  1. Problem is you need 14 to 20 PSI for optimal VP44 lifespan. Below 14 PSI the overflow valve is closed. Stock Carter might barely do 14 PSI at idle but will drop it 8 PSI because the plumbing is too small.
  2. Between injectors or compression. You could pull the injectors and gave them tested with DAP. While the injectors are out do a compression test. You'll find out if you wash out the rings and cylinder walls. Then the injector test will tell you if the injectors are failing or just wore out.
  3. Time do a compression test.
  4. Most likely to go along with the synthetic chicken right?
  5. 450,494 miles for us US folks. Welcome to the website and the family Cummins owners.
  6. I'm trying something different. I'm straying my calculation a bit. I know that the Hankook 245's are the same weight capacity as the 235's. Now I'm going to keep the offset from front to back but I'm going to rise +10 PSI to both axles. So my front is 70 PSI and the rear is 50 PSI. I'm mostly highway miles right now but I've had strange wear patterns in the past running 60 PSI front and 40 PSI in the rears. It would feather or cup the edges of the tires. When the winter weather and road conditions come I might drop back to get the bite for traction purpose. With the pressures this high I've notice my contact patch is much smaller for sure.
  7. The only thing I've been having a problem with lately is a weeping fuel leak. Not enough to make a mess but it still dripping off the bellhousing. It will drip just enough to spot the ground and smell of diesel fuel. I replaced the two sealing washers on the return line at the back of the head. That is a trick to do. I tell you a secret is to put your new sealing washer on the banjo bolt and put it in place in the banjo fitting. Now push the fuel line back against the firewall to hold the bolt in place now you can push the second sealing washer on the bolt. Now just thread it back into the head. Crossover tubes got fresh o-rings during the assembly process and the injectors got fresh o-rings too. I'm chasing the fuel leak between either #5 or #6 behind the hoist ring. Maybe I got it this time. Never had a hard start issue.
  8. The only reason I can see jumping to 17-inch is for the 3rd Gen oversized brakes. But if your using the 245's like I'm running you have better final gear ratio and better braking than upgrading to 17-inch wheels and oversized sizes. I jumped back to the 2nd Gen steel chrome wheels (16 x 6) which happen to be 1 inch narrower than the aluminum wheels (16 x 7). Most people look for the cool factor and go oversized. I stuck to the performance and calculation of gear ratio and torque output. Now I actually hunt for the big jacked up 37" tires because I can whip them with no problem. Done it more than once. Funny when a small tire stock height 2nd Gen whips a 4th Gen jacked up on 35" inch tires.
  9. Kind of why I do the double stack filter setup. AirDog 150 with Donaldson 3um filter and then the stock filter can is still there and I've got a 7um filter in there. So no matter what I've got a better chance of keeping dirt and water out of the injection pump and injectors. I will not buy the cheapest fuel either. I typically stay to either name brand truck stop that sell high volumes of fuel or name brands like Chevron. No mom and pop fuel stations for me.
  10. So am I. At least I don't have to worry about him being too cold in the garage as I leave for 13 hours for MoparMom's dialysis treatment. Then if I take him I would have to go out and fire up the truck and let it warm up so he didn't freeze to death in subzero weather. Visa Vera when it was summertime like you worrying about him being too hot in the truck. Being cooped up in the garage for the 13 hours where it was at least cool for him. But I know he got lonely laying down there waiting for us. Just because of the circumstance its best to be dog free for the time. In the future, if things change then it would be time to get a dog.
  11. I would have those rotors checked for cracks and runout before machining or thinking of using those rotors. I'm betting the slotted rotors either cracked or they are not machined true at all or both.
  12. Kind of like my 1973 Dodge Charger SE which was the first vehicle I ever owned. I rolled 336k miles on the odometer then sold it about 4 years ago. That car I replaced the original 400 CID with a 383 CID and beefed it up and had the 727 torqueflite transmission. My Dad bought that car brand new back in 1973 at Reseda Dodge. I even gave the new owner all the original invoice from the dealer. My 1972 Dodge Power Wagon I put on a bit over 220k miles and because of my lack of knowledge of oversized tires (and wanted to look cool!) I ended up destroying that front axle 3 different times which forced me to buy the current 2002. No longer could get part for that truck being so old. I learned a lot from that old truck. Now with my 2002 Dodge currently running, I've traveled 356k miles and still going. Yeah, I've had to do repairs but nothing outrageous out of the norm. I tow mostly during the summer either my utility trailer packed with firewood or the RV. Believe it or not my Cummins has only been towed home once in its life. (Broke the transmission mainshaft). Very reliable truck and always brought me home safely. Even in the worse of weather this Cummins just keeps rolling. Never gelled fuel yet even with the weather down to -40*F. Always started and always brought me home. I still going to cross the 500k milestone for sure. Now as for when I bought the 2002 Dodge brand new. Yeah, it was cool to have a new truck and no issue. But... When issues came it was a pain in . By the time I reached 48k on the clock, I was losing my first lift pump and then by 50k lost the VP44. Not long from there I gave the Dodge Dealer the middle finger and became my own warranty station. I was already learning about the crappy lift pump and fuel supply by then and the dealer wanted to install an in-tank lift pump which I refused. After that point, I handled all the repairs on my own. I've never looked back. So I basically threw away 50k miles worth of warranty to keep from getting crappy parts which would have kept me coming back for VP44 replacements. I doubt I'll ever buy a brand new truck again. Having a truck payment and dealing with the service techs and making sure your getting the best option. Naw... I'll turn wrenches until I can no longer do it. The fact is no matter what vehicle you buy today they all have there own weakness and it up to you as the owner to study up on those weaknesses. Being I deal with vendors and other providers for the Dodge / Ram Cummins I know a lot about the newer trucks and not very happy with the current state.
