Me78569
Everything posted by Me78569
  1. looks like it didn't upload successfully. only ~20 lines in the export. Try to attach to the site again.
  2. I am building an article with before and after video. If you have any will you post them up so I can get them put in the article? I have tfaoro, and carb and myself right now.
  3. Ios can't use bluetooth, they require WIFI.
  4. Here are some videos of the pre and post Quadzilla with V2 Tuning. Looking to buy a Quadzilla here is the links back to Quadzilla Power. 1998.5 to 2000 Dodge Ram Quadzilla Adrenaline $699.99 2001 Dodge Ram Quadzilla Adrenaline $699.99 2002 Dodge Ram Quadzilla Adrenaline $699.99 Side note, if you would rather have a pre built tune to start with you can checkout our tune repository. https://mopar1973man.com/forum/182-quadzilla-v2-custom-tune-repository/ You can find the "How To Tune" article here If you find after watching the below videos that you want to upgrade to the Quadzilla Adrenaline, you can buy one in our store. Setup 7000' altitude 7 x .009 injectors HE351ve turbo Pre-1000 series Quadzilla tune Stock fueling Post Quadzilla V2 tuning Locking TC and lugging the truck at high throttle Tune changing on the fly Setup 7000' altitude 7 x .012 at 330 bar he351ve Stock Tuning Quadzilla on V2 tuning lvl 3 canbus WOT leaving light Quadzilla on V2 tuning lvl 3 canbus WOT Lug Down Towing Gooseneck horse trailer %50 throttle take off 7 x .012's Setup 7000' altitude 7 x .012 at 350 bar he351ve 0-60 WOT take off Setup 7000' altitude 7 x .013 injectors 62/65/12 over 75/96/1.32 Pre Stock tuning Post with V2 Tuning Stock and Quad with V2 Setup Sea level 7 x .014 injectors hx35 over ht60 WOT take off on lvl 0 vs lvl 3 Setup Sea Level 7 x .013 at 340 bar pop pressure hx35(62/64/14) over s475 (75/96/1.32) Setup Sea Level 7 x .009 injectors 60/68/14 non-gated Pre Edge various levels Post, Quad turned up various driving styles
  5. Here are some videos of the pre and post Quadzilla with V2 Tuning. Looking to buy a Quadzilla here is the links back to Quadzilla Power. 1998.5 to 2000 Dodge Ram Quadzilla Adrenaline $699.99 2001 Dodge Ram Quadzilla Adrenaline $699.99 2002 Dodge Ram Quadzilla Adrenaline $699.99 Side note, if you would rather have a pre built tune to start with you can checkout our tune repository. https://mopar1973man.com/forum/182-quadzilla-v2-custom-tune-repository/ You can find the "How To Tune" article here If you find after watching the below videos that you want to upgrade to the Quadzilla Adrenaline, you can buy one in our store. Setup 7000' altitude 7 x .009 injectors HE351ve turbo Pre-1000 series Quadzilla tune Stock fueling Post Quadzilla V2 tuning Locking TC and lugging the truck at high throttle Tune changing on the fly Setup 7000' altitude 7 x .012 at 330 bar he351ve Stock Tuning Quadzilla on V2 tuning lvl 3 canbus WOT leaving light Quadzilla on V2 tuning lvl 3 canbus WOT Lug Down Towing Gooseneck horse trailer %50 throttle take off 7 x .012's Setup 7000' altitude 7 x .012 at 350 bar he351ve 0-60 WOT take off Setup 7000' altitude 7 x .013 injectors 62/65/12 over 75/96/1.32 Pre Stock tuning Post with V2 Tuning Stock and Quad with V2 Setup Sea level 7 x .014 injectors hx35 over ht60 WOT take off on lvl 0 vs lvl 3 Setup Sea Level 7 x .013 at 340 bar pop pressure hx35(62/64/14) over s475 (75/96/1.32) Setup Sea Level 7 x .009 injectors 60/68/14 non-gated Pre Edge various levels Post, Quad turned up various driving styles View full Cummins article
  6. I use that one also. Really any ELM327 device will read codes on any vehicle newer than 1996
  7. really it comes down to the more tuning you do the better the truck will run, but you can get "most of the way there" by using someone else's tune. If it runs good enough at that point then fine.
