Did my VP go too?
As for the sump idea... At any rate the seal or o-ring will fail eventually on that sump. Sure would suck later in life that sump seal is no longer manufactured. Then end up trying to patch a massive hole in the bottom of your fuel tank. I've already had two people down this road and fought to replace the fuel tank.
Engine loss of fuel after hard acceleration.
Go to a true Alternator Shop. The report back the full load AC ripple voltage.
What was the final AC ripple voltage?
Did my VP go too?
I cut my straw flat on the bottom with the thickness of a single quarter coin. I lightly notched the tip with an angle grinder. I did all my measurements on an EMPTY fuel tank this way as the fuel weight will bow the tank away from the straw tip. This way as the fuel tank empties it will pull the bottom up towards the tip of the straw.
Did my VP go too?
If you are using your truck offroad at all I would steer clear of any sumps. If you hook that sump its game over for the fuel tank. Finding replacement fuel tanks are rather tough these days.
Quad installed!
Might just consider upgrading to 4" exhaust that's all.
Did my VP go too?
I would suggest the draw straw. I'm still using my 12 year old AirDog old school draw straw without issues. Matter of fact I rolled into the fuel station with a 1/8 of tank.
FNG w/ a 02 24v W/ CODES
Would you mind contacting @pepsi71ocean and getting this information added to the database of ECM rebuilders? This would become very helpful to other Dodge Cummins owners that have failed ECM and needs it rebuilt. Nice to know there is several rebuilders out there that actually do good work!
Finding fuel leak under FASS pressure
I've got the same thing but no extra fittings really. Just the two male JIC fittings for the Carter. No it's not mounted on the block. It would hang in the AirDog location. Just swap power leads. But my AirDog 150 has been running non-stop for 12 years now. I've long given up on the secondary lift pump long ago.
Timing Reduct Scaling
Dang... I thought it would be some sort of data within the actual App itself. Oh Well...
Absolutely! That would be awesome if Quadzilla would add that.
Ok. Now it's coming together. It's hard to use a setting if you don't understand the information it's using and from where.
Ok you've lost me again. I'm trying to figure out what setting are being used against this Timing Reduct setting. I know the Max Load Timing Offset is only a 0 to 3* limit. So where are you getting 5* at? Are you talking about Low PSI Timing Reduct that is a 0 to 5* span. I'm trying to get the setting that this works against and understand how it works correctly. First lets list out the variables this actually works with. Then let work with how the math is figured out.
@Me78569 I'm going to check and see if I understand this option correctly. Basically, Timing Reduct Scaling basically affects the Max Load Timing Offset vs APPS Sensor. So if I set the Max Load Timing Offset to 3* and then the Timing Reduct Scaling to 50%. so by the time I hit 50% on the APPS sensor, the timing should be maxed out on the performance side.
Suggestion for Quadzilla
IIRC the Quadzilla was still functional and working correctly just the iQuad app had given up. Oh Yeah... Props to you @Quadzilla Power you finally got the menu icon fixed...
How strong is a stock clutch?
Way too many people think there is something special about the NV5600 vs NV4500 the gearing is nearly the same there is only an extra gear down around 25 MPH. Other than that the 6 speed is no different on the highway from the 5 speed. Look at the top two gears. I'm typically in 1.00:1 (Direct Gear) by 30 MPH. So as for the clutch issue if you have a 5 speed and upgrade to South Bend Clutch you'll end up getting a 13 inch flywheel. So stress levels between both transmissions are the same it just a matter of do you have the old 12.25 or the 13.00 inch flywheel and how much input power are you placing on the flywheel. As far I as I know the 6 Speed typically had the 13 inch flywheel. I would still order a full kit including the flywheel if I was to replace your existing clutch. If you opt for re-using your old flywheel have it surfaced again and checked for true flat.
At this point all current with the app and the flash there still is a tune loading issue. Like I had my phone in my truck and iQuad fired up started the truck backed up to my trailer. Shut down the engine hitched up. Then started again to move not more than 20 feet to shut down. I caught the tune loading midway and the app hacks like this forever never resets. If you restart the truck it hung like this till you shut down the truck and the app and refire up like normal then its fine again. Then I found another on my way back home from McCall today. Just got done do about 90 MPH 3 car pass and looked down and the iQuad crashed. Of course, I'm not going to fill out details for the app crash while unwinding from 90 MPH. So, I restart the app and nothing. Shut it down and restarted 3 times nothing. Then got smart and cycled the Bluetooth radio off and on again. iQuad fired right back up. So there is an issue with the iQuad and Bluetooth.
First off I would remove the alternator and have it bench tested for AC ripple as most shop would call it. Verify your power first. Now I would consider having the ECM flashed "may, just maybe" the software can be reset and resolve the issue. If there is any issues the DRBIII tool at a Dodge dealer should be able to spot issues. If the ECM needs to be rebuilt there is a list start here on the website by @pepsi71ocean for good ECM / PCM rebuilders.
Quad installed!
Way better than my old Edge Comp.
Has no bearing on the issue. IAT and MAP doesn't control fueling or throttle at all. Might only if the signal is bouncing but you never mention that. So I doubt it. Yes because I'm always aware of thing. Like during my month inspection I spend at least one hour on a creeper and inspecting the entire underside of the truck looking up at stuff the most won't even see from opening the hood. Then when I'm doing an oil change I'm testing my alternator with a DVM for excessive AC noise so I'm aware of the diode health. Knowing this is an issue being I've lost 5 alternators in 2 years I know I've not found the cause of the alternator failure yet. The only way to damage a PCM, ECM or VP44 modules is with an alternator with bad diodes. You can't see this kind of damage. You have to take the alternator apart. Here is another example. Just not our trucks... Just not Dodge even Ford and Chevy have these issues.
Don't do it. Just replace it with a Timbo APPS. There is nothing to clean. ECM issues. You can verify this with a live data tool and monitor the TPS signal. If the signal jumps then the APPS to blame if the signal is steady then the ECM is to blame. Still at that rate test the alternator for AC noise.
Tachometer works about 5 seconds at start up
Cam gears are different as in the tone rings. The early 24V had only a single tooth tone wheel on the outer edge. Where the later series 24V had a multi-tooth tone wheel inward on the hub of the cam gear. The cam gear and the gear case are different because the location of the cam sensor is in the wrong location. Versus... Two different animals.
Yes. I've done it plenty of times when alternator failed badly so instead of taking AC noise damage to the electronics I shut down the alternator by unplugging the field lead and continued home on just the batteries. Typically you'll find out all the weird issues go away because now you are on "TRUE DC" power once again. The computers all start work perfect. The cause I'm finding is the grid heaters that kill the alternator diodes. I'm not clear on why yet but research the solution to this whole AC noise issue.
Typical AC noise problem. Next time this happens pull the field plug on the back of the alternator if the problem goes away when the alternator is NOT charging then the alternator diodes have failed. What you post is a classic AC noise issue where the AC noise corrupts the tach signal the ECM varies the throttle up and down back the ECM is seeing the two waveforms. The dash cluster won't report it or show it on the tach but its happening.
Quadzilla Adrenaline Economy and MPG
Now that I've returned to the wiretapped crowd now I can see the difference between CANBus only o Wiretap. Of course, the power is way better tapped but I want to find out if I can reach higher like I've done in the past. All those years of the Edge Comp of running in the 20's MPG bracket were great. Hopefully, now I can do the same being I've got fresh injectors and 1 year broke in VP44 injection pump. Sad I doubt I'll get much MPG for the next couple of tanks. I'm like a kid with his first NOx bottle on a drag car. The "Go Baby Go" button is always being pressed.