  13. TUNE PARAMETERS Side note, if you would rather have a pre built tune to start with you can checkout our tune repository. https://mopar1973man.com/forum/182-quadzilla-v2-custom-tune-repository/ Number of Power Levels Range of Values: 6 to 15 Default Value: 11 First off let me state there are fixed levels on the Quadzilla Adrenaline that you cannot change. This is levels 0 to 3 which are listed below. Stock - Quadzilla Adrenline is disabled and Stock ECM tune is used. Valet Mode - Explained below. CAN Bus limited to 100% - Quadzilla CAN Bus fuel is used until it reaches your 100% mark, then stops and holds 100% up from there. CAN Bus fuel - Full CAN Bus fuel table is used. Level 0 - Allow you to shut down the Quadzilla Adrenaline completely. The ECM is in full control with stock fueling. This level also is used during engine warm up and limits your fuel to your 0 PSI fuel setting. Level 2 - This is good for finding your spooling curve. Once you found your starting percentage using Valet Mode you can now build a fuel curve using Level 2 keeping the smoke under control. So for example, if you find that 80% is your 0 PSI position then do +1 percent for the first 5 PSI then step up doing +2 percent which will have you at 9 PSI at 99%. Then you can test this part of your tune by doing several heavy throttle launches and watching your smoke. Note that Any value over %100 is ignored. OEM duration is max duration on level 2. Level 3 - Now you can test your full CAN Bus fueling map as an entire tune. This level could be used for people with weak transmissions or clutches to extend its lifespan just a touch longer. Level 3 might also be helpful for winter driving conditions keeping traction better. From level 4 on up to 15 are wiretap levels which are divided up in a percentage of cut of power. Like I prefer using 7 levels. This gives you 4 wiretap levels which becomes... 25% wiretap power 50% wiretap power 75% wiretap power 100% wiretap power So you can divide up 12 times of the wiretap if you wish. RPM Limit Range of Values: 3200 to 3700 Default Value: 3200 This is the governor setting of the Quadzilla Adrenaline. This is the maximum RPM that Quadzilla Adrenaline will fuel too. Without supporting modification I don't suggest higher than normal RPM limits. Stock RPM limit is 3200. VALET MODE PARAMETERS Maximum Valet Mode Power Range of Values: 0 to 100 Default Value: 50% Quadzilla Adrenaline Valet mode has a few different purposes which is level 1. It can be used for what the title states which is a cut of power for valet mode to use your vehicle but not allow them to use the full power. Valet mode can be used to find your starting fuel amount without smoke. Then the last thing is using it as a security feature where the truck will start and run but only travel at super slow speeds. As for finding your starting fueling you would select level 1 and then set your valet mode amount. Depending on how big your injectors you may be higher or lower than me. I'm using DAP (7 x 0.0085) injectors which has a clean start out at 80%. So you would set your percentage and do several heavy throttle launches watching you smoke amount. Start low and bump up slowly till you see haze then back off slightly. This will be your 0 percent value you will use in your CAN Bus fueling table. As for security you can set the Valet Mode as low as about 20% and it will start and run but at full throttle, a thief will struggle to build speed beyond 20 to 30 MPH. If you set this too low it can cause it to stall out when you give it throttle. As for Valet Mode you want to set enough for a person to drive the vehicle normally in a parking lot or at speed you wish. You'll have to experiment with values to you find what you like. PUMP TAP PARAMETERS Maximum Fuel Stretch Range of Values: 1200 to 2200 Default Value: 1800 This value is pulse time in microseconds that Quadzilla Adrenaline will give to the wiretap to the fuel solenoid. When the CANBus fuel end this is the amount of time (microseconds) in fuel signal added to the fuel solenoid holding it open. My suggestion is to start out at the 1200 setting and work your way up till you get your fuel to boost figured out. There is very little reason to even get close to 2200 setting which in most cases will result in excessive black smoke which does mean you are overfueling. TPS Pump Maximum Range of Values: 0 to 100 Default Value: 100 This is the TPS value that Quadzilla Adrenaline wiretap will peak out at. The wiretap will continue at the power level you at that TPS value. Typically this is just left at 100%. TPS Pump Minimum Range of Values: 0 to 100 Default Value: 20 This is the TPS value that Quadzilla Adrenaline wiretap will start at. You can specify TPS percentage that will trigger wiretap. If this is set for zero and then the Pump Low Boost Scale PSI is used. If both values are set for non-zero then both conditions must be met before wiretap occurs. Typically I would leave this set for zero. I've tried 30% setting a few times but it makes the wiretap start point rather random being that you have to make both boost pressure and TPS conditions true to make it start. Best to use boost pressure as a trigger and leave this set for zero. Minimum Pump Tap Fueling Percentage Range of Values: 0 to 50 Default Value: 0 This is the minimum amount of Quadzilla Adrenaline wiretap to start out with. Most for daily driving will leave the wiretap set for zero. Pump Low Boost Scale PSI Range of Values: 0 to 25 Default Value: 5 Quadzilla Adrenaline Pump Low Boost Scale PSI is the boost pressure that will start the wiretap. You should set this just high enough so the turbo is just getting spooled off the CAN Bus fuel and then you can kick in the wiretap without much smoke change. Boost Scaling Range of Values: 20 to 40 Default Value: 38 Quadzilla Adrenaline Boost Scaling is the point at which the wiretap will hit 100% wiretap. The lower in the boost number the quicker it reaches 100% wiretap. Basically, in a nutshell Pump Low Boost Scale PSI is the starting boost pressure to start the wiretap and Boost Scaling is the point that wiretap will reach 100%. TIMING PARAMETERS Max Load Timing Offset