Grid heater manual control...
- Replies 33
- Views 32.6k
Mopar1973Man 11 posts
dave110 4 posts
JAG1 3 posts
jlbayes 2 posts
Yes, you can. I have had mine wired with a manual momentary toggle switch since the truck was new. It is simple to do and works very well. Since your truck is an 02, you should be able to use the at
WE NEED FANCINESS!!!! If that means burning the truck to the ground, then it was worth it! Lol Seriously, if you really want it, the right battery disconnect switch will do fine. The co
No. It won't fry the ECM. It burns the fusible link near the battery.
Can I control the grid heater by installing a switch on the Grid Heater Relay control wires? I know this was talked about before. Did a search and nothing comes up.
