Edge juice or iQuad
No thanks... @Yankneck696 and @Me78569 both talk a huge game of how Quadzilla Adrenaline is so superior over Edge Comp or Edge Juice.
Edge juice or iQuad
Each tuner has its up and downs. Smarty is best for low end launching, Edge is typically all round favorite. Quad is typically for those looking for big HP/TQ numbers tuner wise. I've got to agree with John...
automatic transmission late shift
Deeper pan is just going to buy a little more time before it all heats up. Once all the ATF is heat up it will take longer to cool down more fluid and more heat. Is there a gain? In my mind not really. I think you gain more on a better quality cooler than stock.
Pan isn't going to change the method of checking the fluid. Just it will hold more fluid in the pan. So you have to add more to get to the full mark.
Weight in the bed
I'm not quite the heavy but really close at 1,400 pounds on the rear axle. No air bag or changes in rear suspnsion and no problems towing either. Then using my modified air pressure 53 PSI in the front and 57 PSI in the rear.
Brake shudder at higher speeds
Typically this is from the extra leverage forces of oversized tire. The brake can't over come the extra leverage forces so people start down the slippery slope of modification on brakes trying to improve stopping power for a wheel/tire combo that is too big now. Again I just shake my head to this stuff. Back to the oversized tires and leveraging forces on the brake rotors and pads. Then poor driving habits and tailgating where most people make the mistake so driving fast and stabbing the brakes hard in a panic constantly. So they assume ceramics and slotted rotors are going to help because race car use them. Sorry to say light weight race car vs. 8,000 to 9,000 pound truck is a world of difference. Then adding leverage forces of the over size tires and poor driving habits makes for a brake nightmare...
Engine Vibration
All I can say is when a name like Bosch makes a test at least is not Doom and Gloom. It real. Even Bosch states that US 520 HFRR fuel is too low in lubricity. Need to be minimum of 450 HFRR or lower. I could understand the statement if it was just a independent shop or delaer stating this but when Bosch does this kind of test and publish the findings... I have to say it best to error on the side of safety.
Trans maintenance
This man knows his stuff when it comes to transmission work. I highly suggest you go over there and talk to Dynamic (Jon) anbout your servicing you transmission. Jon will guide you through and explain rather well on what you need to do.
Edge comp
This is most likely because of suction leaks. If the air bubbles are too plentiful the air bubbles can pass through the filter still and be fed to the engine. Air in the fuel will retard injection timing. Airdog's are known for this problem and testing solution is to use thick axle grease on all the suction fittings when hooking up the quick connects. If the MPG comes back you know you need to convert back to Parker Push-Loc fittings.
Automatic transmissions should be warmed up and checked on level ground while idling in neutral. Stock 47RE transmissions will only pump while in neutral. While like my modified 46RE will pump in park or neutral now. Like during my time reloading I was not wanting to overfill being the transmission is cold but also pouring fluid down the tube make the dip stick show weird readings too so you must have patience while filling a transmission and check after a period of time. Engine and transmission heat help in getting the dipstick tube cleared faster.
Edge juice or iQuad
Edge Juice isn't bad but most people lose power getting wrapped up in the alarms and limits. If you turn all the alarms and limits off you find that Edge Juice can stand its own ground fairly well. Quad does have a few other means of adjustments vs. Edge Juice and a bit more power. still in all when you break it down there is the standard 0-60 HP on the CANBus and then the remainder on the wire tap. Based on what the module sees for boost pressure during it run it will modify the wire tap signal.
30 WT oil
http://www.pqiamerica.com/apiserviceclass.htm http://www.api.org/~/media/Files/Oil-and-Natural-Gas/Engine%20Oil/MOTOR_OIL_GUIDE_2010_120210.pdf?la=en
Edge comp
Actually, a fully stock truck can reach over 1,400*F. That was my first shocker towing here in Idaho with my brand new DiPricol gauges back in 2004. No other mods.
Throaty, Spooly 2nd gen
- Brake shudder at higher speeds
If it was me, I would turn both back to true. Then put the new pads in the calipers.- Throaty, Spooly 2nd gen
Only if you have full length 3" or 4" exhaust system. If the exhaust pipe is shorten or dumps early or under the truck is still going to drone. Bigger the exhaust pipe the more chance of drone.- 30 WT oil
Personally myself i run 15w-40 even with minus winter weather. No issues. Even unplugged. Matter of fact my block heater cord failed years ago.- automatic transmission late shift
Like JAG1 found out as well even going from 265/75 R16 to 235/85 R16 there is another change with acceleration factor more so. But just getting to 31" tire helps a bunch. Like as my transmission is breaking in for the 1996 Dodge Ram 1500 it settling down down and needs to have a minor adjustment. I might add just a bit of slack to mine. I'm glad the family here could resolve your issue.- No Cruise Control?
Most likely got a hole in the body of the cruise control motor or the vacuum line rotted off.- Throaty, Spooly 2nd gen
I done a Diamond Eye 4" on a 1995 Dodge turned out awesome with muffler. The Diamond Eye muffler is a straight through like mine is and its still got a bit of noise but no drone and nice cruising with.- what grease to use where.
Myself it just Walmart red grease. Matter of fact I due to pick up a few more tubes this summer. Then a tub of grease for packing bearings. http://www.walmart.com/ip/Super-Tech-Multi-Duty-Grease-14-oz/16928004- what grease to use where.
I'm in it for the long run. Why not take care of your truck. You'd be really surprised to see how much is still OEM parts on my truck.- Brake shudder at higher speeds
Myself I use the cheapest pads I can get less metallics the better. I'm still running all OEM brake parts and did my first brake job at 185k. Exhaust brakes really do help a bunch.- Morning Pic For Today...........Post A Pic around your place.....
No whining here...- Throaty, Spooly 2nd gen
I'm running factory 3" with a straight flow muffler and mine is also very spooly sounding as well and can be heard again decelerating get a nice unspool sounds too.. - Brake shudder at higher speeds