Range of Values: 0 to 3 Default Value: 3 Quadzilla Adrenaline Max Load Timing Offset is used for giving the amount of retard over a range of engine load. For example, if your set for 3 then you would have -3° retard at 0% engine load and at 100% engine load you would have 0° retard. Example if you have 14, 18, 22, 26 for timing with 2 Max Load Timing Offset. You can see the Timing max values in the 100% column. The way to check the impact of the Max Load Timing Offset is to get to a cruise speed near 1,500 RPM and then add some grade or add throttle to increase the load to fall out of the Light Throttle Load Limit and just as it does the timing should drop to its lowest point now. Using the table above for an example if the Light Throttle Load Limit is set for 30% that means it should fall to about 12.6°. This gives you an idea that you have to figure +2° to allow for the Max Load Timing Offset the room to retard the amount you've set. Checking this setting can be rather difficult for varying road conditions. What you want to look for in your data logs as the timing vs engine load. As engine load rises past the Light Throttle Load Limit (Percent) and drops into the performance range then the timing should drop this set amount look and see what the timing value is and if it's retarding too deeply at this point. Low PSI Timing Reduct Range of Values: 0 to 5 Default Value: 2 Low PSI Timing Reduct is the amount of timing Quadzilla Adrenaline will retard during heavy throttle conditions. This is to aid in quick spool up of the turbo. Value can be altered by the Timing Reduct Scaling below. Both the Low PSI Timing Reduct and Timing Reduct Scaling work during low boost acceleration like below 5 PSI of boost. Timing Reduct Scaling Range of Values: 0 to 100 Default Value: 100 Time Reduct Scaling is a percent value. For example, if you have 5° of Low PSI Timing Reduct and you have Timing Reduct Scaling set for 50% then you only going to get 2.5° of retard to the timing for 50%- 100% of the TPS. A rather Difficult setting to explain but the Timing Reduct scaling is basically the steepness that affects both the amount of timing and range of the TPS. If you to apply 60% TPS then you will still be left with 2.5* of timing retard. If you set this for 100% then you get 5° of retard increase in a linear fashion until you hit %100 TPS. These functions are a limit function of Timing reduct, to give a faster pull of timing with limited TPS input. Once 10 psi is reached there is no longer timing retard given by the Quadzilla Adrenaline. Light Throttle Timing Adv Range of Values: 0 to 8 Default Value: 2 Quadzilla Adrenaline adds this number of degrees of timing added on top of the RPM Timing Max. If you have 14, 17, 20, 23 set for timing then have Light Throttle Timing Adv set for 3 then the result would be 17, 20, 23, 26. This is only base numbers. When in light throttle condition Max load timing and timing reduct are not considered. Light Throttle Load Limit (Percent) Range of Values: 0 to 40 Default Value: 30 Quadzilla Adrenaline Light Throttle Load Limit is the engine load value that Light Throttle Timing Adv will end. Like my tunes I've been using 30% so from 0 to 30% engine load the Light Throttle Timing Adv is added to the timing value. Once the engine load rises above this set number then Light Throttle Timing is no longer added. You want to set this value to something that allows your normal flat ground cruise to stay within cruise timing. I suggest building this around 65 MPH speeds. Like my truck, I hold right about 25% engine load at 65 MPH on flat ground 30% gives me a bit of wiggle room for the roll of the land. Excessive high settings will hold the advanced timing too long and make it counterproductive if you hit a hill or grade the advanced timing will prevent boost to build easy. You want it to drop this and switch can to a more retarded state to build boost for power. This will now flip back Max Load Timing Offset. RPM TIMING MAX RPM Timing Max Default Values: 15°, 18°, 21°, 23°, 25° Mopar1973Man Suggested: 14°, 18°, 22°, 26° ***adding more timing up top will result in more power, but my goals are mpg. NOTE: The green bands are considered safe ranges for a stock unmodified engine. If you wish to experiment beyond the safe ranges we highly suggest installing the supporting modification like head studs etc before experimenting with high timing values. RPM Timing Max this is the maximum amount of performance timing you can reach per RPM band. Used normally this timing structure replaces the ECM completely. You can build a timing curve any way you which and any curvature you want. In my example, I'm running an offset between bands at +4. 13+4=17. So forth. Notice the max timing slider I've set for +3 only which is to match the cruise timing value this prevents cruise timing from being canceled on this limit. What to set your timing too? What we are finding out there is such a wide range of variance in peoples tunes. There is no exact formula for timing. The rule of thumb most tend to fallback too is that Light Throttle Timing at 2,000 RPM should be in the 19° to 20° range roughly. If you have a 3 set for Light Throttle Timing Adv and then you now see 17° plus 3° you come out at 20° Light Throttle Timing. Now if the Light Throttle Load Limit is set for 30% then when you exceed that It will drop back to 17° minus the Max Load Timing Offset. As you can see the low engine load end up with a bit extra retard to allow for building boost pressure to carry the load. MAX Slider controls the absolute MAX timing advancement you can have. For example, if your Light Throttle Timing Adv is large enough to push the timing above this setting the Light Throttle Timing Adv will be canceled and push back to RPM Timing Max. You will basically lose you cruise timing at this point and be forced back to performance timing. QUADZILLA SECRET: If you set all TIMING PARAMETERS to ZERO then on the RPM Timing Max slide up what you want to add to the stock ECM timing you can now run ECM timing plus a value compared to the fully replaced timing that Quadzilla normally does. Timing add limit is 5* in this mode. Bucking and