brake main line failure
- Replies 40
- Views 10.6k
CUMMINSDIESELPWR 20 posts
Mopar1973Man 3 posts
dripley 3 posts
Haggar 3 posts
I wrote up an article about this. I have the website that I bought them from. They give you all of options to choose from. Read the article, and follow it, there are parts for or t
@CUMMINSDIESELPWR you should just get a hold of President Trump and tell him to just sign your stimulus check over to NAPA, it'll be easier...
"Mr President, i need a check for Me, Myself, and I. Thanks!" $3600
So if this is wrong section move please.
I had a main brake line failure today, thankfully while teaching nephew manual transmission. he was standing on the brake and thankfully caused the fault which would have been very bad had i been at speed.
it is the steel main line along driver frame rail leading to the rear brake valve. all rubber lines still look good but im gonna redo ALL brake lines steel and rubber to have a fresh system.
