Questions replacing battery cables
- Replies 15
- Views 4.4k
dripley 3 posts
Ed ke6bnl 2 posts
015point9 2 posts
01cummins4ever 1 post
On the topic of solder make sure you never use acid core on anything electrical. May sound obvious but i have seen people use it and it causes some of the nastiest electrical problems you will ever se
If you got the military terminals the cable ends you gave should be all you need. I personally prefer soldier, because it seals it better and you won’t have air gaps that will start to corrode overtim
Solder...found a old spool from Tandy projects. Probably 60"s or 70's. Unknown percentage of mixture.
1st QUESTION...Any certain type of solder for battery cables?
2nd got these things in pic that are 2 ought in size.
Are these in pick or do I actually need the type that circle the battery post?
And already picked up "military" type battery posts.
Any help
Thanks