backfire are typically signs of excessive advanced timing. Then if you are too far retarded you'll see more of bluish grey haze and cutting out. Timing Steepness Some idea on timing. Consider the span between bands as how steep the timing is. Like for example of 15°,18°, 21°, 24° this is +3 between bands. Now, look at +4 between bands 15°, 19°, 23°, 27°. As you can see timing is much steeper curve. Amount of step between bands is going to affect the steepness of the timing curve. Fixed Point Timing Another one that is common people want to call out a 2,000 RPM timing point. You can do this. Let's say you wanted to have 19° at 2,000 RPM now figure up and down from that point using the amount of step between bands. This is kind of common when you building tunes for daily driving because the 1,500 and 2,000 RPM bands are you common RPM span of a daily driver. Anchored Ended Timing What I mean here is you can start from a low end or high end as an anchored point then build from that point. For example, you have 13°, 17°, 21°, 25° (+4 step) you can anchor the high end and then suck the low end up given advancement. 14.5°, 18°, 21.5°, 25° so I built this backward starting from the fixpoint of 25 and minus 3.5 downward. This is handy if you know your max timing limit you can build downward. Bit Shift Timing This is a way of advancing or retarding the entire table in on adjustment. For example, you have 13°, 17°, 21°, 25° for current timing you could plus +1° to all bands and then end up with 14°, 18°, 22°, 26° for timing. Be aware changing timing like this affects the cruise timing as well. If you shift towards advancement then cruise timing will too, and the same said about retarding in this method. Timing Limits (What is too far?) It's rather difficult to specify an exact number of degrees as a limit for each truck. There are variables like injector pop pressure, injection pump accuracy, cetane of the fuel, coolant and air temperature that play a role in the amount of timing each truck will require. I can give clues on what to look for. Bucking or Backfiring is a sign of too far advanced in timing. Pay attention to the RPM realm that the bucking occurs and then try dropping that band 1° worth of timing or bit shift the RPM Timing Max table retard 1° degree and see if that helps. If you retard too deeply typically you notice the engine seems very quiet and tends to produce more white/bluish smoke. Builds boost rather well but launch power seems a bit slow to build though. Most applications the green bands on the RPM Timing Max table are very safe realms to work in. Retarding timing will allow for building boost pressure by pushing some of the expanding gases through the turbo. Advancing timing puts the majority of the energy to the piston as long as it's not too advanced which in turn can produce "negative torque" where the piston is being slowed down by the expanding gases but then breaks over the TDC and the gain power again. This is non-productive in negative torque state. It is important to remember that nearly all box tuners for 2nd gens max out timing at high boost and ~2500+ rpm. Max theoretical timing is 32° degrees of timing. Fuel Cetane Things to stay aware of setting timing. ECM and VP44 cannot detect cetane level. As cetane goes up the ignition quality of the fuel is better and faster so less timing is required typically for winter fuels with high cetane. Same can be said true about summer fuel added timing advancement will be required because of lower cetane typically in the summer. Keep in mind cetane is backward to octane. More information on cetane rating here. Cetane tends to carry more weight in tuning than IAT temperature so consider your "Winter Time Fuel" first before considering IAT temperatures. IAT Temperatures As the air gets colder it takes longer for the fuel to go from the atomized mist, to vapor to ignition (BANG!). Stock ECM can step up over 4° advancement as IAT falls below +80°F IAT. Since diesel engines and diesel fuel ignite based on heat in the cylinder things like coolant temperature, IAT temperature and cetane all have to be considered when building your timing tables. Stock head on the Cummins ISB has the IAT sensor within a few inches of the coolant jacket in the head. If you watch both fuel temperature and IAT you will find that both follow closely together in temperature as long as the stock fuel filter can and fuel heater still active. This is why if you monitor the cold start run of the ECM (level 0) you see extremely high timing like 21° at road speed. This was to aid in cold fuel and cold air running. BOOST LEVEL FUELING - CAN BUS Boost Level Fueling - CAN Bus NOTE: The green band is considered safe normal ranges. QUADZILLA SECRET: If you set 100% in all positions you would have ECM stock fuel table. All values are ECM fuel value times the percentage given. Like 0PSI value is 85% so if I command WOT the most I could get is 85%. ECM (100% fuel) x Quadzilla (85% Limit) = 85% This makes it possible to have below stock fuel rates for large injectors and control fuel to boost pressure and keeping smoke under control. This is your CAN Bus fueling table. I will suggest when your building your tune to work with Level 3 to omit the wiretap temporarily. Finding a starting point. I mention it a bit back with the Valet Mode level 1 you can set level 1 and vary the Valet Mode power up and down till your heavy throttle launch is clean or just a light haze. To build the curve to 100% now you would use level 2. Now you can build the fuel curve from your starting point you found with Valet Mode level 1 to your 100%. Most of us use a +1% as seen above but I only did it to 4 PSI. Then jumped to +2. Once you are happy with your fuel to 100% now you can jump up to level 3 and now build from the 100% mark on up to 150% fuel if you wish. You don't have to use the full 150%. There is no absolute formula for calculating fueling tables. There is way too many variables like injector size, pop pressures, turbo size, timing setting etc. In a nutshell, the best suggestion to build off your smoke and keeping it down to mere haze. Towing suggestion. I typically build the CAN Bus only