dave110
Everything posted by dave110
  1. Hows the fit? Looks like there is a filler plate of sorts? You make that, buy it, or did it come with? $39 is pretty cheap. I drank that much already. Can an old phone with no service still be used to store and play music? Be gentle now, I'm one of those older guys that still has an LG flip phone with no plans to update, but newer BT phones can be had at yard sales cheap.
  2. Read through this thread. Your problem seems similar to this one.
  3. @JAG1 beat me to it! Might as well put it to good use.
  4. Don't worry. Elizabeth Warren is on the way. I'll have to find a picture for Dripley
  5. That's the picture they show you when the Viagra lats longer than 4 hours
  6. Thanks for sharing! I had no idea Rock Auto had springs for the front of ours. Sometime I want to do mine. It had a plow rigging on the front and a hydro seeder on the back before I bought it. Was so much constant weight on the back that it popped open the clips that keep the leafs together. Both ends are tired.
  7. Dripleys right. Just for future reference, a 2 door is considered an extended cab. Only 2 doors open. A 4 door has 4 opening doors hence the name quad cab. Quad =4.
  8. I knew you had that one in your arsenal. Was hoping you'd take the hint
  9. I got it now. A duck-en he is. OK now Dave
  10. Chickens don't migrate . They just cross the road. To this day nobody knows why though.
  11. Had some fun doing one of my favorite things yesterday, 35+lbs of noise and vibration. Glad I don't have to use this all day long. Nothing makes a mess like 1/2" pitch chain. Got some of the 'smaller' saws out too.
  12. https://www.dieselautopower.com/quadzilla-power-1998-5-2000-dodge-5-9l-cummins-adrenaline-with-iquadbt Is everything I need here? And I want the BT one to use with an Android tablet right?
  13. Looking over DAPs site at the new quad and I managed to further confuse myself, partially because there are 4 different prices for the 98.5-00 Adrenalin. If I buy the $642 one does it come with V2 tuning or is that extra? Do I need the add on BT module as well? Does a base tune come with it? Will it work on windows 10? In other words will I be ready to go with just the tuner or must I add something? OK, that was more than 1 question. Thanks in advance.
  14. Mount it to the front bumper like the old Ford Camper Specials. It'll double as a winter cold front and the deer will just bounce off. Ideas..... I'm full of em
  15. Plenty of clearance on mine. I have a stock size spare though. Anything larger won't fit in between the hitch.
  16. I run a Diamond Eye 5" on my truck and the spare in the original location. Not sure what the difference is
  17. Read through here. There's a diagram showing where the lines go The one that's not attached could be the vent or exhaust.
  18. I think that there should be 4 on the little vacuum valve block at the transfer. 1 is feed from the firewall junction, 1 is an exhaust, 1 is cad engage, and 1 is cad disengage. I have a feeling someone will post a diagram here shortly. It might be me if I can find it.
  19. The CAD axle, which I believe you have, is shifted into 4WD with vacuum. If one of your lines is disconnected it will not engage the axle.Either that or the spool in the axle itself may be locked up and not moving.
  20. Just for reference 3/4=.750. 19mm=.747992. Pretty close.
  21. Does our lousy Reading winter weather have you thinking about Florida Pepsi?
  22. I always liked the look of my OBS Ford wheels better than anything I've ever had. They fit right on the Dodge?
  23. I didn't know what TIPM stood for so I googled it and this showed up. Hope it helps. http://absoluteraleigh.com/tipm-repair/
