokes that need block heater and battery charger to start in the cold.
blew a belt, now oil leak.
Just a plastic access cap, no vent.
HE351CW
You would better off setting you goals on a good tuner first. HX35 can work with +100HP injectors with a good tuner.
HE351CW
HE351 is the same as my hybrid expect it tiny exhaust housing. HE351 (60/60/9) HX35/40 Hybrid (60/60/12) Personally, I would go for the hybrid before the HE351. Better exhaust flow.
No. That just an installer tool.
I've used a NAPA seal on mine still doing good over 100k miles.
Rabdom soft shifting
Typically he does but if he's not responding in a day or so send him a message.
No Start
Rev 027 pump do not have a diaphragm. The only ground you need to worry about is the passenger side battery terminal. You might consider the W-T ground mod. What is your fuel pressure? Cranking, idling, highway speed and WOT?
Time to talk to @Dynamic he's the forum transmission guru.
P1689
White/blue smoke on highway
- blew a belt, now oil leak.
At the most a crank seal. The gear case I'm pretty sure is like the 2nd Gens has no gasket and just grey silicone. No real parts to order a local part house should have all this in stock. The only thing that has oil is the gear case in front.- White/blue smoke on highway
P0606 is an ECM failure. Passenger side battery is the ground for the ECM. The if the alternator has bad diodes then the AC noise will produce the P0606 code from AC voltage damage to the ECM. I highly suggest... Replace both batteries. Have the alternator tested on a test stand for AC ripple Replace all battery cable that is damaged. Do the @W-T ground wire mod. Clear the codes and see if the P0606 comes back.- Track bar
Standard NAPA track bar. I don't buy into the premium junk.- Track bar
Yes, replace it. I bought an Autozone track bar being low on funds. I was shocked to find the AutoZone track bar was a sealed unit and figured that the ball end would fail first. Nope. The rubber end failed and it was pulling the bolt back and forth. Once replaced it with NAPA track bar the steering was tight once again.- blew a belt, now oil leak.
On 3rd gens there is so little room compared the earlier 2nd gen. I know on the second gens you can do the crank seal and gear case without pulling the front apart. As for the 3rd gens I would opt to at least pull the fan out so to gain some room. Yeah you got to unplug the fan clutch and get a fan wrench set but once the fan is out of the way I'm pretty sure you'll be able to change the front crank seal and reseal the gear case.- Stock Carter Fuel Lift/Transfer Pump...Replacement Quesiton
I would suggest against it. Typically the DDRP (Dodge Direct Replacement Pumps) don't address the plumbing issues. So the pressure problem will continue. Also the DDRP pump don't isolate the ECM from the pump so if the pump shorts out you take the risk of eating a ECM. There is no fuse or relay for protection like the bigger kits like AirDog 150 or FASS 150. You need a fuel system that replaces everything from the fuel tank to the VP44. So you going to buy a good high power fuel lift pump but force it to suck on a 6mm straw and push fuel through the choked banjo bolts. Not a good idea. Good way to experience this is take your favorite beer put it on the back bumper and get some 6mm tubing and suck your brains out to get your beer. The stock fuel pickup module is also too small to this why most have either modified the stock fuel module or just installed a drawstraw.- Would You Reuse an A/C Evaporator?
I would only reuse an evaporator in two conditions are met. 1. There is no visible damage to the evaporator or visible leaks which show up as an oily spot. 2. No "Black Death" in the tubes. Black Death is the aluminum grindings from the compressor. As long as the tubes are clean I'd use it.- Subwoofer pop when stereo turns off
Talk to @IBMobile he knows the relay to use.- Mobil 50 SAE Transmission Fluid used in NV4500
4 quarts.- Stock Carter Fuel Lift/Transfer Pump...Replacement Quesiton
Just like me shutting down my exhaust brake I get the crack from the discharge of the solenoid magnetic field just like an ignition coil. You'll need a proper filter diode like in quality relay have that reduce the discharge spike across the diode. - blew a belt, now oil leak.
