NV4500 locked in 4th
- Replies 23
- Views 8.3k
Dieselfuture 7 posts
Mopar1973Man 4 posts
Towrigdually 2 posts
Doubletrouble 2 posts
Here's the pics to go with that!!
Wow, just think if someone had no idea what to do next, probably cost them few thousand bucks to deal with that. Good thing you had some tools with you. So is this something that may have been overloo
Like I said the front two tower bolt were not tight so when I pulled down to 4th I pull the shift rod right out of the gate. If the tower was tight it might not have happened. Being I normally just st
Yup. It finally happened to me. Dropped from 5th to 4th rolled up my power tried to shift to 5th again... NOPE so I'm stuck in 4th limped into Hoots Cafe in Whitebird, ID. Im glad my sockets with me. Quickly pulled the cup holder up. The the boots. Then the shift tower. Everything was good just jumped out of the gate. Push the center fork back to neutral. Reassembled. Took 20 minutes with basic tools. Now in Grangeville ID getting breakfast.
