- Replies 36
- Views 8.9k
Mopar1973Man 9 posts
dobienut 5 posts
Dieselfuture 3 posts
WiscoRedkneck 3 posts
Problem solved... I went and got a Dayco belt from Autozone with a 3 year warranty. Installed and the problem is gone. http://www.autozone.com/cooling-heating-and-climate-control/belt/dayc
Turn the belt around backwards and try again. That's how I fixed my squeak.
Cummins oem brand tensioner and a gates belt is running quiet and eliminated the shut down squeak. I was so used to the shut down squeak it took a friend who owns a Cummins that heard it shut down t
I've got a weird one that just started up. First off I've got a brand new fan belt. I've check all pulleys and bearings. No loose bearing and all pulleys spin freely and grooves are clean. The noise is coming from only the A/C pulley. Turning on the A/C has no impact in the noise level. Now in all my messing around, I managed to get the belt to ride on top of the high points of the grooves for the A/C pulley and the noise was gone. So I took the time released the belt and made sure it was back down in the grooves again. Now the squeak returns. I've tried some of my older belts I kept for spares with no change. I've power washed all the pulleys with degreaser and solvent. No change. I've inspected the grooves for debris and clean all the pulleys. At least now with all the cleaning it reduced the volume of it a bit. Any ideas?
