- Replies 79
- Views 15.7k
Mopar1973Man 22 posts
KATOOM 10 posts
NIsaacs 9 posts
Bullet 9 posts
No, overdrive (6th) is inside the case, better support and it is a bigger tougher tranny all around. The issue with the NV4500 is 5th gear is outside the main case. So any slight bearing slack on the
We obviously dont agree but based on the pictures and information I've seen so far, I do not believe the pilot walked out of the flywheel on its own. I think it was drawn out by the wiggling input sh
DONT float gears in these transmissions. This discussion has been hashed out for years and seems to get very heated depending who's defending what position...but no matter, it still stands as a FACT
With a heavy heart, something broke in the transmission running along at 80 MPH. 5th gear failed with a horrid grinding sound. 1st to 4th still works find but there is a loose object for sure like a 5th gear nut. But you can't put it 5th it grinds bad.
