Wild and Free
  1. Where did you find he has a 64 turbo? I can vouch for the warm weather lope also, the hotter it gets the more it lopes, my 02 is good for it and thats with stock lines and tubes.
  2. OK there, now that I know you are guilty of picture fraud I can narrow down my search......... Some peoples Kids, :razz:
  3. Second time for this................. The fan doesn't mount on the water pump on a cummins like a gasser does. The water pump is belt driven and is just below and right of the alternator 'looking at it from the front' and is only held on with 2 bolts and an o-ring.
  4. I would like to stay with a 0-30 range gauge to get the accuracy a bit closer. I like the one Mike has but searched for a couple hours with no luck. I would like to know where he got it and if it electric or manual. http://forum.mopar1973man.com/picture.php?albumid=3&pictureid=231
  5. Mike where did you get that gauge from and is it a mechanical or electrical gauge?
  6. THE RESULTS: These results are listed in the order of performance in the HFRR test. The baseline fuel used in every test started at an HFRR score of 636. The score shown is the tested HFRR score of the baseline fuel/additive blend. Also included is the wear scar improvement provided by the additive as well as other claimed benefits of the additive. Each additive is also categorized as a Multi-purpose additive, Multi-purpose + anti-gel, Lubricity only, non-conventional, or as an additive capable of treating both gasoline and diesel fuel. As a convenience to the reader there is also information on price per treated tank of diesel fuel (using a 26 gallon tank), and dosage per 26 gallon tank provided as “ounces of additive per 26 gallon tank”. In Order Of Performance: 1) 2% REG SoyPower biodiesel HFRR 221, 415 micron improvement. 50:1 ratio of baseline fuel to 100% biodiesel 66.56 oz. of 100% biodiesel per 26 gallons of diesel fuel Price: market value 2)Opti-Lube XPD Multi-purpose + anti-gel cetane improver, demulsifier HFRR 317, 319 micron improvement. 256:1 ratio 13 oz/tank $4.35/tank 3)FPPF RV, Bus, SUV Diesel/Gas fuel treatment Gas and Diesel cetane improver, emulsifier HFRR 439, 197 micron improvement 640:1 ratio 5.2 oz/tank $2.60/tank 4)Opti-Lube Summer Blend Multi-purpose demulsifier HFRR 447, 189 micron improvement 3000:1 ratio 1.11 oz/tank $0.68/tank 5)Opti-Lube Winter Blend Muti-purpose + anti-gel cetane improver HFRR 461, 175 micron improvement 512:1 ratio 6.5 oz/tank $3.65/tank 6)Schaeffer Diesel Treat 2000 Multi-purpose + anti-gel cetane improver, emulsifier, bio-diesel compatible HFRR 470, 166 micron improvement 1000:1 ratio 3.32 oz/tank $1.87/tank 7)Super Tech Outboard 2-cycle TC-W3 engine oil Unconventional (Not ULSD compliant, may damage 2007 or newer systems) HFRR 474, 162 micron improvement 200:1 ratio 16.64 oz/tank $1.09/tank 8)Stanadyne Lubricity Formula Lubricity Only demulsifier, 5% bio-diesel compatible, alcohol free HFRR 479, 157 micron improvement 1000:1 ratio 3.32 oz/tank $1.00/tank 9)Amsoil Diesel Concentrate Multi-purpose demulsifier, bio-diesel compatible, alcohol free HFRR 488, 148 micron improvement 640:1 ratio 5.2 oz/tank $2.16/tank 10)Power Service Diesel Kleen + Cetane Boost Multi-purpose Cetane improver, bio-diesel