17” 3rd Gen Wheels
Preparing for 3rd gen brakes come nice weather. Looking for 17” 3rd gen wheels on craigslist now, debating steel vs aluminum. Either way, I’ll get them powder coated black. I like the look of the aluminum ones but steelies are cheap. Any downside to running the steels for now? No super heavy towing, mostly loading my 8’ bed with firewood and an occasional light trailer.
  • Replies 51
  • Views 27k
  • Marcus2000monster
    Marcus2000monster
    Could you message me a pic of your truck with those 4th gen wheels? I am thinkin about doing his switch too.  Ha I am so dumb I didn’t even see these before I asked for those pics!
  • I've been lurking quite a bit the past couple months on the forum without posting (shy sometimes).  Glad to find a thread I could add to right away.  Powder coated 17's.
  • Dieselfuture
    Dieselfuture
    Here are my 17s from 4th gen
Not sure if you knew but 4th gen also fit that's what I have, sometimes you can find just as good of a deal as on 3rd gen, that is part of the reason I like factory rims because they had to meet some kind of a standard for weight rating. And the ones I got off of 4th gen it was a 3500. Not sure if weight rating on Wheels would be different.
Personally I’d look for 4th gen 18’s. 17’s are weight limited more than 16’s and 18’s, it’s BS but it is what it is.
You mentioned a bed full of firewood, so I’d go for at least 7K of wheels/tires which you won’t get with 17’s.
It took me 3 months to find a set of the 3rd gen wheels for $200 or less, most people wanted $400+.  The cheapest set of 4th gen wheels I saw was $900.  I didn't really care for the way they looked though, too shallow and seemed to stuff all the tire under the truck.  I'm in no way a fan of this "stancing" everyone seems to love, but the wheels got to stick out just a bit.
My dad bought a set of 18” 4th gen steel wheels for his 06 in Nampa for $250. I didn’t measure them, but the offset appears the same as the 3rd gen wheels. The 4th gen body is wider thou.
I never even saw any of the 18's, pretty much just 20's.  A few sets of those right now for $4-500 with worn tires and scratches.
Don't forget to up size your spare as well.  I almost forgot and decided to hold off on the brake upgrade until I had a 17" spare as well.  I had new tires at the time, but life likes to kick me when I'm not looking.
I went with 4th gen 17’s. I personally don’t like the look of 18’s on 2nd gens and I got a good deal on them so I figured eff it lol.
Heres a side profile of mine.
Oooo do you have more pictures?
Thought about 17's for mine but the tires cost about $25 apiece more for matching size of the Coopers I run. Never checked the loading on them. The 16" ones I bought are rated at 3560#.
What are you seeing the 17 oe's rated at?
17’s are rated for 3195#
Over the last few years all the oversize, 285 etc, tires have been dropping to 3195. There are a couple still above 3195 but I suspect they will change to.
Its not that the tires are weaker, but there is verbiage in the national tire reg (forget its exact name) that limits 17’s and apparently it’s being enforced as 17’s are dropping.
My brother and I both ran different mfgr 285/70R17’s. They used to be 3750# but now they are 3195#. He actually had to get one replaced under road hazard and has 3 3750’s and 1 3195.
Edited by AH64ID
I would have get wheel spacers/adapters to run the 18s thought because of my rear axle hubs.
I don’t know why you would. All HD trucks have full floating axles.
The only firment issue I know is for those with manual hubs up front. Only the steel 18’s fit without machining.
I have had 2 sets of Nitto Duragrapplers 285/75x17 on third Gen wheels.  They are rated @ 3970 lbs.  I also have 2 sets of 3rd Gen wheels which I paid $80 for the first and $100 for the second set.  I did do a lot of watching Craigs list for them and basically first one there to make a cash offer.  Discount mentioned Nitto was probably going to not build this tire anymore because they did not make enough money on them!  =(  Have been great tires for me.
Those are one of the last tires to hold their original rating. Based on what I’ve seen and researched I don’t expect it to last long.
My dad runs that tire as his summer tire since he hauls a slide-in camper and needs the capacity. He hopes they hold onto the rating but we aren’t holding our breath.
Toyo 285/75R17’s used to be rated the same. They no longer are.
Very much aware of that. My '01 got totaled and took out one of the tires (not rim) is the reason for another set of wheels and tires.  Now have 3 extras to put in the rotation at some point.  I think they are great tires with a better than expected snow traction at least when new.  Probably have to do something different when they change rating.  Have you seen/heard what's up with that at all?
Ha I am so dumb I didn’t even see these before I asked for those pics! :doh:
Those rims look pretty good on a 2nd gen.....What kind of tires are those?
I must be old,,,, I dont go for the blacked rims.  I like the vintage rims like alcoas
It was cheaper to powder coat mine rather than restore to like new (I like the original finish as well).  The winter got the best of the set that I bought but not going to complain for the price I paid. I wasn't going to pay an outrageous price for a set in very good condition.  Also, for me, it took about 1.5 months for a set to popup that was at a convenient location (craigslist).
