Getting a new to me truck sorted out
Error Codes (Deal with any codes present) Fuel pressure (14-20 PSI) Front suspension and steering (Inspect for damage or loose links) Injectors (If there is more than 100-150k miles) All fluids and filters changed. Engine oil Transmission fluid (and filter if applicable) Coolant flush Power Steering fluid Brake fluid Axle gear lube Transfer case (if applicable) Brakes (Inspection) AC Noise check
Blinker Wiring (In Cab)
Look at B6 and B8 there are the turn signals. Again here...
How can I Lower My Egt's
Another way to just check is to mark your driveshaft and the tires. Now rotate the driveshaft until you make one revolution of the tire. The number times the driveshaft spins is going to be your gear ratio. So if you are a bit over 3 and half turns then you've got 3.55 gears. If your barely over 4 turns then you have 4.10 gears.
I promise the gearing will change a ton load of the EGT's really quick.
I think my ECM took a crap
Might have to hook up for the winter time when deep cold sets in but only to start in the morning. After the truck is warmed it won't need grid heaters afterwards. I do want to resolve this issue and figure out exactly causing these issues and not just educated guessing...
Let's put it this way. Either change alternators every 4-9 months with the grid heaters hooked up and take the risk of excessive AC noise. Or... Like I unhooked my grid heaters and not looked back nor had any alternator problems. Another way I look at it. My 1996 Dodge Ram 1500 has never had an alternator replaced ever in 22 years. Wonder why? No grid heaters. Same alternator, Same make of truck less the Cummins diesel (grid heaters).
Yes. The Grid heaters can draw upwards of 195 Amps with both heaters active and the alternator only produces 140 Amps at 2,000 RPM but at idle it's much lower. So the PCM tells the alternator full speed ahead and ramps up the field lead to max voltage which now creates a huge load on the engine. Then when the grid heater turns off the PCM throttles back and the engine load decreases again.
This is a for sure solution. This isn't a for sure bet yet.
The only theory I've got is the heater elements are drawing more current as they age, putting this load on the alternator. The relay are just a switch if the contact were bad the current flow would be reduced just like starter contacts. But in this case the load is increased and alternator diodes are overheating and blowing out.
Everyone post a picture of your truck!
HX35/40 Hybrid (60/60/12).
How strong is a stock clutch?
Directly from Peter at South Bend Clutch. In Jan 2017 because it was Christmas I was coming back from seeing MoparMom in the care unit and in Weiser, ID the clutch slipped big time. Now its April 2018 and I've got over 59k miles on that clutch since I installed it Jan 2017. I've got 76k miles on the NV4500 since it was rebuilt. I've been traveling...
Yes sir.
Ahhh... That explains the roll over noise I got with my first Con OFE and the poly springs. My second clutch has normal springs and its silent.
Can you stop battery corrosion?
Never did like that spray terminal stuff. Every time I lean over the terminal rub my arm on it end up with red spray junk all over my clothes and my arm. Engine oil leaves just a minor oily film on the terminals and will not get back you or your clothes. The felt pads don't do anything either being only protecting what its touching. So just the bottom of the terminal and the top of the battery.
Just looking more friction material. https://www.southbendclutch.com/clutches/1947-OHD-10170/ https://www.southbendclutch.com/clutches/1947-OFE-10171/
Heat Shield for the BHAF
Looks like someone is due for filter change getting rather dirty looking...
Smoother I could understand being the OFE can be a bit grabby. The quieter I don't understand being mine is silent.
May I ask what the difference is? Where are you dyno'ing at these days?
I've the single version of that I listen to 6 hours of turbo whistle all the way down to Ontario, OR and back home.
Pyrometer typically is measuring the flame temperature inside. You could use a normal outdoor thermometer and measure the temperature around the BHAF. I know ISX did this long time again and typically without a heat shield, the temp was much more than +10*F over outside temp while rolling. Bein this is old information it might be worth testing again and seeing what you get for measurements as well.
In stock form without any injectors, tuners or fuel mods I was able to measure 1,400*F EGT's towing up a 7% grade. It was just a Chey 3/4 ton pickup on the trailer. Cruise set for 60 MPH. When I noticed the temp I backed out and dropped a gear and kicked the RPM's up and it settled at 1,200*F the rest of the way. Yeah the factory air box is plastic...
Just on the side of cautious nature, I would keep a fire extinguisher in the truck. Keep an eye on it as the weather warms up. If it starts to deform you'll most likely call it a fail. I'm still curious if it can be done with that kind of heat on that turrbine.
You've got my attention. I'd like to see this go through and be tested with summer heat. You'll be the first with a plastic heat shield.
Jigsaw... That's all I used.Then went to a friends house to use his brake to fold the 90* angle. Sheet metal trash can should be interesting...
57/65/14 with 7x.012s
Should be better on the choke point compared to my 12cm2 housing on my 60/60/12 HX35/40. Being my stock HX35W measured out at 54/60/12 The only thing I see is lag might be up there.
