Me78569
Everything posted by Me78569
  1. Go into the quadzilla section. The video for how to update is pinned
  2. Try out some of the tunes that we hosted here.
  3. export the log via your approved method and use the above article. It's just a .csv file
  4. oh ok. then yea that should be fine.
  5. There are 4 different large injector tunes I see, they all say 7 x .011 or bigger What tune are you running? they show injector size in the description currently.
  6. It should be your first stop. It is a hugely powerful feature. Also I would not be using a "big injector" tune on a truck with 7 x .009's the big injector tunes are designed for 200 + hp injectors
  7. data log the issue. data log the issue. data log the issue. If you ANY issue with your tune, datalog it happening and look at the log.
  8. its a standard mini usb. I dont see how a mechanical whining noise could be related to the quadzilla.
  9. you should always have the ablity to flash your box. however it isn't causing your issues. 1st, don't free rev. it serves no purpose and there is no maps in the quadzilla as it is not important. Tune on the road. 2nd the quad doesn't do anything at idle state unless you have quadzilla high idle enabled. Since you have oem high idle, dont enable quadzilla high idle. tune your truck, the base tune is not meant to be a great tune, it is meant to be safe across the board. What do you mean whining noise? Is it coming from your speakers or is it mechanical?
  10. What you describe is what happens when oem high idle tries to kick on while the quad high idle is active.
  11. Don't disable oem high idle. It works better. Disable the quad high idle.
  12. Yep it is bridged right. The newer flashes are much smoother handoff of fueling. However I would want to fix the map not reading until higher psi. I would get an oem sensor from geno's as for your timing curve. Make sure you are maxing out timing up top, you will gain a large amount of power doing so. I would do 16,19,23,27,30 or something similar to that. you can use the throttle reduct = 5* to pull timing down low and offset the 1500 rpm mark
  13. I would check the pin inside the box before replacing the sensor.
  14. likely has to do with the sharp drop in fueling that happens at 1000rpm, going from stock down to your 0 psi setting.
  15. how to update verify your jumper setting inside the box is set for a late truck rather than early.
  16. Why is your map sensor only reading 0 psi all the time? Do you ever see boost come above 0 psi? The quad is not getting the inputs it needs to fuel at all. That's likely your issue. you should also update the box under the hood. The flash is from 2017. There are big improvements since that point.
  17. Sounds like the ecm and quad fighting for control. The quad doesn't take over until that 1000 rpm mark. Post a datalog of the issue. It could also be too much timing. When's the last time you updated the box under the hood?
  18. The s200 is a fine turbo for your goals. it should be happy at just under 400 hp. The he351 turbos flow ~67 lb/min if I remember right and they are good for the 400 mark without heat issues.
  19. Great news!
  20. guess he couldn't wait to see that rockin Stache. congrads!
  21. the eb isn't even close to the amount of pressure that happens when combustion happens.
  22. Figured I should start another thread about reloading to keep things seperate. I believe @AH64ID said heused berger bullets? what has brought you to them? I am currently using hornady eld-x for my hunting rounds, but I have heard a lot about bergers. Berger is pretty proud of their stuff though $$
  23. %100 normal. At some point in the late 90's there was a meeting. for some reason they decided to not allow higher than that on the engine bus, but they did on the obd and ccd bus. I dont understand why, but it is the way it is.
  24. he only had the control pod, he does not have the iquad so he can't custom tune or setup custom values for things like high idle.
  25. any 8 pin molex should work. here is a 1' section https://www.amazon.com/ATX-8-Pin-Extension-Cable-ATX-8P-EX/dp/B004LKASDO
