100hp 7x.009 injectors EXHAUST POP?
Uh no... You still have the PCM and it issues, central timer and its issues, ABS computer and its issues, etc.. So all you done is removed the VP44.
Oil leak in turbo
I just rebuilt my HX35/40 turbo. Not hard at all to do. DAP has a good price on the rebuild kits. Also whatever air filter you running you need toss that one away and get a BHAF.
VP pics
Let me know Ibe still got the VP44 pump to shoot any pictures you want.
Grid heater manual control...
As long as the ECM can see connection to the two solenoid it will not throw any codes. As for disconnecting the wires at the battery the is no power to the grid heater and the ECM can call for heat be nothing happens. Any switch that breaks the trigger leads will set codes but no CEL.
Help raptor 100 problems
Shouldn't be. I've got a factory replacement AirDog draw straw in my shop that is also straight cut as well.
No. It won't fry the ECM. It burns the fusible link near the battery.
Apps issues
The only connection between the ECM and PCM basically is the CCD Network. I hardly doubt it being the PCM is required for starting the network and the ECM is considered a secondary device that just shares data over the network. You might just a poor quality sensor...
This also trips the P0380 and P0382 codes. The only way to do it without tripping codes is to pull the main battery feed to the grids. Anything that breaks the connection of the smaller trigger leads will produce error codes. I know it doesn't light the CEL but it's nice to have to deal with error codes and resetting. By disconnecting the main power lead then the ECM will still do as it pleases will no ill effects of codes or loose wires that might short out.
True. There are a safety and legal issues with sumps. Bottom draw is illegal. For me, all I'd have to do is drive over a log or rock and that sump would vanish and so would the fuel in my tank. I do go offroad quite a bit. As for the draw straw I've got one of the old ones from way back in 2006 and no issues to report and can run well below 1/4 tank without a single problem. Most draw straw issue come from people cutting the tip wrong and way too short. Take notice its a straight cut, lightly notched (less than a 1/16"), the total gap to the tank is the thickness of one quarter coin with empty tank. Do not do this will a full tank the gap will be wrong. The tank will naturally deflect away from the draw straw as you fill the tank as it empty it will pull up tighter to the straw again because of less weight of fuel being present.
Apps issues
Welcome to the site. It would help if you filled out your signature so we knew what we are working with. As for the AC noise what voltage did you measure and where did you measure at? Surging and going WOT seems like an ECM issue. Any error codes present currently? Did you try going back to the old sensor? What brand of sensor did you buy? (Timbo's, Wells, OEM)
Where is the oil drain plug on this Cummins?
That will make it a dealer or shop only oil change most people will not have the device for drawing the oil out the dipstick.
Quadzilla V2 Custom Tunes
Being I'm a manual it lopes as the clutch starts to engage. I'm smaller on the injectors at 7x0.0085 (+75 HP). Then as I coast up to a stop with the transmission in neutral it lopes dropping the RPM's to like 700 RPM and bounce up to roughly 850 or so. Once I come to stop it idles right at 800 RPM's.
Can't. It will throw a P0380 and P0382 error codes if a toggle switch is added. I just remove the grid heater lead from the positive battery post. I should disconnect mine for the summer. Basically from April to October I leave the power lead disconnected for the grid heater. Any temperature above 32*F doesn't require grid heaters.
That's one of the Ram 1500 eco diesels.
ABS failure found!
Bring your truck to Idaho I'll fix it...
I've got a similar issue, not a heavy lope but there is a lope as soon as I start to launch out of 2nd gear.
Kind of like mine showing 2 PSI of boost with the key on and engine off.
16x7 Dodge Ram Steel Chrome Wheels
@MUDDY said he has the hub caps for these wheels I just now go to get them next time I hook up with him...
Np241hd fluid
That won't work with a manual. Being there is GL4 gear lube in the transmission and ATF in the transfer. Which this would be a bad deal for the transmission. Strange enough the G56 transmissions in the 3rd Gens run on ATF+4 as well. So who knows how mission critical it is to have the proper fluid...
Let's talk alternators
I'm not 100% certain but the socket isn't much. Then it attaches to the brushes of the alternator. I would figure its a plug more so.
99 2500 No Start No Code
Then the CCD network wire map...
ABS failure found!
Kind of tough to figure out ABS issues without being able to see codes. As you see my thread is based on fighting an ABS issues for over 2 years and spent lots of money on sensors and ABS module rebuild. I'm hoping is a basic issue like broken wire or a sensor that isn't fully plugged in.
2002 Dodge Transmission issues
I also vote for Quadzilla. Way better fuel to boost management. Then the ability to adjust your timing curve and cruise timing is something no other tuner can do for the 24 valve Dodge Cummins.
Looking for experience with fuel lines and PSI
Need to know what your WOT pressure is like. This is the most important number.