compatible, alcohol free HFRR 575, 61 micron improvement 400:1 ratio 8.32 oz/tank $1.58/tank 11)Howe’s Meaner Power Kleaner Multi-purpose Alcohol free HFRR 586, 50 micron improvement 1000:1 ratio 3.32 oz/tank $1.36/tank 12)Stanadyne Performance Formula Multi-purpose + anti-gel cetane improver, demulsifier, 5% bio-diesel compatible, alcohol free HFRR 603, 33 micron improvement 480:1 ratio 6.9 oz/tank $4.35/tank 13)Used Motor Oil, Shell Rotella T 15w40, 5,000 miles used. Unconventional (Not ULSD compliant, may damage systems) HFRR 634, 2 micron improvement 200:1 ratio 16.64 oz/tank price: market value 14)Lucas Upper Cylinder Lubricant Gas or diesel HFRR 641, 5 microns worse than baseline (statistically insignificant change) 427:1 ratio 7.8 oz/tank $2.65/tank 15)B1000 Diesel Fuel Conditioner by Milligan Biotech Multi-purpose, canola oil based additive HFRR 644, 8 microns worse than baseline (statistically insignificant change) 1000:1 ratio 3.32 oz/tank $2.67/tank 16)FPPF Lubricity Plus Fuel Power Multi-purpose + anti-gel Emulsifier, alcohol free HFRR 675, 39 microns worse than baseline fuel 1000:1 ratio 3.32 oz/tank $1.12/tank 17)Marvel Mystery Oil Gas, oil and Diesel fuel additive (NOT ULSD compliant, may damage 2007 and newer systems) HFRR 678, 42 microns worse than baseline fuel. 320:1 ratio 10.4 oz/tank $3.22/tank 18)ValvTect Diesel Guard Heavy Duty/Marine Diesel Fuel Additive Multi-purpose Cetane improver, emulsifier, alcohol free HFRR 696, 60 microns worse than baseline fuel 1000:1 ratio 3.32 oz/tank $2.38/tank 19)Primrose Power Blend 2003 Multi-purpose Cetane boost, bio-diesel compatible, emulsifier HFRR 711, 75 microns worse than baseline 1066:1 ratio 3.12 oz/tank $1.39/tank CONCLUSIONS: Products 1 through 4 were able to improve the unadditized fuel to an HFRR score of 460 or better. This meets the most strict requirements requested by the Engine Manufacturers Association. Products 1 through 9 were able to improve the unadditized fuel to an HFRR score of 520 or better, meeting the U.S. diesel fuel requirements for maximum wear scar in a commercially available diesel fuel. Products 16 through 19 were found to cause the fuel/additive blend to perform worse than the baseline fuel. The cause for this is speculative. This is not unprecedented in HFRR testing and can be caused by alcohol or other components in the additives. Further investigation into the possibilities behind these poor results will investigated. Any additive testing within +/- 20 microns of the baseline fuel could be considered to have no significant change. The repeatability of this test allows for a +/- 20 micron variability to be considered insignificant. CREDITS: This study would not have been possible without the participation of all companies involved and dieselplace.com. A special Thank You to all of the dieselplace.com members who generously donated toward this study and waited longer than they should have for the results. You folks are the best. Arlen Spicer, organizer.
  7. Here is an intersting read. http://www.arb.ca.gov/fuels/gasoline/meeting/2003/022003bosch.pdf
  8. Yeah Thermo on my 05 read -21 on the raod last night. Never got above -10 for 2 days now but is supposed to hit single + temps with a south wind today.
