  1. You've got to build a math formula display the right boost pressure. You might ask either @Chris O. or @Me78569 they would both know.
  2. APPS reset on programs the ECM the span of voltage from idle to WOT. The Exhaust brake is typically based off the IVS (Idle Validation Switch). If the switch is triggered for idle then the exhaust brake should be active. Depends on the type of APPS. Timbo APPS is fully mechanical so there is no voltage value to flip-flop the IVS it all based on angle. Now the Stock APPS and Wells APPS both rely on voltage to flip-flop the IVS.
  3. Basically, you need to make sure your getting +12V on the Red lead. Then the Orange/Balck is getting your ground signal. Double check the #1 fuse to see if it cracked. I've seen that too many times. You can look at the fuse and it appears fine but to an ohm meter its cracked. Might swap relays for the transmission to see if it bad relay.
  4. Like myself, I broke out the 3,000 PSI power washer and power washed all those tough spots to make sure all the mud and salt are gone from the truck.
  5. That's the right app. I guess some needs to update the download area. @Me78569 or @Quadzilla Power...
  6. You might talk to @Me78569 and see if the download is up to date.
  7. According to my app the 1.9.41 is the current version.
  8. Plus compound turbos... Way different setup. Also, I'm not driving any roads that allow for 80 MPH anymore.
  9. You might still want to have the Quadzilla because high cetane fuel requires retarding in the winter time to gain MPG's back hence the design around the MPG fooler. Excessive timing with high cetane fuel makes for really low MPG in the dead of winter. I've been able to hit 20 MPG this last winter even with the 7 x 0.0085 injectors. Now I'm gearing up for the fuel price hike and going for the gold on my high mark which is 27.2 MPG hand math. I've already started the tune and will be reporting my MPG as I go.
  10. If I go down to my truck I can pull out my fuel logs I'm sure I've got plenty of 17-19 MPG right now.
  11. I'm fighting to keep the rust at bay. So far I'm holding my own.
  12. Now here is a Dragon fire VP44 injection pump. ($2,474.00) Why even mess with the NAPA pump... https://www.dieselpowerproducts.com/p-5170-industrial-injection-dragon-flow-extreme-vp44-injection-pump-985-02-59l-dodge-cummins.aspx
  13. You would be better off buying another truck.
  14. I don't have a Windows PC either... Strictly Linux and Android. No. Just key on. The Live Data yes needs the vehicle driven or running.
  15. OBDLink LX is the dongle I've got. http://www.obdlink.com/lxbt/ I've used both the OBDLink App and Dash Command (Palmer Performance). I prefer the Palmer Performance being it does auto connect properly where the OBDLink app doesn't you manual have to remember to reconnect each time.
  16. I'm bringing this topic back to the top. I've been warned by a few forum members and local fuel stations that the price of diesel is heading towards $4.00 a gallon for sure. I've changed over to hypermiling again. I'm going to build that Economy Tune from hell. I'm going to reach for that 28 MPG and beat my old 27.2 MPG high mark. I'm going to start reporting my tank to tank hand math as I fill the truck. I'm at 340k miles currently. I'm also going to do some injector building on my old stock injectors. I'm going for a set of 7 x 0.009 injectors increase the pop pressure to 315 bar most likely. Then send my current injectors back and have them re-popped to 315 bar. So my days of hypermiling are going to return again. Since I'm required to continue to make these trip to Ontario, OR for MoparMom's dialysis treatments I've got to make the Cummins efficient as possible to make it pass that surge of fuel prices. I'm starting as of last tank of fuel. Let see what I get for MPG's when I return down to Payette for fuel on Saturday. Another task I need to do is my valve lash since its most likely needing a bit of TLC. If I get lucky I might see if I can find a used set of 245/75 R16 tires and change up the gear ratio to optimize the MPG factor reducing the load on the engine. Currently, on flat ground, at 55 MPH my engine load is about 17-19%.
  17. Yes sir. I ran that way so I wouldn't void the VP44 warranty right off. Just ran level 3 tunes and never bother to configure the wiretap settings of my tunes. Now with the wiretap hooked up I'm only using between 1,200us to 1,400us of wiretap pulse. Beyond that it just becomes excessively smoky.
  18. Yes Sir. I lost my factory 16x8 aluminum wheels which cracked. Then the other set of modular aluminum wheels I had the offset kept slinging road salt and mud on the side windows. Got tired of that... The Factory 16x7 steel wheel fit the 235/85 R16 properly and tucked the wheel back under the fender where they belong. Remember I'm rolling 60k miles a year...
  19. I have been for over 25 years no issues. Matter of fact I'm gearing up for doing A/C work all summer. I've got my first customer today and getting ready to haul to Riggins, ID. There is a few things I ran into NAPA wise I will not purchase. So be smart price check things. https://www.napaonline.com/en/p/CRB22355 - Fuel shut off solenoid 12V for $432.00 (I can buy 4 of these from Gould Gear!) https://www.napaonline.com/en/p/CRB230223 - VP44 injection pump $1839.00 (I can buy a Dragon Fire for that much!)
  20. Yes. This is why I suggesting this it will wipe out the bad tune and start over fresh.
  21. I just stopped in yesterday and got a passenger side brake cable and ended up with a free NAPA tee shirt too.
  22. Something like this... https://www.homedepot.com/p/Westek-Heavy-Duty-Outdoor-Timer-Black-TM12DOLB/100645892
  23. That's where my OBDLink LX shines the best. I can leave the ignition key on engine off grab my cell phone lay it on the valve cover and monitor signals while I test for sensor issues. Corded OBDII tools suck because now you can't watch the display with you wiggle wires or test anything. I very very rarely ever use my corded tools any longer because of the cord limitation which isn't long enough to even make it outside the cab.
  24. Booting issues of the ECM will stop the truck from even starting. The very first instruction is to do the blub check for the WTS and fire the grid heaters if required for the IAT temperature.