to hold towing if need be. Like towing my 8,000 pound RV I can set Level 3 and never reach 1,200°F towing on a 7% grade. What you want to do is build you fuel table based on EGT's not HP/TQ. This way you can tow without huge worries of EGT temperature issues. Again you are not required to use all 150% of the fuel table. When starting to add wiretap into your tunes you should always remember that your canbus fueling should make up the meat of your "off the line power" and wiretap should be used for "wrapping it out" Canbus fueling can offer more than enough duration to smoke out the world. If you feel you need more power than the canbus fueling can offer alone then it is time to consider an injector upgrade. NOTE: Your 0 PSI slider value will be the maximum fuel you get during warm up phase till you reach Warmup Mode Setting coolant temperature. How to get the most from your tune for a daily driver? I highly suggest you look into an app for your cell phone or mobile device to track your MPG closely. https://www.simplyauto.app/ This little app is very handy for keeping track of your MPG and fuel logs. This way you can make informed choices on your tunning for your truck. Wonderful app it tracks even your repairs and fuel logs for you reminding you of maintenance that needs to be done on your vehicle. View full Cummins article
  14. TUNE PARAMETERS Side note, if you would rather have a pre built tune to start with you can checkout our tune repository. https://mopar1973man.com/forum/182-quadzilla-v2-custom-tune-repository/ Number of Power Levels Range of Values: 6 to 15 Default Value: 11 First off let me state there are fixed levels on the Quadzilla Adrenaline that you cannot change. This is levels 0 to 3 which are listed below. Stock - Quadzilla Adrenline is disabled and Stock ECM tune is used. Valet Mode - Explained below. CAN Bus limited to 100% - Quadzilla CAN Bus fuel is used until it reaches your 100% mark, then stops and holds 100% up from there. CAN Bus fuel - Full CAN Bus fuel table is used. Level 0 - Allow you to shut down the Quadzilla Adrenaline completely. The ECM is in full control with stock fueling. This level also is used during engine warm up and limits your fuel to your 0 PSI fuel setting. Level 2 - This is good for finding your spooling curve. Once you found your starting percentage using Valet Mode you can now build a fuel curve using Level 2 keeping the smoke under control. So for example, if you find that 80% is your 0 PSI position then do +1 percent for the first 5 PSI then step up doing +2 percent which will have you at 9 PSI at 99%. Then you can test this part of your tune by doing several heavy throttle launches and watching your smoke. Note that Any value over %100 is ignored. OEM duration is max duration on level 2. Level 3 - Now you can test your full CAN Bus fueling map as an entire tune. This level could be used for people with weak transmissions or clutches to extend its lifespan just a touch longer. Level 3 might also be helpful for winter driving conditions keeping traction better. From level 4 on up to 15 are wiretap levels which are divided up in a percentage of cut of power. Like I prefer using 7 levels. This gives you 4 wiretap levels which becomes... 25% wiretap power 50% wiretap power 75% wiretap power 100% wiretap power So you can divide up 12 times of the wiretap if you wish. RPM Limit Range of Values: 3200 to 3700 Default Value: 3200 This is the governor setting of the Quadzilla Adrenaline. This is the maximum RPM that Quadzilla Adrenaline will fuel too. Without supporting modification I don't suggest higher than normal RPM limits. Stock RPM limit is 3200. VALET MODE PARAMETERS Maximum Valet Mode Power Range of Values: 0 to 100 Default Value: 50% Quadzilla Adrenaline Valet mode has a few different purposes which is level 1. It can be used for what the title states which is a cut of power for valet mode to use your vehicle but not allow them to use the full power. Valet mode can be used to find your starting fuel amount without smoke. Then the last thing is using it as a security feature where the truck will start and run but only travel at super slow speeds. As for finding your starting fueling you would select level 1 and then set your valet mode amount. Depending on how big your injectors you may be higher or lower than me. I'm using DAP (7 x 0.0085) injectors which has a clean start out at 80%. So you would set your percentage and do several heavy throttle launches watching you smoke amount. Start low and bump up slowly till you see haze then back off slightly. This will be your 0 percent value you will use in your CAN Bus fueling table. As for security you can set the Valet Mode as low as about 20% and it will start and run but at full throttle, a thief will struggle to build speed beyond 20 to 30 MPH. If you set this too low it can cause it to stall out when you give it throttle. As for Valet Mode you want to set enough for a person to drive the vehicle normally in a parking lot or at speed you wish. You'll have to experiment with values to you find what you like. PUMP TAP PARAMETERS Maximum Fuel Stretch Range of Values: 1200 to 2200 Default Value: 1800 This value is pulse time in microseconds that Quadzilla Adrenaline will give to the wiretap to the fuel solenoid. When the CANBus fuel end this is the amount of time (microseconds) in fuel signal added to the fuel solenoid holding it open. My suggestion is to start out at the 1200 setting and work your way up till you get your fuel to boost figured out. There is very little reason to even get close to 2200 setting which in most cases will result in excessive black smoke which does mean you are overfueling. TPS Pump Maximum Range of Values: 0 to 100 Default Value: 100 This is the TPS value that Quadzilla Adrenaline wiretap will peak out at. The wiretap will continue at the power level you at that TPS value. Typically this is just left at 100%. TPS Pump Minimum Range of Values: 0 to 100 Default Value: 20 This is the TPS value that Quadzilla Adrenaline wiretap will start at. You can specify TPS percentage that will trigger wiretap. If this is set for zero and then the Pump Low Boost Scale PSI is