Me78569
Everything posted by Me78569
  1. It is Beyond easy to do. -Drop the pan / drain fluid ( put a trans pan plug while you have it off) -Remove the "e" clip holding the park rod in place - undo the TV lever from the top of the rooster comb - Undo the Bolts holding hte VB in. ( keep in mind you will drain another 3-4 quarts of fluid) - drop the vb.
  2. Well Gang, The Board of Directors on the Mopar1973Man.com has decided that we need to produce some new High Idle Switches for the 2nd gen 24V Cummins. We have spent a considerable amount of time designing a Brand New High Idle / MPG fooler Switch. We have learned from the last switch design and have made significant improvements. The New High Idle / MPG Fooler switch will be the same price as before, but it will be more robust and modular to allow for easier install. We have decided to only offer a "Install Anywhere Kit" rather than a gauge mount or Cubby Mount. You will nly have to drill one 1/4" hole to allow for the fitment of the switch. Some teaser pictures. We are making 50 switches to start then another run of 50 after that. You can order them from The Mopar1973Man.com Store I expect to have them ready to ship within a 6 week time.
  3. how to remove the 47re or how to remove the 47re valve body?
  4. I have never actually been into games. I have played a couple fps and so forth, but I never got more than a few days into it.
  5. Yea, I know what I want it to do, but I am still building the code in my brain, and working through the issues.
  6. No more at x turbo rpm be at x position. More so if turbo is gaining speed do this or slowing down do this. Not sure how I want to do that yet, but I have been thinking about it.
  7. I really need to spend some time working on this again, but life has been too busy. I keep thinking the top end control of the turbo needs to be more dynamic.
  8. any mud recently?
  9. Anyone out there looking at the moon now? Big and Red, looks pretty awesome.
  10. It'll run fine with a ho. Ed had a ho on his Truck
  11. the oil pressure gauge in the truck dash is a dummy gauge. It isn't good for anything. I wouldn't worry, if you want put a mech gauge in to verify, but I don't think I have ever heard of a oil pump going back in one of these trucks, provided of course that the truck has had it's oil changed haha.
  12. cw would be a good choice if the OP wants some more go. However why not get a rebuild kit for your turbo? Cheap and easy.
  13. Do you know what your fuel pressure is pre-vp44? I would also hot wire the vp44 http://www.bluechipdiesel.com/vp44_diagnostics.html If you are seeing "No-Bus" then i would also VERIFY all fuses. Clean all leads to the battery.
  14. I'd say it greatly depends I know in my setup 2:1 (or more)in low boost situations is needed. Once the turbo is going good it levels out to 1:1 pretty quick. I can tune the ratio better, but spool is is way worse.
  15. Haha. Big fan of the middle.
  16. I should taken a picture, but for less than $500 total, plates cups food etc etc etc, we fed about 100 people. Everyone said it was good, so I will mark it off as a successful.....plus now I am hitched
  17. Well made another trip up the pass. Had about 3k less in the trailer and ambient Temps were about 30*f less. Temps didn't come above 200*f Dunno if it was me cleaning the radiator or Temps being lower. Oh well
  18. My Lifetime warranty water pump seem to go out about every 30k haha. So that is how often I flush coolant.
  19. Mike, They might have used that wire to power the gauge. If there was a short in the gauge you might see an issue. I doubt that is the case, but it is possible.
  20. Onions are cut, garlic peeled and cut. Another #20 of pork done. Crock pots are now idle. Picking up green beans in the AM, and cutting potatos tomorrow night.
  21. coolant got somewhere around 230*f Pass I was driving is is about a 3,000' elevation increase pretty good grade. 45mph speed limit with a kansas person doing 25mph ugh. as soon as I was able to get going 35-40 mph temps dropped to 220f*
  22. well, I pulled about 10,000-12,000 up the pass today. I can say the turbo loved it....My radiator, not so much haha. I guess it is time to clean her our.
  23. It really screams when you have a trailer on. Just a little bit of extra load really helps lite the turbo. I was climbing a small hill in 2nd maybe 15-20 mph, look at my boost gauge and I was still at almost 10 psi, looked at my rpms and I was at like 1400 haha. little more tweaking and I will be really happy with the setup.
