New to the page
Go to this link. https://mopar1973man.com/settings/signature/ The actual steps so you know. Go up to the top of the page where your username and avatar is and click. Then select "Account Settings" from that drop-down menu. On this next screen select "Signature" from the list. Now type your signature. Add all the information you know about your truck. Then hit the "Save" button. You are done...
Turbo options and opinions
Then I would say slow down a second. First get the Quadzilla first you find out you are really close just with that. Then toss in some injectors @Me78569 would suggest (7 x 0.010 Injectors). That will get you the fuel you need to reach it. Now as for the turbo at this point you could do either. But without the injectors and the tuner that truck will be laggy. Kind of like seeing guys that have twin turbos with RV275 injectors. Yes, I'm sorry to say I've seen this...
VP44
The last few times I've never bother to even crack any high-pressure lines open. Just cranked for about 20 seconds and it would start. I would bump the starter crack the fuel supply line till fuel was present at the VP44. Jump in the truck and just fire it up. Mine like I said, is about 20 seconds of solid cranking it fires right up.
47RE fluid temp?
There is no port in the transmission where the fluid flows enough to be in any of those ports. Either put in in the pan or the return line. Personally, I'm going for the pan. I'm going to put the sensor down low in the pan so it doubles for a drain plug.
Electrical ground issues
Now @IBMobile when you unwrapped that part of the loom which way does the ground cable go? How much unwrapping did you have to do? As for the last photo I hope you installed an alternator fuse. The reason there is an alternator fuse is that if some moron hooks up a set of jumper cable reverse polarity that alternator will be frying quickly if not on fire.
manual boost controller
Holy Crap. That is expensive! https://www.napaonline.com/en/search?text=EH227&referer=search_form-allprod I'd go to Transmission Cooler hose before I buy this stuff! Wow!
how do I identify my stock turbo?
HX35W will be divided exhaust housing where the HY35W is a single port. Take notice tot the exhaust housing the 9cm2 has a raised rib on the HY35W. The HX35W is a smooth faced exhaust housing which is typically 12cm2 . HX35W has a hose between the wastegate motor and the discharge. The HY35W has a hard steel tube.
Blue Top Steering Rebuild
I'm going to kick this off with a rebuild thread here. Ryan @Blue-Top Steering was nice enough to set me up with the seal kit for my steering box. The only tool I had to borrow was a pitman arm puller. First thing I did was tie the steering wheel to the seat base in the center position. This is to protect the clock spring more than anything. Next I pulled the pitman arm nut and lock washer. Slipped the pitman arm over and using a 1/2 drive ratchet pulled a good load of pressure on it and smack the pitman arm a bit with a hammer to free it. Pulled a bit more and off it came. Then moved up to the 13mm socket and wobble head ratchet and spun the pinch bolt out. Wiggle the coupler and steering shaft came right off. Next was reaching up with a 3/4" wrench and pulled the power steering hoses. Make sure to have a catch bucket it will drain the system. Mine had a bit of a foul smell might be time for another flush which most of the system will be emptied. That left me the 3 bolts holding the steering gearbox on the frame. So in a timely manner, Blue Top's seal kit shows up today. The only thing I had changed up is the input shaft seal could one of two different designs. I had Ryan supply both seals. To be continued on my next day at home.
Quad installed!
Because the fact is the same air comes in a 3" intake horn with no issues why do you need 4 or 5 inch exhaust? Even with expanding gases it will still fit in a 3" pipe. Now the science is yeah there is going to be some pressure there but will flow through muffler or straight pipe there is no restriction to hang it up. This why for racing they would look into the 4 and 5 inch exhaust for more flow because they are running WOT. Daily driver different story where you run WOT 1-2% of the time. More or less yeah. In the past most tuners didn't give control of how much fuel and timing so most canned tunes where about the power and the smoke. Now with the Quadzilla you can produce a clean burning tune and control the fuel and timing to fit the engine without the need of huge exhaust and dual air ram intakes. Still making good power without killing the EGT gauge.
Quad installed!
Nope. Won't change much. If I take my backdown setting for EGT's and turn them off I can tip 1,500*F EASY! Trust me 4" is not going to drop your EGT's just because you bolt it on. What will change EGT's is more timing advancement which will lower the EGT's, more fire in the cylinder and less blowing out the turbo. (This might need to be looked at on your tune) My problem is I've got no control of my boost pressure (Edge Products boost elbow - non-adustable) and I'm sure I'm hitting the choke point of the turbo and just creating massive heat. The other step is I've running my wiretap tune on top of a good stand-alone CANBus tune. I need to rebuild the CANBus tune to control fuel on the upper end. Already got 4" and can get wild on the EGT's... https://mopar1973man.com/garage/modification/275-4-inch-diamond-eye-aluminized-exhaust/
Quad installed!