  9. Three sisters ages 92, 94, and and 96 live in a house together. One night the 96 year old draws a bath. She puts her foot in and pauses...She yells to the other sisters, "Was I getting in or out of the bath?" The 94 year old yells back, "I don't know. I'll come up and see." She starts up the stairs and pauses "Was I going up the stairs or down?" The 92 year old is sitting at the kitchen table having tea and listening to her sisters. She shakes her head and says, "I sure hope I never get that forgetful, knock on wood." She then yells, "I'll come up and help both of you as soon as I see who's at the door." _____________________________________ An elderly Floridian called 911 on her cell phone and reported that her car has been broken into. She is hysterical as she explains her situation to the dispatcher: "They've stolen the stereo, the steering wheel, the brake pedal, and even the accelerator!" she cried. The dispatcher said, "Stay calm. An officer is on the way." A few minutes later, the officer radios in "Disregard..." He says, "She got in the back-seat by mistake..." _____________________________________ Three retirees, each with a hearing loss, were playing golf one fine March day. One remarked to the other, "Windy, isn't it?" "No," the second man replied, "it's Thursday..." And the third man chimed in, "So am I. Let's have a beer." _____________________________________ SUPERSEX A little old lady was running up and down the halls in a nursing home. As she walked, she would flip up the hem of her nightgown and say "Supersex..." She walked up to an elderly man in a wheelchair flipping her gown at him, she said, "Supersex." He sat silently for a moment or two and finally answered, "I'll take the soup." _____________________________________ ROMANCE An older couple was lying in bed one night. The husband was falling asleep but the wife was in a romantic mood and wanted to talk. She said: "You used to hold my hand when we were courting." Wearily he reached across, held her hand for a second and tried to get back to sleep. A few moments later she said: "Then you used to kiss me." Mildly irritated, he reached across, gave her a peck on the cheek and settled down to sleep. Thirty seconds later she said: "Then you used to bite my Neck." Angrily, he threw back the bed clothes and got out of bed. "Where are you going?" she asked. "To get my teeth," he replied _____________________________________ DOWN AT THE RETIREMENT CENTER 80-year old Bessie bursts into the rec room at the retirement home. She holds her clenched fist in the air and announces," Anyone who can guess what's in my hand can have sex with me tonight!!" An elderly gentleman in the rear shouts out his answer, "An elephant?" Bessie thinks a minute and says, "Close enough." _____________________________________ OLD FRIENDS Two elderly ladies had been friends for many decades. Over the years, they had shared all kinds of activities and adventures. Lately, their activities had been limited to meeting a few times a week to play cards. One day, they were playing cards when one looked at the other and said, "Now don't get mad at me.. I know we've been friends for a long time but I just can't think of your name. I've thought and thought, but I can't remember it. Please tell me what your name is." Her friend glared at her. For at least three minutes she just stared and glared at her. Finally she said, "How soon do you need to know?" _____________________________________ SENIOR DRIVING As a senior citizen was driving down the freeway, his car phone rang. Answering, he heard his wife's voice urgently warning him, "Herman, I just heard on the news that there's a car going the wrong way on Interstate 77. Please be careful!" "Hell," said Herman, "It's not just one car... It's hundreds of them!" _____________________________________ DRIVING Two elderly women were out driving in a large car - both could barely see over the dashboard. As they were cruising along, they came to an intersection. The stoplight was red, but they just went on through. The woman in the passenger seat thought to herself "I must be losing it. I could have sworn we just went through a red light." After a few more minutes, they came to another intersection and the light was red again. Again, they went right through. The woman in the passenger seat was almost sure that the light had been red but was really concerned that she was losing it. She was getting nervous. At the next intersection, sure enough, the light was red and they went on through. So, she turned to the other woman and said, "Mildred, did you know that we just ran through three red lights in a row? You could have killed us both!" Mildred turned to her and said, "Oh! Am I driving?" Please!!!! TELL ME THIS WON'T HAPPEN TO US!!!!
  10. This is a company with bulb kits for HID also. http://www.spencershids.com/
  11. Quite a few guys around here that take the fans off and never put them back on. But we have lots of open roads, the only issue most claim is lack of AC while town driving and higher auto tranny temps in town also. But most don't do enough town driving fo it to bother anything.
  12. I am to a point after many years with a BD low pressure indicator that I am in need of a true gauge on my 02. My question is this. I want a gauge that is electric and doesn't use isolators and needs bleeding ect. I want the best quality with least hassles. I read continuous threads on a lot of forums of the gauges with isolators causing more issues than the rest of the rig. Which gauge mfg is the cats meow? I don't care about the bling the face has just after reliable accuracy without hassles. On my 05 I am after an electronic gauge cluster like edge BD quad ect, looking for input on the best choice in that area also. I want to keep the 05 simple and uncluttered versus running several gauges.
