  1. The only problem I see with the valve cover breathers is the vapor coming back in the cab. Rotella and even some of the CK-4 oils now have a fairly strong oil odor when fresh. This why I made the mod to route the vapor behind the cab and not have to smell that oil vapor at every stop light. Adding excessive amounts of vents isn't going to change the performance other than mess later on. Years ago another member on CF created a vacuum vent system using the exhaust. Basically tapped in a one-way exhaust valve and the venturi effect pulled a light vacuum on the crankcase. The only problem there is the fact it would be possible pull oil into the exhaust pipe. Just better to aim it at the ground and let it vent. Keep your tubing short and rigid. Avoid using rubber hose it does get soft and kink very easy.
  2. Not a good sign though. If you have to do relearns of the APPS sensor all the time to gain a stable system that is a sign of AC noise issue on the ECM.
  3. Sensor is nothing but a coil wrapped around a magnet. As the tone wheel teeth pass by it creates a small AC voltage with a variable frequency which the ECM count the frequency of the sine wave and convert to as RPM gauge signal. Again here we are back to something possibly flooding the electrical system with more AC noise that is possibly fouling the tach signal. It still could be a simple wiring issue to the sensor. This is another reason I like to typically pull the field and the alternator fuse as well. The absolutely kills the entire alternator circuit and there is ZERO connection to the alternator.
  4. It must be some poor pissed of Ford owner turning over in his grave because your Cummins is still running.
  5. What's your fuel pressure? 12V Overflow valves are known issues.
  6. Do the diagnostics. This will help you.
  7. Sorry dann spell checker on my phone. Today is mobile day for me.
  8. Just make sure your vent cant kink shut. Nice way to blow the rapper cover gasket.
  9. If you have to vent that much you might consider doing a rebuild. I'm still running my vent mod and not blowing any oil out.
  10. No. Not required. All the puller is used for to pop the shaft out of the gear after that it can be removed. Typically I slide the shaft in and check with a mirror to make sure the key is lined up with the gear before tightening any nuts. Typically I will do the 4 mounting nuts first to draw it in the rest of the way and double check one more time with a mirror for the key alignment before placing the lock washer and nut on the shaft.
  11. Goes back to the whole problem... 1998.5 to 1999 do not report any error codes. 2000 to 2001 typically only report PCM codes. 2002 is the only year that reports both PCM and ECM. So why bother with a key trick system if only 1 year works... Just easier if everyone uses a code reader.
  12. I would ohm test the wires back to the ECM pin to pin. Also since we are dealing with AC waveforms with the tach signal I would suggest having the alternator tested for excessive AC noise as well. During the time its bucking you could pull over and unplug the field lead on the alternator and see if the bucking stops if so the alternator is to blame.
  13. Right here is why I ALWAYS suggest using OBDII scanner instead of the key trick.
  14. I also don't think the output file is 2.7 ready either. @notlimah sent me a file and will not import to the Quadzilla 2.7.
  15. Splitting out this thread...
  16. Like mine went a whole 10 years before the OEM alternator failed. Now I can't keep an alternator unless I ditch the grid heaters.
  17. Part number for that bolt is 05003621AA on the tappet cover. (Part number 32 on the page) https://mopar1973man.com/external-media/pdf/1999Ramparts.pdf#view=FitB&page=229
  18. 15 years later still look the same. I've never really had to clean the terminals at all. When I changed batteries back at 10 year I cleaned them but since then I've not touched them.
  19. Just replace the terminals. Go buy some military-style terminals and the cut off the old terminals. Solder on new copper eyelet terminals on the cables and just bolt them to the military terminals. While have the old terminal cut off take notice if the cable has corrosion in the strands or not. If so the cable got to be either replaced or trimmed back to get rid of it.
  20. Bingo... Frequency range is only 50 to 60 Hz.
  21. Typically the AC scale is in the 10 to 40 mV AC range. Be aware the meter has to be able to handle varying frequency. In other words, a lot of cheaper meters are designed for household 60 Hz 120, 240, 480 and up voltages. To find a meter that can measure mV range AC and any frequency it's a hard trick. That might explain some of the wandering. Because the ripple pattern is not a smooth pattern is a very random and choppy pattern the meter has to be able to work with that.
  22. Don't feel bad mine was the reverse problem my went to full advance and barely limp me home at 30 MPH. No white smoke just lots of hammering and knocking. I did have a P0216 code only if you used a code reader. My failure I contribute to pure wear. 243k miles and like 11 year if I'm not mistaken. I'm not complaining one bit. I grew up in age where it was normal to pull an engine and refresh it at 100k miles. Now to have a VP44 that last 243k miles not a problem. As for protection... 14-20 PSI fuel pressure is optimal 128:1 ratio of 2 cycle oil optimal. (Bocsh requires <420 HFRR today fuel is ~520 HFRR) AC noise below 0.04 (40 mV AC) Double filtering is optimal 3-micron filters.
  23. typically yes. I bought like 3 gallon yard sprayer and thought to mix up in that. Pump it up. Then spray the truck down. Little spray bottles work but the cleaner will eat the pump on little spray bottles.