Won't change the EGT's much if any at all. I've been running 3" for a very long time. No issues. Then jump to 4" after mine rotten off the only thing that changed for me was the DRONE. Even with a muffler there is more DRONE than change in EGT's.
Relationship between fuel pressure and boost
Totally guarded by the skid plate. Now the first trip offroad to get firewood and skid logs I would end up taking that AirDog right off the frame... Bad idea... No even protected from flying drbirs from the front tires.
Poor Fuel Mileage and Low Power
Like for example. Manual or Automatic transmission HO or SO engine Highline central timer with security feature This are just some of the things that can make trading PCM and ECM hard at times.
Electrical options. Anything different between the PCM options and ECM options.
Did my VP go too?
For highway like that I find a speed that I can travel most of the road that doesn't require huge drops braking in speed and then acceleration again. Basically what your doing is converting you forward energy into heat on the brakes and then accelerating again back to set speed again. I've got a 17 mile stretch of road from Tamarack Mill to Council, ID which is posted 55 MPH which I know I can run that speed but every corner I would be hammering down the brakes to make the corners. So I back down to 50 MPH most of the corners I can make and if I plan right and back off the throttle I can coast to the tighter corners and get around without wasting the energy on hitting the brakes.
How can I Lower My Egt's
... and the radiator / cooling system.
Did my VP go too?
That's about it. Quadzilla doesn't use IAT temperature for tuning value as far as I know. So the MPG fooler has no value on the Quadzilla. Quadzilla provides a 6 CYL mode which you can terminate sooner that 170*F which is nice for fuel savings. But the switch is the only one that can provide 3 CYL mode on command.
Automatic or manual? If you are manual like me then the PCM does control the APPS sensor line because there is no vacuum cruise motor like the automatics use. So my PCM is directly connected to the ECM sharing the APPS sensor wires. Where automatics still share it but only for sense of how much TPS signal for shift signal. If you unplugged the PCM and the signal is now stable it still lean back on the fact the PCM is screwing up the signal. Look at C1 pin 22 that is APPS sensor signal. Now look here at Pin 28... Yes, they are connected and share the signal.
Did my VP go too?
You would be... Trust me after running Quadzilla untapped for 1 year (waiting for the VP44 warranty to die) then hooking up the wire tap is night and day difference. Like my maximum boost pressure, just CANBus is 28-30 PSI. Wiretapped is now 45 PSI. WAY more fuel than any CANBus tuner can produce. Which I've got a boost controller coming from China and be here on Friday. https://www.ebay.ca/itm/361900309685 Then once I gain control of the wastegate better I'm going to rebuild my CANBus fuel table to keep from hitting the EGT limits. Like @Me78569 mention in another post you should be able to control your fuel table enough to prevent needing backdown limits. Once I do that I should be able to hold it to the floor and not have to worry about EGT.
Did my VP go too?
Yes. Actually, this when you break out with a winter front and keep the cold air off the intercooler so to allow some of the turbo heat to make it to the intake. You don't want ro lower the IAT but to raise it. Again optimal is 100-140*F for MPG purpose. As for the timing aspect use the MPG fooler. That will retard timing. If you had a Quadzilla you can just program your timing.
Did my VP go too?
If the IAT temperature is below 80*F the ECM can kick in up to 3-4* of advancement of timing which typically is too much. Once you reach about 90 to 140*F the optimal MPG starts to shine. Remember the diesel needs the cylinder warmth to cause the fuel atomized spray to vaporize and go bang in a timely. If the air is too cold then the ignition occurs later (retarded). So this where Dodge's lab tech came up with this idea. Problem though is that the only thing the ECM can't measure is CETANE so if your local fuel is still high cetane and the timing is racked up then your over advancing. This why my winter tune I was RETARDING about 1.5* below stock. Still able to reach 20 MPG in near zero weather.
bucking in drive and OD
I'm still running factory styled alternators just unhooked the grid heaters and the problem remains gone for the time. So this points to the fact that grid heaters cause the alternator diodes to fail which in turn is the AC noise.
New to the page
Welcome to the site! You might want to put your truck information in the signature where you put "test" at.
I would keep your pair of ECM and PCM. If the other donor truck is a matching truck with same options then I would take the ECM and PCM for spares.
Possible. All I can say is try again. Double check the alternator and be sure.