  13. Doesn't hurt but is it necessary thats the long ongoing debate. as for vp44 there are a lot of different failures that can occur with them, mostly is early ones had wrong metal compatabilities inside and then the electronics are an issue and lastly is the lack of lube pressure from bad lift pumps none of which any amount of extra lube will help save it. Jeff 929 I LOVE your avatar...........I have never been able to stomach McD's food and I have an Iron gut..........
  14. Hortons are expensive and heavy, and a heads up... the fan doesn't mount to the water pump on a cummins.
  15. I have been having super luck with Schaeffers Soy shield fuel lube additive. My rigs all run smoother with it, most noticeable at idle notably cold start.
  16. Yep we need to know more about the rig, Still a stock turbo and injectors? If not what do you currently have. Bigger lines and crosstubes are not needed until going to 200+ sized injectors and a good IP to keep them happy. If you are going to stay under 650 hp range fuel only stock lines and cross tubes are all thats needed.
  17. I shopped for a couple of years before going with the Ranch Hands, they had the strongest design for the price, Definately the most bang for the buck .......and doe's:lmao2:
  18. Hope all have a SAFE and happy 2010.......
  19. Me.. 1995 ram 1500 4X4 360 Gone totalled by next owner1999 ram 2500 4x4 v10 Is now a work horse for the city of Bismarck ND2002 ram 2500 4X4 cummins My play toy2005 ram 2500 4X4 cummins My daily driver1969 Chrysler New Yorker 440 ...life ended as a derby car. Wife..1995 Dodge Neon bought new sold at 310k miles 3 years ago and its still running around. sister.. 1980 power wagon 250 4X4 360 ext cab Long gone1985 Ram charger 4X4 360 long gone, husband is a Chevy nut Dad...1989 ram 3500 4X4 cummins farm pickup and still going. Swapped auto and 3.07 gears for NV4500 and 4.10 gears.1990 Dodge caravan long gone I know I am missing a couple in the mix.
  20. Ranch Hand bumpers on both my rigs and wouldn't change a thing. The one on my 05 had more action than a slaughter house this past year and nothing but hair in the front receiver.:biggrin: http://forum.mopar1973man.com/picture.php?albumid=26&pictureid=184 http://forum.mopar1973man.com/picture.php?albumid=26&pictureid=195 http://forum.mopar1973man.com/picture.php?albumid=26&pictureid=199
  21. Had this guy by our place a few years ago.
  22. Last Coal Mine I worked at did a couple year experiment with bio blends in its heavy equiment fleets and found that the best fuel economy and performance overall came with the 5% bio blends. This places average daily usage was 35,000 gallons of fuel a day.
  23. Thisrock is the perfect weather indicator, it never fails. It is more accurate than your local weather person.Thisrock is the living word and is 100% correct.Thisis how it works: a dry rock means fair weather. a wet rock means it's raining. a dusty rock means a dust storm. a swaying rock means it's windy. a shadow under the rock means it's sunny. a white rock means it's snowing. if the rock is jumping up and down, an earthquake is upon us. if the bottom of the rock is under water it's a flood.
