Me78569
Everything posted by Me78569
  1. headstuds should be in your budget for 500+ hp
  2. have you done a boost leak test? Why did you replace the turbo? What mods? any codes and do you have anything to read sensor data?
  3. 7 x .010's or .011's with a 62 inducer would get you to 500 and spool pretty dang fast.
  4. you are seeing a pcm report on chris's tool. There is also a level of rounding in place when everything is pushed through .
  5. lol nope I'll wait. I am stubborn
  6. how much power do you want?
  7. using 95.7 will do math of 1/1 * mph from ecm.
  8. check your power connections. sounds like the box is not getting power when ign is off.
  9. call DAP lol. Jacob just told me what I needed.
  10. 7x .010's are good mutli use injectors. they can flow enough for 500+ hp and you dont have to tune them into submission
  11. I would be curious to see it.
  12. how are you comparing the superchips timing to the quads? without logging of sorts I wouldn't be betting on anything.
  13. old quad said 8* was pushing it on those old tunes. fueling it is hard to mess anything up. I would update to new tuning and the iquad.
  14. At this point I give up https://goo.gl/images/1QQ9uc
  15. DDP's are known to be smokey. you are also using tuning that is %100 above oem duration. the quadzilla allowed me to pull duration down to offset the large injectors.
  16. given the logging industry in that area I would think there would be a large number of good shops near you.
  17. most injection shops should be able to. Thunder bay should have a shop for sure.
  18. youtube is your friend. Sure looks like a failing vp44 OR VERY bad injectors. got a place that can pop test injectors local to you?
  19. look at the number plate on the engine.
  20. sounds like someone swapped a 01-02 engine into your truck. I would verify what engine your truck has 1st
  21. Porsche is releasing some data on their ev that goes on sale in 2020. Taycan 310 mile range, DC fast charge of 250 miles in 15 minutes.
  22. Yep big injectors make a world of difference, but some tuning will really help get the full package. Those videos I have I was pulling ~%30 duration offidle. The truck was no faster with or without smoke.
  23. I passed emissions with 7 x .012's here in the springs