used. If both values are set for non-zero then both conditions must be met before wiretap occurs. Typically I would leave this set for zero. I've tried 30% setting a few times but it makes the wiretap start point rather random being that you have to make both boost pressure and TPS conditions true to make it start. Best to use boost pressure as a trigger and leave this set for zero. Minimum Pump Tap Fueling Percentage Range of Values: 0 to 50 Default Value: 0 This is the minimum amount of Quadzilla Adrenaline wiretap to start out with. Most for daily driving will leave the wiretap set for zero. Pump Low Boost Scale PSI Range of Values: 0 to 25 Default Value: 5 Quadzilla Adrenaline Pump Low Boost Scale PSI is the boost pressure that will start the wiretap. You should set this just high enough so the turbo is just getting spooled off the CAN Bus fuel and then you can kick in the wiretap without much smoke change. Boost Scaling Range of Values: 20 to 40 Default Value: 38 Quadzilla Adrenaline Boost Scaling is the point at which the wiretap will hit 100% wiretap. The lower in the boost number the quicker it reaches 100% wiretap. Basically, in a nutshell Pump Low Boost Scale PSI is the starting boost pressure to start the wiretap and Boost Scaling is the point that wiretap will reach 100%. TIMING PARAMETERS Max Load Timing Offset Range of Values: 0 to 3 Default Value: 3 Quadzilla Adrenaline Max Load Timing Offset is used for giving the amount of retard over a range of engine load. For example, if your set for 3 then you would have -3° retard at 0% engine load and at 100% engine load you would have 0° retard. Example if you have 14, 18, 22, 26 for timing with 2 Max Load Timing Offset. You can see the Timing max values in the 100% column. The way to check the impact of the Max Load Timing Offset is to get to a cruise speed near 1,500 RPM and then add some grade or add throttle to increase the load to fall out of the Light Throttle Load Limit and just as it does the timing should drop to its lowest point now. Using the table above for an example if the Light Throttle Load Limit is set for 30% that means it should fall to about 12.6°. This gives you an idea that you have to figure +2° to allow for the Max Load Timing Offset the room to retard the amount you've set. Checking this setting can be rather difficult for varying road conditions. What you want to look for in your data logs as the timing vs engine load. As engine load rises past the Light Throttle Load Limit (Percent) and drops into the performance range then the timing should drop this set amount look and see what the timing value is and if it's retarding too deeply at this point. Low PSI Timing Reduct Range of Values: 0 to 5 Default Value: 2 Low PSI Timing Reduct is the amount of timing Quadzilla Adrenaline will retard during heavy throttle conditions. This is to aid in quick spool up of the turbo. Value can be altered by the Timing Reduct Scaling below. Both the Low PSI Timing Reduct and Timing Reduct Scaling work during low boost acceleration like below 5 PSI of boost. Timing Reduct Scaling Range of Values: 0 to 100 Default Value: 100 Time Reduct Scaling is a percent value. For example, if you have 5° of Low PSI Timing Reduct and you have Timing Reduct Scaling set for 50% then you only going to get 2.5° of retard to the timing for 50%- 100% of the TPS. A rather Difficult setting to explain but the Timing Reduct scaling is basically the steepness that affects both the amount of timing and range of the TPS. If you to apply 60% TPS then you will still be left with 2.5* of timing retard. If you set this for 100% then you get 5° of retard increase in a linear fashion until you hit %100 TPS. These functions are a limit function of Timing reduct, to give a faster pull of timing with limited TPS input. Once 10 psi is reached there is no longer timing retard given by the Quadzilla Adrenaline. Light Throttle Timing Adv Range of Values: 0 to 8 Default Value: 2 Quadzilla Adrenaline adds this number of degrees of timing added on top of the RPM Timing Max. If you have 14, 17, 20, 23 set for timing then have Light Throttle Timing Adv set for 3 then the result would be 17, 20, 23, 26. This is only base numbers. When in light throttle condition Max load timing and timing reduct are not considered. Light Throttle Load Limit (Percent) Range of Values: 0 to 40 Default Value: 30 Quadzilla Adrenaline Light Throttle Load Limit is the engine load value that Light Throttle Timing Adv will end. Like my tunes I've been using 30% so from 0 to 30% engine load the Light Throttle Timing Adv is added to the timing value. Once the engine load rises above this set number then Light Throttle Timing is no longer added. You want to set this value to something that allows your normal flat ground cruise to stay within cruise timing. I suggest building this around 65 MPH speeds. Like my truck, I hold right about 25% engine load at 65 MPH on flat ground 30% gives me a bit of wiggle room for the roll of the land. Excessive high settings will hold the advanced timing too long and make it counterproductive if you hit a hill or grade the advanced timing will prevent boost to build easy. You want it to drop this and switch can to a more retarded state to build boost for power. This will now flip back Max Load Timing Offset. RPM TIMING MAX RPM Timing Max Default Values: 15°, 18°, 21°, 23°, 25° Mopar1973Man Suggested: 14°, 18°, 22°, 26° ***adding more timing up top will result in more power, but my goals are mpg. NOTE: The green bands are considered safe ranges for a stock unmodified engine. If you wish to experiment beyond the safe ranges we highly suggest installing the supporting modification like head studs etc before experimenting with high timing values. RPM Timing Max this is the maximum amount of performance timing you can reach per RPM band. Used normally this timing structure replaces the ECM completely. You can build a timing curve any way you which and any curvature you want. In my example, I'm running an offset between bands at +4. 