  24. Ah yes the Red Green show at possum lodge, I loved it when public tv had them on. They are always super funny. http://www.redgreen.com/
  25. December 8: 6:00 PM. It started to snow. The first snow of the season and the wife and I took our cocktails and sat for hours by the window watching the huge soft flakes drift down from heaven. It looked like a Grandma Moses Print. So romantic we felt like newlyweds again. I love snow! December 9: We woke to a beautiful blanket of crystal white snow covering every inch of the landscape. What a fantastic sight! Can there be a more lovely place in the Whole World? Moving here was the best idea I've ever had. Shoveled for the first time in years, felt like a boy again. I did both our driveway and the sidewalks. This afternoon the snowplow came along and covered up the sidewalks and closed in the driveway, so I got to shovel again. What a perfect life. December 12: The sun has melted all our lovely snow. Such a disappointment. My neighbor tells me not to worry, we'll definitely have a white Christmas. No snow on Christmas would be awful! Bob says we'll have so much snow by the end of winter, that I'll never want to see snow again. I don't think that's possible. Bob is such a nice man, I'm glad he's our neighbor. December 14: Snow, lovely snow! 8" last night. The temperature dropped to -20. The cold makes everything sparkle so. The wind took my breath away, but I warmed up by shoveling the driveway and sidewalks. This is the life! The snowplow came back this afternoon and buried everything again. I didn't realize I would have to do quite this much shoveling, but I'll certainly get back in shape this way. I wish I wouldn't huff and puff so. December 15: 20 inches forecast. Sold my van and bought a 4x4 Blazer. Bought snow tires for the wife's car and two extra shovels. Stocked the freezer. The wife wants a wood stove in case the electricity goes out. I think that's silly. We aren't in Alaska , after all. December 16: Ice storm this morning. Fell on my butt on the ice in the driveway putting down salt. Hurt like blazes. The wife laughed for an hour, which I think was very cruel. December 17: Still way below freezing. Roads are too icy to go anywhere. Electricity was off for five hours. I had to pile the blankets on to stay warm. Nothing to do but stare at the wife and try not to irritate her. Guess I should've bought a wood stove, but won't admit it to her. Gosh I hate it when she's right. I can't believe I'm freezing to death in my own living room. December 20: Electricity's back on, but had another 14" of the damn stuff last night. More shoveling. Took all day. Damn snowplow came by twice. Tried to find a neighbor kid to shovel, but they said they're too busy playing hockey. I think they're lying. Called the only hardware store around to see about buying a snow blower, and they're out. Might have another shipment in March. I think they're lying. Bob says I have to shovel or the city will have it done and bill me. I think he's lying. December 22: Bob was right about a white Christmas, because 13 more inches of the white crap fell today, and it's so cold it probably won't melt 'til August. Took me 45 minutes to get all dressed up to go out to shovel, and then I had to pee. By the time I got undressed, peed and dressed again, I was too tired to shovel! Tried to hire Bob, who has a plow on his truck, for the rest of the winter; but he says he's too busy. I think the jerk is lying. December 23: Only 2" of snow today, and it warmed up to "0". The wife wanted me to decorate the front of the house this morning. What, is she nuts!!! Why didn't she tell me to do that a month ago? She says she did, but I think she's lying. December 24: 6". Snow packed so hard by snowplow, I broke the shovel. Thought I was having a heart attack. If I ever catch the son-of-a-gun who drives that snowplow, I'll drag him through the snow by his b---s and beat him to death with my broken shovel. I know he hides around the corner and waits for me to finish shoveling and then he comes down the street at a 100 miles an hour and throws snow all over everywhere I've just been! Tonight the wife wanted me to sing Christmas carols with her and open our presents, but I was too busy watching for the damn snowplow. December 25: Merry F!=3D@x@!x!x1 Christmas. 20 more inches of the !=3D@x@!x!x1 slop tonight. Snowed in. The idea of shoveling makes my blood boil. Man, I hate the snow! Then the snowplow driver came by asking for a donation and I hit him over the head with my shovel. The wife says I have a bad attitude. I think she's a fricking idiot. If I have to watch "It's a Wonderful Life" one more time, I'm going to stuff her into the microwave. December 26: Still snowed in. Why the blazes did I ever move here? It was all HER idea. She's really getting on my nerves. December 27: Temperature dropped to -30, and the pipes froze. Plumber came after 14 hours of waiting for him; he only charged me $1,400 to replace all my pipes. December 28: Warmed up to above -50. Still snowed in. The Battleaxe is driving me crazy!!!!! December 29: 10 more inches. Bob says I have to shovel the roof or it could cave in. That's the silliest thing I ever heard. How dumb does he think I am? December 30: Roof caved in. I beat up the snow plow driver. He is now suing me for a million dollars; not for only the beating I gave him, but also for trying to shove the broken snow shovel where the sun don't shine . The wife went home to her mother. 9" predicted. December 31: I set fire to what's left of the house. No more shoveling. January 8: Feel so good. I just love those little white pills they keep giving me. Why am I tied to the bed?
