Me78569
Everything posted by Me78569
  1. Data log a high throttle take off with the quad. Does fueling get pulled down by ~%30?
  2. What changes between koeo and driving?
  3. When you do that with the edge screen does it do the full 0-100% sweep and 0% at idle?
  4. So you never see %100 TPS if the truck is running and it shows you %100 throttle truck off no TPS input? You should see a nice full sweep from 0-%100 tps input when you move the pedal, it shoudl also go to 0% when off the pedal, truck on or off
  5. ...That's an odd reading of TPS I hate to suggest throwing parts at it, but it sounds like your APPS is toast
  6. who did you get the VP44 from?
  7. I am shocked the Edge doesn't show throttle position. I am guessing that is your issue.
  8. Thanks for posting a thread, That will help get more eyes on it. Troubleshoot your 501 code. I would verify the ecm is seeing full pedal movement. Does your Edge show TPS %? When you move the pedal does the % update smoothly? Same question for boost, does your boost reading read correctly on the edge?
  9. Mike, If this is sometihng we are wanting to do we are going to have to eat the cost for awhile. No issue with that as we will get it back at some point, but trying to justify the cost upfront will never happen.
  10. I had this issue at one point. I had some poor guy on jumpe rcables for nearly an hour and it wouldn't start, finally got mad enough and held the pedal at 2400 and it cranked to life.
  11. Rev the charging truck and hold at least ~2k while trying to crank the other truck.
  12. Great to hear, Noted that tyler is bad luck haha.
  13. yep, it should pull pretty good to 3500.
  14. I loath apple stuff.
  15. you will like the hardfuel tune
  16. Could be. I wonder if the can is banging on the frame.....
  17. Couple be. It would be worth having them sent out and tested. I am sure DAP would do it for a good price.
  18. seems to have migrated to both now, but orginally up front.
  19. Get a quad. That's the only tuner that shows you timing.
  20. If you want HID's you need projectors, HID's in a Halogen housing is a Big NO NO. Remeber they don't have to sell you approved lights. Cheap housings are also only good if you are going to retrofit projectors. The reflectors in those are likely subpar. I would go with DAP's setup.
  21. yes it does. It's an off the shelf relay mod.
  22. 2x ball joints 2x wheel bearings 3x track bar 2x upper and lower control arms with new hardware, welded camber adjusters 1x swab links and mounts 2x shocks 3x pitman arm to kuckles steering linkages 1x all u joints What gets me is the steering wheel does not move / vibrate / jump at all but your butt / feet / ears hear and feel the truck "side step"
  23. I really need to do this to my truck.
  24. well I snugged up the track bar mount, no go. New set of wheel bearing as the timkens gave up the ghost after ~80,000 I am starting to think that my clunk might be engine mount / trans mount related.
