New guy with questions-added a few pics
- Replies 13
- Views 3.2k
Mopar1973Man 2 posts
015point9 2 posts
sooxies 1 post
CudaDude 1 post
Popular Days
(sorry still leaning how to edit)
Gauges...You're going to have to figure out what you want. Mechanical or elec. I just got an elec Autometer pressure gauge last month because it matched my series of gauges. At the time didn't know
Welcome to the forum, that is a good find. I personally have never been exact on the 2 stroke. I normally fill up around when the fuel light comes on which is about a 32 gallon fill up for me. Might g
New guy here, first time diesel owner. Somebody traded in a 02 2500 6spd 4x4 at work with 163k. It was going to be wholesaled so I got a pretty good deal on it. I've been reading everything I can trying to familiarize myself with the truck, but I do have some questions.
It appears to be completely stock with the exception of a boost gauge that was mounted in one of those pillar pods. I didn't care for the location of it, so I removed it and currently have no boost gauge. Since the truck had no boost gauge from the factory and my plans, at least for the foreseeable future is to keep it stock, is it okay to not have a boost gauge. I'm not heavy footed and have no plans to haul or pull much more than some dirt in the bed or a small camper.
2 stoke oil. I've read numerous things on how these trucks benefit from adding 2stoke (1oz to 1 gal of fuel?). How critical is that ratio? I filled up yesterday (35 gal tank) and added 1 qt of 2stroke (not quite 1oz to 1 gal). I added the oil first and then fueled up so it would mix well.
This is one of those really ignorant questions, as I don't know of any other way. But I'll ask anyway. On future fill ups, will adding the 2stroke after filling with fuel be okay? So I'll know how much oil to add. Will it mix good on it's own?
Idle. Where should these trucks idle? Mine was about 850 rpm but within about 20 miles of adding the 2stroke it jumped up to 950-1000 rpm. That okay?
Temp. So far the temp gauge stays just a little below the 190* mark. I guess around 180-185*. I couldn't find it, but I think I remember reading somewhere that these trucks run best with the temp no less than 200 or 205 (can't quite remember). Should I replace the tstat with something higher? If so, any particular brands you recommend. OEM the best?
I guess that's it for now. Thanks in advance for responses. I'm sure I'll have many more questions down the road.
Edited by CudaDude
