- Replies 19
- Views 3.6k
Mopar1973Man 4 posts
Evan 4 posts
JAG1 3 posts
wil440 2 posts
Standard method disconnecting... Negative cables Positive cables Standard method connecting power again... Positive cables Negative cables APPS reset
Come on, who doesn't love the adrenaline rush you get when you weld your wrench to the fender.
Me, I'd say not as I've had both mine off a few times, what I will say is remove any rings and be careful to not touch tools onto the truck, I shroud the spanner/wrench with my hands hence no rings ev
Beginner question...
In process of gathering new battery terminals, both batteries are out right now. Once cables are fixxed...
Is there a certain sequence I'm supposed re-connect them or pull any fuses first or anything else I should do before connecting?
Thanks