13+4=17. So forth. Notice the max timing slider I've set for +3 only which is to match the cruise timing value this prevents cruise timing from being canceled on this limit. What to set your timing too? What we are finding out there is such a wide range of variance in peoples tunes. There is no exact formula for timing. The rule of thumb most tend to fallback too is that Light Throttle Timing at 2,000 RPM should be in the 19° to 20° range roughly. If you have a 3 set for Light Throttle Timing Adv and then you now see 17° plus 3° you come out at 20° Light Throttle Timing. Now if the Light Throttle Load Limit is set for 30% then when you exceed that It will drop back to 17° minus the Max Load Timing Offset. As you can see the low engine load end up with a bit extra retard to allow for building boost pressure to carry the load. MAX Slider controls the absolute MAX timing advancement you can have. For example, if your Light Throttle Timing Adv is large enough to push the timing above this setting the Light Throttle Timing Adv will be canceled and push back to RPM Timing Max. You will basically lose you cruise timing at this point and be forced back to performance timing. QUADZILLA SECRET: If you set all TIMING PARAMETERS to ZERO then on the RPM Timing Max slide up what you want to add to the stock ECM timing you can now run ECM timing plus a value compared to the fully replaced timing that Quadzilla normally does. Timing add limit is 5* in this mode. Bucking and backfire are typically signs of excessive advanced timing. Then if you are too far retarded you'll see more of bluish grey haze and cutting out. Timing Steepness Some idea on timing. Consider the span between bands as how steep the timing is. Like for example of 15°,18°, 21°, 24° this is +3 between bands. Now, look at +4 between bands 15°, 19°, 23°, 27°. As you can see timing is much steeper curve. Amount of step between bands is going to affect the steepness of the timing curve. Fixed Point Timing Another one that is common people want to call out a 2,000 RPM timing point. You can do this. Let's say you wanted to have 19° at 2,000 RPM now figure up and down from that point using the amount of step between bands. This is kind of common when you building tunes for daily driving because the 1,500 and 2,000 RPM bands are you common RPM span of a daily driver. Anchored Ended Timing What I mean here is you can start from a low end or high end as an anchored point then build from that point. For example, you have 13°, 17°, 21°, 25° (+4 step) you can anchor the high end and then suck the low end up given advancement. 14.5°, 18°, 21.5°, 25° so I built this backward starting from the fixpoint of 25 and minus 3.5 downward. This is handy if you know your max timing limit you can build downward. Bit Shift Timing This is a way of advancing or retarding the entire table in on adjustment. For example, you have 13°, 17°, 21°, 25° for current timing you could plus +1° to all bands and then end up with 14°, 18°, 22°, 26° for timing. Be aware changing timing like this affects the cruise timing as well. If you shift towards advancement then cruise timing will too, and the same said about retarding in this method. Timing Limits (What is too far?) It's rather difficult to specify an exact number of degrees as a limit for each truck. There are variables like injector pop pressure, injection pump accuracy, cetane of the fuel, coolant and air temperature that play a role in the amount of timing each truck will require. I can give clues on what to look for. Bucking or Backfiring is a sign of too far advanced in timing. Pay attention to the RPM realm that the bucking occurs and then try dropping that band 1° worth of timing or bit shift the RPM Timing Max table retard 1° degree and see if that helps. If you retard too deeply typically you notice the engine seems very quiet and tends to produce more white/bluish smoke. Builds boost rather well but launch power seems a bit slow to build though. Most applications the green bands on the RPM Timing Max table are very safe realms to work in. Retarding timing will allow for building boost pressure by pushing some of the expanding gases through the turbo. Advancing timing puts the majority of the energy to the piston as long as it's not too advanced which in turn can produce "negative torque" where the piston is being slowed down by the expanding gases but then breaks over the TDC and the gain power again. This is non-productive in negative torque state. It is important to remember that nearly all box tuners for 2nd gens max out timing at high boost and ~2500+ rpm. Max theoretical timing is 32° degrees of timing. Fuel Cetane Things to stay aware of setting timing. ECM and VP44 cannot detect cetane level. As cetane goes up the ignition quality of the fuel is better and faster so less timing is required typically for winter fuels with high cetane. Same can be said true about summer fuel added timing advancement will be required because of lower cetane typically in the summer. Keep in mind cetane is backward to octane. More information on cetane rating here. Cetane tends to carry more weight in tuning than IAT temperature so consider your "Winter Time Fuel" first before considering IAT temperatures. IAT Temperatures As the air gets colder it takes longer for the fuel to go from the atomized mist, to vapor to ignition (BANG!). Stock ECM can step up over 4° advancement as IAT falls below +80°F IAT. Since diesel engines and diesel fuel ignite based on heat in the cylinder things like coolant temperature, IAT temperature and cetane all have to be considered when building your timing tables. Stock head on the Cummins ISB has the IAT sensor within a few inches of the coolant jacket in the head. If you watch both fuel temperature and IAT you will find that both follow closely together in temperature as long as the stock fuel filter can and fuel heater still active. This is why if you monitor the cold start run of the ECM (level 0) you see extremely high timing like 21° at road speed. This was to aid in cold fuel and cold air running. BOOST LEVEL FUELING - CAN BUS Boost Level Fueling - CAN Bus NOTE: The green band is considered safe normal ranges. QUADZILLA SECRET: If you set 100% in all positions you would have ECM stock fuel table. All values are ECM fuel value