16x7 Dodge Ram Steel Chrome Wheels
Just need the center caps.
This should be the only one. I was fighting a copy and paste glitch that I figured out later on. Sorry for the multiple copies...
Fan belts squeaks
Problem solved... I went and got a Dayco belt from Autozone with a 3 year warranty. Installed and the problem is gone. http://www.autozone.com/cooling-heating-and-climate-control/belt/dayco-serpentine-belt/150612_0_23387_5281
@MUDDY had a project for me at his place. I happen to spot a set of wheels that would get rid of my crappy aluminum wheels that one is way out of center or bent some how. Sad to say, my tires are beyond saving the damage is done to them. I did the dismount and remount myself and spun balanced them to true ZERO on all four tires. At highway speeds you can feel the vibration from the wheels. No, It's not driveline I just replace all u-joints on both front and rear driveshafts. Nice match to my 1996 Dodge Ram 1500 no all I need is a set of center caps. At least the tires are now tucked back under the fenders again.
Ijection lines so tight.....
I've got a 3/4" plumbing wrench that is awesome for thing like that but rarely does it fit where you need it to because of it a 6 sided wrench.
Axle Leak after Brake job
Either case you still had to install from the axle side. Getting the seal out is just easier if you remove the carrier.
100hp 7x.009 injectors EXHAUST POP?
If in doubt have a second shop test them out. Do not send them back to the shop that you bought them from. I typically take my injectors to local shop for testing to see what's going on then I can point fingers at someone for warranty work. Then also having a second shop prove there is an injector problem. The white smoke isn't normal.
Advice on Exhaust Manifold/System/Brake
Kind of like myself like in the first year of ownership of my truck at 15k miles I had the exhaust brake installed. Now I'm trying to base my build around the limits of turbos that I can use with my exhaust brake. You can still have quite a bit of power but the turbo and exhaust brake will always limit what you can do.
2001 idling high, rough idle
Bad news... No one should ever reset APPS voltage. 99% of the time it's done wrong. APPS voltage should ALWAYS be 0.05 to 0.1 below tag voltage. That's a sign of bad alternator with AC noise problems. If you got to relearn the APPS there is a problem. 6 years I did mine just because I replaced the batteries since then I've not done it again. The majority of the issues are caused by AC noise. Now knowing it's a Timbo's APPS. There technically no voltage adjustment. Basically, adjust the stop pin till the voltage rises the back off till you hit bottom and loosen an extra 1/2 turn off the set screw. Timbo's does not have a voltage setting. It's an angle setting. All this does is ensure the contact or on the IDLE position of the contact. Another thing to be aware of that if the IVS is on the throttling position then it will follow the APPS voltage. If the IVS is in the idle contact then the ECM ignores the APPS voltage and uses internal software to control idle speed. This is where people screw up attempting to adjust idle speeds or adjust to an old voltage of an old sensor. This is all wrong. Timbo's basically just need to be sure the arm return back enough to make contact on the idle contact or Idle Validation Switch (IVS). Just had a passing thought. If you just unplug the APPS sensor and start the truck this will force the IDLE mode of the ECM. If its still idling rough then its NOT an APPS sensor issue but fuel system issue or ECM issue.
Gallon Per Hour Filter size for Primary filter?
You also have to factor in the fact Raptor does not have a return line. So reaching 150 GPH is not going to happen. The most I've seen so far in fuel consumption rate is 25-30 GPH. Now the typical highway flow rates are 1-5 GPH roughly. Then you have to figure in the return flow rate but since the body of injection pump limits the flow of return.
You have to remove the carrier out of the differential to be able to replace the seals. Drive them out from the differential side then install from the axle side with a long driver tool. I had a shop do mine and watched the mechanic during the process.
Help Diagnosing Brakes DRAGGING
Fluid is dark and nasty again. As for the rubber no biggy. Rather normal to see that happen.
7x0.0085 +75HP SAC Injectors from DAP
Turbo has nothing to do with launching the truck from a stop. Just releasing the clutch from stop not touching the throttle will produce a pretty good lope as the truck starts to roll. 1st hear isn't bad at all just 2nd gear. Once you apply throttle it's gone. During that time the turbo is even being fuelled yet.
Headlight options
Let's say the main reflector is good quality and good spread of light. Now the secondary light reflector isn't that great. Very narrow beam path and more of a spot light pattern. Together both reflectors work well together creating a hot spot from the secondary and good spread of light from the main reflector. Like I said they are OK quality but nothing like HID like @Me78569 or @jlbayes are running.
Headlight options
Not the greatest but not the worst either. Let's say there OK nothing like @Me78569 HID lights.
Headlight options
Ground for the lights..
ECM information
Might look over here being that @Me78569 added an article about it too.
Verifying HX35/40 turbo size
300 bar vs. 310bar (stock) Already done in my tuning. I'm max boost is now like 37-40 PSI I cut my maximum fueling off by about 10% and made it long shallow curve for towards the max fueling. Again majority of my travels are mellow cruise control 2-5 PSI. Very Very rare do I run hard on it. I need reliability more that racing performance. Again... I've got to travel 4,000 some odd miles every month. Not about racing... Just about getting there on the cheap fuel wise.
I'm impressed with the minor change in how the turbo runs. Highway cruise boost pressure is down I'm like 2-5 PSI at 65 MPH and now with the +75HP injectors my EGT's have dropped a good 100*F so 65 MPH I'm floating 500-600*F. Max boost I was able to bang out this turbo so far was right around 47 PSI with my old Quadzilla tunning for the stock injectors but it was way hot and smoky.
Headlight options
Last night was my first test run of the 2 relay and 1 fuse system. Works really well and just as good as the 4 relay and 4 fuse setup most are selling for this setup. Fuse is tapped in at the PDC and right now the relays ate zip tied to the battery (BETA testing).
Fan belts squeaks
I guess one day soon I'll just have to buy a good Gates Belt and get on with it. Right now I just rubbed a bit of liquid dish soap on the belt to shut it up for the temporary time. Rather annoying...
Exhaust Brakes and head gaskets
Nearly 270k miles on my head gasket with the use of an exhaust brake. They will apply around 60 PSI of drive pressure on the exhaust brake. There is no fuel applied during the exhaust braking so the pressure are much lower than say high timing and big injectors with high boost.
Yes optimally studs would be good idea. That is why my current tune is limited on the max fuel to bring max boost back to 40 PSI. Then again I'm focused more on MPG than HP/TQ so majority of my run time is 2 to 10 PSI of boost. Hardly doubt head gasket will fail there. Nice to have the passing power back.
Yea, yea, yea, when my pockets become deep I'll buy another truck to build. Reality says I've got to keep MoparMom well and travel 4,000 a month, I'm currently not working and working with a limited budget. You say denial... LOL!
I love how people think I've got the bug. Being with the Quadzilla with my old 50s was easy to the control. So jumping up another 25 is not what I call going nuts. I've got to work with the idea of MPG, my exhaust brake, and stock head gasket.
