RV Battery Charging From Trucks Alternator
Typically you should have a fuse or something limiting the charge or current flow to that circuit so to protect from over loading. I wouldn't use much more that 10-14 AWG wire for charging the RV batteries. Like even the Dodge trailer plug is only a 10 AWG cable and again limited to 40 Amps on the trailer plug. Even my RV with nearly dead batteries never draws hard on the system because of cable and fuse limits.
No. It will not draw more that the fuse will alway typically like for my RV its got a 40 Amp fuse for the trailer plug so its below 40 amps because it never blows the fuse.
Bought Me a First Gen
Nicely done... I likey!
Crazy MPGs
For me that where I gain my most MPG is in town rolling slow. I get seriously high numbers like 30-35 MPG. The only difference is most of the small towns don't have traffic lights. So if you plan your travels right you can travel town with little to no stopping.
Crazy MPGs
Not all... I've done my research here and some of the Mom and Pop places don't have filters or also using screens. Now most name brand places have standard and will keep to those standards typically. Even worse some are still using mechanical pumps with mechanical price boards. Those I don't even stop at...
High + Up & down RPM @ start up.
Seems fine to me...
Exaust 4 or 5 inch
There is no reason for a 5" unless you like it loud and lots of drone. For most of use that are daily drivers like myself there isn't much of a gain going even to 4" pipe. I'm still very capable of turning 20's in MPG with stock 3" and straight pipe setup with a flow through muffler (NAPA). Like myself I typically below 600*F EGT's for most driving and below 5 PSI of boost so there is no real back pressure issue.
Crazy MPGs
Catch me if you can... Warm IAT temps are back and low cetane fuels have returned...
automatic transmission late shift
Another way to test for that is just unplug the APPS sensor and start it up or hot wire the VP44 then the APPS is removed.
Destroyed Dana 70 rear end...
No kidding. I was looking for two control arms for the truck I'm working on and I can say is there isn't much for parts here in Idaho (Boise Area). Doesn't matter if its a gas or diesel most of the bone yards are getting rather empty of Dodge Ram's.
Chat room?!
I moved it out so the count number shows now. I had in hidden in the Social tab but the count never showed....
Pyrometers install
I've got a 4 terminal barrier strip. Basically 12V+, Key Power, Dash Lights, and Ground. So this ground goes to the dash frame. All my accessories are powered by this strip.
Front Crank Seal Help .... and show and tell of what the dealer did
Very, very impressed with the idea of the bolts. Like I told @bms231 I'm going to purchase a set of bolts for this reason and keep them in my toolbox for future jobs. I'm sure soon I'll be doing more gear case resealing. Then his idea of pressing the speedy sleeve on with the damper. Again another very smart idea. So I got to give Brian a big High Five for great ideas neat tricks and idea!
Hey now. Old rigs are cool. I use to be a big fan of the 1970 cars and truck till I sold them all and upgraded to 2nd Gen collection.
I've got a funny though its something wrong with the valve body. There is 2 sets of springs for 1-2 shift and then 2-3 shift I wonder if one set of springs is damaged and its up-shifting too early against a damaged spring and the down-shifting because the pressure fell sharply. Educated guess...
iding too high
But you can verify your current injectors for a either a very low price or free. Like my local shop with pop test for free as long as there is no adjustment of the injectors.
I told him he's suppose to catch the parts as they fly...
Here is a pic for today... A little vehicle line up. Excuse the haze skyline USFS is having fun with prescribed burns all over the place and the valley fills with smoke every evening. Ugh!
Free Azpen A729 Tablet Holder for Dodge Ram's
Hey don't knock my redneck carpentry skillz. If JAG was around I could get a killer bracket that was done in oak or something stylin'. At least the tablet isn't sliding around on the floor or the seat. I did a run down to Council, ID today and was OK with the location like I said the stick in 5th gear blocks the view really bad on the left side. 1st and 3rd aren't too bad. When I'm cruising town its viewable. Again I really don't want to be looking too much at it anyways. There is two things that tablet is doing... Providing me a good trip data logger. Providing the stereo MP3's through the AUX jack. I've been working with OBDLink staff to getting things added to the software like speedometer calibration and a few other things. I'll start another thread and show you...
You can help it a bit by customizing the throttle valve cable a bit. Get it to be close to what you want.
Pyrometers install
Here is a installer that screwed up the pyrometer probe install. As you'll see they drilled in the divider of the manifold.
Pyrometers install
I won't say that. Back when I barely installed my gauges completely stock powered no module or injectors yet. I was hired to tow a trailer loaded with a Chevy pickup to Boise for a friend. Just with cruise set at 65 MPH climbing 7% grade I was able to easily push 1,400*F without even thinking. At the time I was running DiPricol's gauges and they where less than 90 days old. So as for EGT's stock doesn't mean its safe.
My burnouts are typically done as I climb grades. Ask JAG1 one about that being he was in the passenger seat when it happened...
A little future project
POOF! Call 911 Dave is BBQ'ing...
iding too high
Be careful. Like BlueChip rebuilds pumps be unable to calibrate or flash a new PSG unit because BlueChip does not have a 815 test stand. If this company does have a 815 test stand can you please post up the information so I can add them to the list on the article database.