times the percentage given. Like 0PSI value is 85% so if I command WOT the most I could get is 85%. ECM (100% fuel) x Quadzilla (85% Limit) = 85% This makes it possible to have below stock fuel rates for large injectors and control fuel to boost pressure and keeping smoke under control. This is your CAN Bus fueling table. I will suggest when your building your tune to work with Level 3 to omit the wiretap temporarily. Finding a starting point. I mention it a bit back with the Valet Mode level 1 you can set level 1 and vary the Valet Mode power up and down till your heavy throttle launch is clean or just a light haze. To build the curve to 100% now you would use level 2. Now you can build the fuel curve from your starting point you found with Valet Mode level 1 to your 100%. Most of us use a +1% as seen above but I only did it to 4 PSI. Then jumped to +2. Once you are happy with your fuel to 100% now you can jump up to level 3 and now build from the 100% mark on up to 150% fuel if you wish. You don't have to use the full 150%. There is no absolute formula for calculating fueling tables. There is way too many variables like injector size, pop pressures, turbo size, timing setting etc. In a nutshell, the best suggestion to build off your smoke and keeping it down to mere haze. Towing suggestion. I typically build the CAN Bus only to hold towing if need be. Like towing my 8,000 pound RV I can set Level 3 and never reach 1,200°F towing on a 7% grade. What you want to do is build you fuel table based on EGT's not HP/TQ. This way you can tow without huge worries of EGT temperature issues. Again you are not required to use all 150% of the fuel table. When starting to add wiretap into your tunes you should always remember that your canbus fueling should make up the meat of your "off the line power" and wiretap should be used for "wrapping it out" Canbus fueling can offer more than enough duration to smoke out the world. If you feel you need more power than the canbus fueling can offer alone then it is time to consider an injector upgrade. NOTE: Your 0 PSI slider value will be the maximum fuel you get during warm up phase till you reach Warmup Mode Setting coolant temperature. How to get the most from your tune for a daily driver? I highly suggest you look into an app for your cell phone or mobile device to track your MPG closely. https://www.simplyauto.app/ This little app is very handy for keeping track of your MPG and fuel logs. This way you can make informed choices on your tunning for your truck. Wonderful app it tracks even your repairs and fuel logs for you reminding you of maintenance that needs to be done on your vehicle.
  15. I wish I could but to leave a puppy locked up in a garage for 13 hours every other day isn't fair. Kind of hard to housebreak a puppy in the back seat of the truck. That was one of the things I enjoyed about Diesel he was a good travel dog. I've only had a few accidents with him but typically he would whine telling me time to get out. Yeah, I'd love to have a new puppy but my current lifestyle isn't fair to a new puppy.
  16. That's the problem those injectors are poorly remanufactured and typically have a shorter lifespan. It's only best to buy NEW injectors if possible.
  17. Like tonight I just BBQ'ed a nice 3-pound tri-tip. I was munching on my piece and cutting off the extra fat. It hit me again that what our pooch is for to enjoy the table scraps that we have on our plates. Man, it reminded me really quick he's gone as I'm tosing the few bit of fat in the trash. There was a trick I got "Diesel" to do was no matter what it was I could place a chunk of meat, fat, dog biscuit, etc. on the end of his nose and make him hold it there till I said go. He would flip it up in the air and catch it about 95% of the time. One day I got smart to him. I bit a marshmallow in half so the sticky is exposed then stuck it to his nose.
  18. Just wait if you buy a new truck. Injectors should be replaced somewhere around 100-150k miles at a cost of $3,500 or so. EGR issues plugging up the intake and grid heaters. DEF system failures where it leave you stuck and unable to drive the truck. Lower MPG's on the newer truck unless you delete it then if you live in a smog state that's not possible. Injector fails for some reason it possible to wipe out pistons and cylinders at the same time costing even more. So far there is nothing on the 3rd or 4th gens I'm happy enough to give up my 2nd Gen. Repairs are still way cheaper on the 2nd gen vs 3rd or 4th gens. Once warranty runs out you better be ready to trade it in. Lifespan on CR engine are much lower than the old 1st or 2nd gens.
  19. @jlbayes is a member here too.
  20. I've heard that in-tank fuel pump you should look for Delphi they seem to be the better brand of pump typically for gasoline or diesel.
  21. Might consider twins at that rate. Talk to @TFaoro or @trreed they would know.
  22. Gamble. It might run for a few weeks or a few months or a few years. There are 4 things that kill a VP44... 1. Low fuel pressure. Should be 14 to 20 PSI at all times. 2. Poor filtration. Cheap filters. 3. AC noise from a failed alternator. Should be less than 50mV AC. 4. Poor Lubricity. Today fuel is 520 HFRR Bosch required 460 HFRR or less. Hence the 2 cycle oil theory. So if there are any of these issues your chance of any lifespan is greatly shortened.
  23. Fuse number 2 in the PDC. Pins 48 and 50 should be constant hot. Fuse number 9 in the Cab is ignition hot for both ECM and PCM.
  24. Hook up a live data tool and watch the rail pressure. If the rail pressure start to slide downward as the engine warms up then you have a rail leak. Most likely the crossover tube is not seated properly in an injector or the crossover tube is loose slightly. I've seen this before. The one I dealt with the rail pressure was good cold as it warmed up it continued to slide down till it would no longer run (below 4k PSI). Let it sit and cool down the pressure returned. We started checking crossover tubes... Bingo! The truck has been running since.
  25. You might want to talk to @cajflynn he made it to 1.3 million miles with a 53 block towing heavy every day.
