Fuel transfer pump quit
ECM fuel pump control circuit failed. You'll have to have the ECM sent in and rebuilt.
Wire tap % question
That is the starting percent. Most of us start a zero. Unless you have stock injectors you might start higher.
IBMobile at Mopar1973Man place
@Ben you have get togethers too. Just hook up with members around you plan it out. Quite enjoyable meeting other people on the website.
AC clutch
If the clutch is spinning its engaged. If it's turning slowly the clutch is fried.
ATS Co-pilot or Firepunk Anteater?
Should talk to @IBMobile his set up is way better than ATS.
WTF HELP
We have those in our store.
WTF HELP
Yeah and no. TPS is just a 3 pin sensor. APPS is a 6 pin sensor with idle validation switch. Things are handled a bit different from just a TPS.
WTF HELP
Just above the VP44.
WTF HELP
I would still use an OBDII reader and see if the code is still there on the ECM side. Typically if the APPS is going bad or out of range there would be P0121, P0122 or P0123 code. You can monitor the TPS signal with a live data tool and see if the signal it smooth or dropping out suddenly. Might test for AC noise issues from the alternator. Excessive AC noise does weird things.
WTF HELP
Use a different code reader you can't have P1693 code without a second error code. If your using the key trick typically the 2001 only reports the PCM only. Hence why you are seeing only a P1693 code. This could be charging system issues, battery terminals/cable issues or starter with bad contacts or armature brushes. If its fuel related it could be air bubble or loss of prime. Dead pedal can be only two reasons typically bad APPS sensor (typically always a error code with it) or a failing VP44 (which may or may not have an error code). I would have to refer back to the error codes and what is present. Not really possible to skip a tooth on the gear. The only way that can happen is pull the front cover off and pull the gear out and turn in and replace the gear. It can't be lifted enough to spin the gear the lost time I checked. As for the pump did you line pu the key in the keyway and check the keyway with a mirror before you tighten the shaft nut? I've seen people crush the key in the gear and create a timing offset.
I've got to say thank you to @IBMobile and Jennifer for the wonderful dinner they brought us. They stopped in this evening and brought dinner, friendship, and great conversation. Again thank you both for the wonderful home-cooked meal. I would like to publicly announce that we have a new BoD member to the list. I know that one of our BoD is stepping down and @IBMobile will be replacing him. He's a welcome asset to the Mopar1973Man family being he's a knowable person and talented mechanic.
Exhaust Brake Intermittant - Suspect APPS
Basically its not the alternator but more like the grid heater. High current load for an excessive amount of time overheat the diodes. If you want to upgrade to 180 to 250 amp alternator to overcome the problem but comes at very high price tag. Upwards of 500 for alternator. So in my case I'm using a Autozone alternator now but left my grid heaters unhooked since December no issues to report. @W-T has a great ground wire mod that some report reducing the AC ripple noise.
I would test the alternator for excessive AC noise. When the batteries are weak like that it puts more stress on the alternator and diodes are known to get damaged from overheating. Now that the electrical load is reduced because the batteries are fresh the alternator AC noise will be less but the problem still remains. I would test it just for safety sake.
Quadzilla V2 Custom Tunes
Here you go... https://www.rockauto.com/en/catalog/dodge,2000,ram+2500+pickup,5.9l+l6+diesel+turbocharged,1361999,fuel+&+air,manifold+pressure+(map)+sensor,11207 https://www.napaonline.com/en/p/CRB227091
@Raffron What year of truck? It's not in your signature...
Not shifting from 1ST WOT
The best man to talk to here is @Dynamic about the transmission.
Limp mode with codes
Head over to the Quadzilla forum and hang around and ask question tunning information will come.
Tach jumping
I'm going to aim for doing this mod soon myself and see what happens too.
Last time I bought a Cummins MAP sensor it was about $135 for the sensor and the 2001 to 2002 wiring adapter.
Doors
Dodge is a bronze or brass sleeve.
Tach jumping
Test for excessive AC noise issues. Then if you do find an issue, you'll need to replace your alternator then also consider doing this mod too.
Doors
Don't worry about it. No pins or bushings to install. I've still got to order them. I'll just get my local body shop to do it.
Also adding distance from the tap point helps. Like my sensor is relocated on the fender with over 5 feet of tubing in between the sensor and the tap point.
Doors
I plan it already it just trying to do a job like this without a second person is impossible. I'm most likely take my truck to a body shop and have to pay the big money to get them replaced. Sucks but I don't have many options.
Steering wheel radio controls
I'm not sure about 3rd Gen what is in the dash for stereo controls. If the truck didn't have the controls in the first place it might be missing the wiring and computer module receiver for the controls. At least 2nd gen you would have to change out the dash harness and the high line central timer. Again I don't know what 3rd gen have for this control.
