DDRP
Adapter 06JIC X M12 with seal. Threads are 12mm X 1.5 TPI.
DDRP
Enuf said... I kept my stock filter housing and still use it. You'll need to get a big line kit between the stock filter and injection pump.
Hard start after grid heaters disconnect
Signs of low compression. I would do a compression test. Another is slow starter which can create the same problem. I pulled my grid heater in the middle of winter and been starting with average temperatures in 20's no issues.
Previous issues and a new noise.
MAP sensor has nothing to do with Idle. You can be missing the MAP sensor and it will still idle fine.
Injector swap
First time I did injector work I created a nasty random miss. No external leak and a random hard start. After talking to some of the guys found out I installed then wrong. So I re-did my install exactly the way I was told basically install and tighten the crossover and then tighten the injector hold down. Now I got a good seal on the crossover tube. Before the injector was clamped in the head BEFORE the crossover tube was tightened so the injector won't self-align to the crossover tube so there is a poor seal between the crossover tube and the injector and the leak is just blown in the return rail back to the tank.
Sound like you got a possible boost fooler issue then you need to head towards that Quadzilla soon. As for testing the MAP circuit in a nutshell. Unhook both end MAP sensor and the ECM. Now ohm test from end to end. A passing grade is <5 ohms. Leaving both unhooked now go from pin to GROUND. A passing grade is infinite ohms. Hook up the ECM lead turn the ignition ON engine off test the 5V pin. Make sure you got 5.00V present on that pin. Leave your current boost fooler out of the circuit and just hook up your MAP sensor. Clear all your error code go for drive. If no codes are thrown then that circuit is good you should be able to reach 19-20 PSI of boost without a boost fooler and possible rise slightly pass and feel the defuel kick in without codes. I typically still reach 23-25 PSI without codes but it dog out above 20 PSI for me and struggles to build more boost. This is normal.
Possible Causes Other DTCs Boost Pressure Sensor 5-volt Supply Circuit MAP Signal Circuit Short To Ground MAP Signal Circuit Short To Sensor Ground MAP Sensor Intermittent Wiring Problem ECM No listing of a turbo there. So you need to go over the P0237 code diagnostic carefully. Basically if the MAP sensor is throwing the P0237 its in LIMP MODE. The ECM can no longer detect boost pressure so the turbo will not spool.
OBDLINK
I just cap off the turbo lay some pressure to the air system. Then soap down the system looking for bubbles.
Injector swap
I normally tighten / snug my crossover tubes FIRST then tighten my injectors hold downs.
OBDLINK
@Me78569 could... Mine never was right.
Brake upgrade option & opinions
My bad... I did my post off my phone and didn't pay attention to the sig... My bad...
DDRP
Be aware some of the DDRP pumps have smaller plumbing ports than the full 100 GPH or 150 GPH pumps. You can increase the line size but the port will still be a restriction.
Door Lock Fob
As far as I know, the dealer is the only option. There might be some 3rd party stuff out there but I've not seen it yet.
Turbo options and opinions
Need to see want data is being fed to the ECM. Voltage won't mean much it the data that ECM process into fuel and timing.
100% on exhaust brake my average brake life is 200k miles. 90% of my stopping is done on a exhaust brake. High end pads will eat the rotors quicker. Ill post more tonight.
Easier yet hook up a live data tool look for change of value.
New to the forum
You have to change boards either direction. Up to 4K or down to 3K. There is a hardware difference.
Airdog low pressure
So, that bounces you back to pressure regulator on the AirDog/Raptor.
Airdog low pressure
Now think a second... That larger spin on water separator with all that screen area vs. a little piece of screen stuffed in the inlet of the Raptor pump.
Airdog low pressure
New to the forum
I gather with that monster of an engine you did the Quadzila 4k box correct? If so that is going to be night and day difference between Edge and Quadzilla. I know we don't have any tunes for the 4k series on hand but between @Me78569 and @Quadzilla Power I'm sure we can get you started on tuning that Quadzilla.
VP44
Absolutely... That is the best time to do it. It only took another 20 minutes to remove the other tidbit and slap that tappet cover on with a fresh gasket,
New to the forum
Came to the right place. Would you be willing to explain your signature a bit more? 6.7L VP44? Seems like a heavy modified engine.
Can you stop battery corrosion?
Back in the 70's when I was growing up I use to see a thick coating of bearing grease on the terminals. I would rather use the fluid film or PB blaster.
manual boost controller
Same here... I've got a steering box that I more or less turned into junk.
