Looking for Staff Members
Does anybody know if the little “male” connector with the spring door can be purchased separately from the pigtail that plugs into the body trailer harness? And if so, what’s the part number? All I can read is Delphi. Everything else is gone. Thank you.
  • Replies 15
  • Views 3.8k
  • Dieselfuture
    Dieselfuture
    Which is crazy, why do we give more power to these people that make it so difficult to live a simple life.
  • I guess what messed me up is the male and female thing. Still does. The plug for the trailer fits into the part with the spring loaded door. To me that means the trailer plug is the male in my feeble
  • Oh how I'd like to help out here!   Nope, I won't. I'll just get into more trouble    @Mopar1973Man, can you make it so that I can give @dripley a like, a ha ha, and a thanks all in one post
I just googled "male 7 pin trailer harness connector" and many are shown at many different suppliers. They are pretty standard. But l have not seen one with the spring door. The female has the spring door on all the ones l have messed with.
I think it would be wasted effort to try and replace the spring and cover.  the plastic is so brittle on the rest of it that I would guess it would break trying to replace it.
You can get them from amazon, or the local junk yard off any 2nd gen dodge truck. I have 2-3 sitting on the shelf because of junkyards.
Genuine Chrysler 56038366AB 7-Way Trailer Connector https://www.amazon.com/dp/B00GBW09G6/ref=cm_sw_r_cp_api_i_WlmMEb9F7W59W
I’ve found it searching “2001 Dodge Ram 3500 7 pin trailer plug” which I’m sure would work for your truck year and model if ya changed it
Edited by Towrigdually
I guess what messed me up is the male and female thing. Still does. The plug for the trailer fits into the part with the spring loaded door. To me that means the trailer plug is the male in my feeble mind. But I go and look more close and see the female part is hiding the male part. Where's Caitlyn Jenner we need her explain this stuff.:think::doh:
Oh how I'd like to help out here!  :evilgrin: Nope, I won't. I'll just get into more trouble :spank:
@Mopar1973Man, can you make it so that I can give @dripley a like, a ha ha, and a thanks all in one post? Just this one post? :lmao: :pray:
Edited by dave110
I really had to think about what l was typing when l posted this. The world around us aint what it was when l grew up.
I agree. So many folks preaching tolerance these days. Yet if you cant see things their way they are pretty much intolerant of you.
I've never felt more agreeable than now.
Yeah my steel protective plate crushed it, but it only ended up being the very end part. The little 10" pigtail is still good, along with the female connector part.
Here's what I'm talking about.
5476-D321-048-B-4919-909-E-80842-C95-C95
7-E1-D3-A74-0-C9-A-457-C-95-BD-B055-DE5-
Edited by Florin1
post pictures
Look at a PK11893 (Pollak replacement 7 RV connector, vehicle end)
It should connect to your existing pigtail.