  8. Read the article I created under "how to get better lights for your 2nd gen"
  9. Max timing setting is above 3k rpm it wont go over that. Max fuel load timing sets how much of that rpm timing is related to load %. So in order to reach that timing limit you set you would have to be at %100 canbus fueling. Each truck will be different at cruise state. My truck likes to sit at 20* at 65. Yours might like 17* or 19*. Issue is I am no tuning genius I just created the interface lol. All I know for tuning is what works on my truck.
  10. Exporting data always helps,that will tell us what the truck is doing rather than trying to guess. If you want more meat then bump your canbus fueling more. You won't hurt anything. Also on stock injectors if you want more bottom end reduce your pump low boost scale psi from 8 to 1 or 2 if you want it to drive like the edge on 5x5. Setting it at 8 means you get 0 wiretap until 8 psi. Good setting for bigger injectors but not so much stock fueling. Rest of the tune seems good. From my testing only timing really has changed mpg much. Fueling doesn't do much so long as wiretap isn't going crazy.
  11. I agree with Moparman. What's your tune?
  12. Try 5* just make sure your cruise psi limit is set correctly to disable if your load increases. I would save your tune again and then load the tune again to ensure it sticks, 17* seems low.
  13. I don't know if it is possible to have a choice in place to have the app dictate where the export gets saved. The perk of using the "intent" function of android allows the user to choose what to do with it. What you see pop up when you hit export is the intent function asking the user how they want to handle the action you requested. This is a fundamental android function that pretty much makes a system wide API. Personally I would not use a natively built in save function because I just use Google drive. It automatically syncs. So if the cost of having a natively built in export save function removes the intent function of the app / android then I think it is a step backwards and I would be very unhappy. I don't want to be limited to only saving the export file to a location on the device. This is why I suggest have a folder program installed on the drive so when you call the Android intent process it finds that program and does what you want. The way it is setup now is a future proof method or exporting data.
  14. Mike install a folder app on your phone. I can just hit export and select folder FX and it will save it to my home directory. The issue is that you don't have a native app on the device to save the file.
  15. Increasing timing within reason. Typically I would expect 18* at 55 19* at 65 and 20* at 75 for a stock injector truck.
  16. I would. I'd hate to do all of that work and have it run bad.
  17. if something isn't explained well let me know.
  18. no worries I try to document well.
  19. As with everything we want to save and document it is stored in the articles section. Even a tuning video. 1.Max Loda Timing Offset is how much timing of your base timing curve is related to load. If you set this to 1* then load will ditctate 1* of the total timing up to your canbus limit. 2. thats the lowest limit that wiretap will apply 3. Cruise timing is base 17* so if you set this to 1* then your Quad will try and hit 18* total timing at cruise at 2400 rpm. There is a 3* span of cruise timng between 1400 and 2400 rpm so if cruise timing is set to 1* then at 1400 rpm you would get 15* of timing at cruise. 16* at 1700 17* at 2000 and 18* at 2400 rpm. 4. Using TPS from 0-100% this set the minimum amount of wiretap to use. So if you have this set at %25 and go to %100 tps then you will get no less than 25% of the wiretap fuel stretch. if you go to %50 tps then you iwll get %50 of that %25. Pretty much allows you to set a min amount of Wiretap at WOT. Race tune type stuff. 5. Set how fast timing reduction gets pulled, but allows for a limit. If timing reduct is at 3* and reduct scaling is %75 then you will get a max of 2.25* of timing pulled at high throttle low boost, but it will increase down low faster than just setting your timing reduct to 2.25*
  20. but right now I just update my google drive folder lol.... good thing I am not updating stuff anymore....at least public stuff that's a pretty neat idea, but don't limit your tunes to a rampup fueling only. MY tow tune ramps up quickly off the bat then tapers off to slow growth by10psi. You can do decimals, no point really. I guess you couldn't but I doubt you would feel the difference. Really if you wanted to max fueling up top you would only need to reach %112 to hit 4095 at WOT higher revs.
  21. maybe that's Torque management kicking in when it shouldn't be? Thats something that cuts fueling that comes out of the ECM. However it shouldn't happen until after you get the truck moving. Does your tool show you mph? maybe the PCM is telling fueling to cut? Replace the VSS? The sensor on the rear diff? unplug the ABS and try again
  22. I almost wonder if you have a corrupt fueling table in the ecm. Is anyone local a smarty you can flash then flash back?
  23. edit just reread everything. Thinking. I really wish I could see the canbus data and see if the ecm is sending junk data for some reason.
