Me78569
Everything posted by Me78569
  1. I trust airdog stuff about as much as I trust, well, airdog stuff.
  2. Great, I am glad to see that hte test program works like I was thinking it would. I am about to make some pretty large revisions to my code so you timing couldn't be better.
  3. I am gonna bet you have a short in the junction located above the drivers front wheel. that junction carries all the wiring for the bed of the truck
  4. I have attached the manual. It will change some over the next week or two, but all the info will be the same. Mopar1973Man High Idle Switch install.pdf Also added another 6 high idle switches to the store.
  5. Give me a second and I will add a out of country shipping time Cost to ship to canada is 20.25 so that will be addded. Select the Canadian USPS flat rate shipping.
  6. Here is the manual for the switch Mopar1973Man High Idle Switch install.pdf
  7. use the new store. We are about to post this online. Alrgiht guys, There are 20 high idle switches for sale in the store Shipping is $5.25 and we will get them out ASAP.
  8. http://www.seeedstudio.com/wiki/CAN-BUS_Shield Verify that your version is working on pin 10 ( scroll down some in the wiki) Looking at your pic on the back of the board I see the CS with 9 and 10. I think it looks like it is jumping to pin 9.
  9. I don't have anything to extent the current switch, all of our wire is being used on this first batch. There is only one version of the switch, so no cheaper version. The switch is meant to mount wherever you want within the 10' cable length. You will have to clean the place you want the switch, dry, apply sticker. then drill out the white part of the sticker and then mount the switch through the hole.
  10. I am also using a r3 board. If you want ship the board and harness to me and u will look it over.
  11. Alright 25 switches are ready to ship. As soon as Mike and I figure out the shipping labels we will get these in the store and they will start being shipped out. Next 25 will be ready by the end of the week and then the next run of 50 should be ready within the month/end of the year.
  12. What??? haha opps. well I supposed that makes sense. Humm well ignore the above and I suppose we need to put it back haha.
  13. Also, Another cool feature, you should see a little arrow on the left hand side of the screen. you should be able to customize your forum layout with it. IE: you should be able to add things to the right side of your screen like topic feed, forum stats, etc. Just click, drag and drop to where you want it.
  14. Drooling over here. Can't wait to see it in person.
  15. Almost old enough to put out to pasture haha.
  16. Happy Birthday you old fart. Maybe take some time off and go treat yourself some.
  17. Trying to keep up on the internet. Big upgrade for the site. Once smoothed out it should make things better all around.
  18. Gauge defunct? Sensor defunct. Verify coolant temp with another gauge
  19. Not sure I understand that?? Really you can't borrow a scanner from autozone? Dealer and free don't go together.. I guess you need to buy a scanner then. try harbor freight.
  20. any word on your setup, did you figure out why the turbo doesn't seem to respond?
  21. Go to autozone borrow a scanner and see what codes you have. don't worry about what you need or dont until you get a scanner on the truck.
  22. It should self clear after x number of time without the code being prompted, but the 1693 code means you have another code somewhere.
  23. So you cleared codes after replacing it? You really cant have a single 1693 code, it is always paired with another code.
  24. Welcome, I am glad you were able to get joined on the site. so you replaced your apps, the issue went away, then a few months later you get another p0122 code?
