Quadzilla V2 Custom Tunes
I am a freak don't you know...
Doors
Tough call... It might be a PITA but it might come down to that pulling each hinge one at a time and rebuilding.
manual boost controller
Might be too much spring strength and the boost can't overcome the spring. You are hooked up correctly in on the red side and out in the blue side to the wastegate. Basically, the pressure has to overcome the spring and check ball to apply pressure to the wastegate. The hole is there to bleed off pressure after the pressure drop below your setting. I've got mine nearly all the way lose and the boost just barely hitting 40 PSI.
Doors
I've done a few older trucks by supporting the door and doing them on the truck. The problem is the hinge has to be separated so you can change the bushings. So this is not a single man job being these trucks have electrical in thee doors. The ones I did back in the 70's at most had just a speaker wire just chop that bad boy off and pull the door pins lift the door off. Our trucks are whole different story.
Stock HX35W turbo, +50 HP injectors, Edge Comp (5x3), Straight piped 3" exhaust. So far with the Quadzilla I've hit 22 MPG but the weather is still very cold in the morning hours which hurts the MPG's. Optimally 70-90*F weather is best and hitting at least 100*F IAT right off.
Fuel shut off solenoid
Yeah that's an 8 year old post. Might help to start a new post.
Doors
All winter long I really didn't do much to the truck but now spring come everything ignored from cold wet weather now is biting me now. Can't cry when I'm passing 341k and rolling.
Doors
Shortly after this my driver side door lower hinge spit the bottom bushing out. Crap. Time to get a door bushing kit.
No Gauges No Pump No Start
Need to update you Quadzilla to the V2 series and solve the smoke issue.
Quadzilla adrenaline v2 custom tunes
...and smoking them out does? Sorry, I don't see your logic. If I'm already ahead of the foolish driver just stay there all your problems are literally behind you now. Trust me I'm on the road quite a bit these days and I can spot the idiot drivers quick and just use the wiretap I can overtake them and leave the problem drivers behind me. I driving 250 miles 3 days a week minimum (750 miles a week). I've not found a good reason to smoke anyone out other than it brings down more EPA laws on the diesel community. Now looking forward to 4th gens with all the junk that is for EPA equipment, not fun working on.
Man, I'm glad those days are behind me. Still roughly hitting 21-22 MPG... (735 to 770 miles to a tank) Full mark by ~100 miles. 3/4 mark by ~225 miles. 1/2 mark by ~350 miles. Typically filling back up by this point. Rare for me to run to the bottom of the tank. Too far between towns and most up here are getting upward of $3.409 and $3.509 per gallon for diesel.
Derale Aux Trans Cooler
Always love when guys talk manuls transmission they argue about how 6 speeds are needed because of the number of gears and application of torque. Then we get to automatics with mere 4 gears where the top two gears are the basically same ratio as the top two gear of the manuals. Then you have only two lower gear where the ratios are way different. Then you mix up torque converter stall RPM's and possibly oversized tires on top of 3.55 gear you get a soup pot full of issues. I see @Youngblood24v is at least stock tire size. I've got to ask how much time are you spending unlocked on the torque converter? Not an accurate temperature. There is no flowing ATF fluid there. Most likely not typically that temperature is lower. The hot line leaving the transmission to the cooler is typically the hottest. Kind of like measuring coolant temperature at the driver side radiator tank which will be close to the 190-195* but now open the radiator cap and measure the coolant on the passenger side it like 110-130*F at the most. Same thing is true for the transmission the pan will be the coolest spot after the cooler. Currently, my 46RE (Dynamic Transmission) in my 1996 Dodge Ram 1500 has a clamp on Trans Temp probe on the hot line leaving the transmission. Yeah, I need to buy a bung and install the probe in the pan. So far my hottest temp I've ever seen is 190*F in downtown Boise traffic stop and go on about 110*F summer. Again measured at the hot line leaving the transmission.
Remaned ECM took out vp44?
All I can say is contact the ECM rebuilder and let them know the VP44 has been damaged by there rebuilt ECM. You'll need to get a replacement VP44 and ECM re-tested.
Well the Order is in
Holy Cow dude this is taking forever to build one truck.
What needs to happen is do the BlueChiop hot wire test. This will power up the VP44 as a stand-alone module. The truck should start and idle without a ECM.
Simple you can replace the sender on the fuel pickup in the tank to get accuracy back. As for the loss of fuel pressure someone cut the straw too short. There should only be the thickness of a quarter (coin) between the tip of the straw and the bottom of an empty tank. I've seen so many people screw up cut them diagonal or nearly an inch from the bottom. As you can see I've lightly notch my straw and it only the thickness of a quarter between the tip of the draw straw and the bottom.
Currently, there is a issue with the math on getting speed from the tire size and gears. I wished iQuad had an option to just pass the stock signal along. Like my truck, the odometer and the speedometer are right on the mark and should show 55 MPH when I'm traveling 55 MPH but it shows 57-58 MPH.
I don't know why it can't be averaged out. Just need to divide total miles by the Trip gallons and you have AVG MPG for the tank. I've got to do it in my head right now and the quick way is for every gallon I expect 20 miles. So every 20 miles I check the gallons and see if its less than dividing then I know I'm ahead of the 20 MPG mark. The only thing this is missing is an odometer that's all.
painful things to watch people do in their trucks.
Sure won't be a buddy after bringing it back to him like that. Going up is one thing I wonder what it was like when he came back down that slope again. How much more damage did he take on? Here is another video full of goofy people.
Choosing the right turbo
Just add a bit more retard to the 1,500 RPM area and allow the engine to build boost for you.
disarming the alarm
The alarm is part of the central timer under the dash. So if you disconnect the central timer the alarm should stop. The only problem is the wipers will too. The wiper delay function is based in the central timer.
Beating the ABS/Brake light horse again
Me personally, I would have avoided the Powerstop kit. The ceramic brake pads will eat the rotors before eating the pads. When I look at the pad life on my own truck at 180k miles for my first set. My second set of brake pads are going to most likely exceed 200k miles on they are rock bottom economy pads. I'm still running OEM rotors which have been turned once took very little to straighten back to true again. Trust me after see what ceramic brakes do you are not going to be happy replacing rotors being you have to press stud out every time. Everyone says it my exhaust brake that does this. Not true. 171k miles on my 1996 Dodge 1500 with a V8 5.9L gas engine no exhaust brake there either. I finally did my first brake job on only the front axle last year. Again I used the bottom of the barrel economy pads so the rotors don't get chewed up.
Turbo to T3 exhaust manifold gasket
No sealant used. It's more or less a one-time crush gasket.
Is it vp44 time?
Why not upgrade to an AirDog or FASS fuel system. Then you deal with all the 6mm ID restrictive fuel system with 1/2 inch plumbing, Adding in 3-micron fuel filters basically double stacking filter with your stock 10-micron filter. Then you get the fuel pump relay as well.
Go buy a Ford truck and beat it up. Keep the Dodge at home...
