Fan belts squeaks
I've got a weird one that just started up. First off I've got a brand new fan belt. I've check all pulleys and bearings. No loose bearing and all pulleys spin freely and grooves are clean. The noise is coming from only the A/C pulley. Turning on the A/C has no impact in the noise level. Now in all my messing around, I managed to get the belt to ride on top of the high points of the grooves for the A/C pulley and the noise was gone. So I took the time released the belt and made sure it was back down in the grooves again. Now the squeak returns. I've tried some of my older belts I kept for spares with no change. I've power washed all the pulleys with degreaser and solvent. No change. I've inspected the grooves for debris and clean all the pulleys. At least now with all the cleaning it reduced the volume of it a bit. Any ideas?
  • Replies 36
  • Views 11.7k
    Problem solved... I went and got a Dayco belt from Autozone with a 3 year warranty. Installed and the problem is gone.   http://www.autozone.com/cooling-heating-and-climate-control/belt/dayc
    Turn the belt around backwards and try again. That's how I fixed my squeak.
  • WiscoRedkneck
    WiscoRedkneck
    Cummins oem brand tensioner and a gates belt is running quiet and eliminated the shut down squeak.   I was so used to the shut down squeak it took a friend who owns a Cummins that heard it shut down t
Something has moved... hard to say what.  Could just be surface wear or something building up in the grooves of the ac pulley.
In the past i have used belt dressing or soap as a temporary fix.
I tried that yesterday and it lasted about 5-10 minutes then it would be loud enough to make you want to roll up the windows.
I cleaned the grooves of the pulley, then spray solvent on them and power washed them. Just to be sure there is no other oils, belt dressing, etc. that might be causing the issue. I even sprayed the belt down and power washed the grooved side of the belt to get any debris out of the grooves of the belt. I did find like metal plating or paint in the grooves. It now clean.
If you changed the new belt with an old belt and the noise is still there then it's not a belt problem.  The pulley is clean and dry of contaminants then I think the pulley may be out of alignment causing added pressure on one side of the belt groves.
For what it's worth that happened to me once, did everything you did cleaning ect. Ended up buying the new more expensive one, I think it was Gates from Carquest, and noise stopped right away. I'm still running same belt 3 years later.
At first I actually thought my alternator bearings were shot
On a different note I had a Chrysler Town Country van and it sounded like a crankshaft was broken banging around, Ended up being bad bearings in the alternator
Edited by Dieselfuture
A/C pulley has no movement. No visible wobble either. The new belt is 1mm thinner than my previous CarQuest or NAPA belts. The A/C compressor is fairly low miles.
That's what I think I'll end up doing. I'm going to run it and see if it clear up in the next Boise trip.
Tensioner holding still? Or bouncing at idle, I just fixed this issue new tensioner and gates belt.  You say A/C has low miles is it rebuilt or new?  Possible clutch shifted if it's rebuilt
All pulleys are straight. The belt is ride straight on all pulleys. Bearings are all smooth, fan, water pump, alternator, tensioner pulley, and A/C pulley. New compressor.
I guess one day soon I'll just have to buy a good Gates Belt and get on with it. Right now I just rubbed a bit of liquid dish soap on the belt to shut it up for the temporary time. Rather annoying...
  • Popular Post
http://www.autozone.com/cooling-heating-and-climate-control/belt/dayco-serpentine-belt/150612_0_23387_5281
Been dealing with the same issue for about a year and a half.. Had just the every day Gates belts on and they would be good for a bit then the swooshing noise nice starts. Since the start of this i've put I think 3 cheaper belts on and then went to the Carquest commercial Gates belt as mentioned about. Problem was fixed for three or four months and then after getting my truck out from storage this winter it started again. I too the belt off and cleaned all the pulleys and wire brushed them, bought another new belt figuring the other one just got hard or something from sitting all winter, and the new one took my noise away completely...for maybe a week. Now its back!  Soon ready to sell the dam truck if I can't get it stopped as noises like that drives me nuts
My truck did this at shut down the first 4 or 5 years I had it and slowly just went away. Always heard it described as the Cummins sneeze. I heard several others with it and just never gave it a thought.
 Surprisingly enough, i've yet too hear mine do that in the 14 years i've owned it
Mine squeaks when I shut it down. All of the Cummins trucks my grandfather had (6) have squeaked whenn shut down too. I even hear it in some of the medium duty trucks that come in to work that have the isb in them. I figure it's just normal lol
if the belt squeaked all the time while running I'd go insane
Edited by CumminsTech
I'm half way there..it drives me nuts! Especially when I can't get rid of it. Could mean the sale of a truck
Did you try oem mopar? I'm not sure who makes the oem belt, I know the tensioner is dayco. My local shop said run oem or it'll squeal. I've been running oem mopar belt and tensioner for a couple years, only squeaks on shutoff.
No I've never tried one, guess I just assumed theyd be the same company making them. May have to inquire
both my 2002 and my 2001 squeaks at shut down. Ran one belt for at least 150k miles with never a thought about it on my 1st gen. Never had a belt fail... knock on wood.
Both my 02 and 99 have a quick chirp/squeak at shut down. I'd probably think something was wrong if it didn't do that when I shut the truck off!
