  1. No. That was calculating backwards for the heater of the fridge in DC mode. Using the wattage of the 120V side then calculating the 12V amp draw. No measurement yet for my furnace.
  2. Guilty as charged. I used to be that way have a big rig in front of me and blow around them. Now I tend to just hang back with my 55-60 MPH cruise most times I end up travelling with a semi-truck up the canyon. I've got no problem with that now. When I see my MPG jump up I tend to enjoy the bonus of cruising slower and getting the MPG boost. Easier on brakes, less panic stops, less close calls,etc.
  3. Corrected my post above for DC operation not 12V to keep other from getting confused. But even my Norcold with 2 standard lead acid batteries, 45w (3 Amp charge) solar panel and 1,200w inverter (100 amp draw @ 1,200w) sit around for 2 days watching TV and drinking beer no problems with batteries running dead. It's all about being aware of the loads. I do think your attempting DC operation and ate the batteries in a short order. My Norcold is only a AC or LP operation no DC function. Still in all it best to operate in LP mode, propane is cheap and last a very very long time compared to DC operation eating the batteries fast or putting load on the tow vehicle alternator. AC only works if hooked to city power or genny. Well in AH64ID case his inverter but still even then the load is place back on the tow vehicle. The biggest propane eater is the furnace, next is water heater, then fridge.
  4. They do it on curves, blind hills, etc. They don't care just get out of their way. During the winter time the highway here gets quiet and very few accidents occur. But now get tourist from other states and they drive like they are still in Texas with 80-85 MPH speed limits. If you going 2 MPH slower they pass you. I've actually had people pass me in a fire truck before truck running against the governor and went around me with lights on even. (Most of our trucks govern out at 60-65 MPH).
  5. Slide the tool into the lock. The while hold pressure against the tool twist lightly back and forth of the pipe to free the o-ring. Now it should come off. Typically that's how I free a connector the rocking back and forth will seem to get some oil on the o-rings and get it to slide off for you.
  6. Still in all 2 Amp draw should last a long time vs. 200 Amp hours of batteries. At least 4 days calculated to fully dead. What killed your batteries is the main heater which draw lot lot more amperage. Roughly speaking the main heater on 12V is 40 Amp draw which would deplete the batteries to full dead in about 5 hours. But since its only allowed to 10.5 volts the time is even shorter. Like I said charge the batteries back up and switch to LP I'm sure it will work just fine even with the heater.
  7. Ok... DC operation is only advised if you hooked to your truck and travelling. LP mode should be used if boondocking. AC mode should be used if hooked to city power. All I can say is start over with a fully charged battery and make sure your using the proper mode. I typically leave mine locked on LP mode. On a fully charged batteries it will go over 2 weeks without recharging just the fridge alone.
  8. Summer is here... Please people slow down. I'm listening to the fire radio yesterday while cutting firewood. Riggins EMS was paged out to a roll over vehicle accident. Seem like everyone is in a hurry and passing with on coming traffic which now becomes a game of chicken and loser ends up in the ditch rolled over. I was lucky a few days ago as well coming home driving my typical ol' slow self I'm glad I was because the same thing happen to me I had a semi-truck passing in my lane force me off the shoulder of the road. Please people be safe and slow down there is nothing in the world that require high speed.
  9. So how about 1,821 feet at Riggins, ID? Or even lower yet at 1,581 feet at Whitebird. Even my place is barely 2,800 feet. Elevation this is low. MPG fooler is just setting the IAT to 143*F so even turning it off I'm seeing true number but on warm days I can float as high as 120-130*F when I was noticing the smoke. But now with colder temps I'm down to 80-90*F IAT's. Still fooler on or off the smoke level still high. Actually a little secret if you turn over to 6 Cylinder mode its a smoke switch. Dropping the IAT colder and ECT colder produces a healthy cloud. (Just letting you all know I've played and looking for other causes). This is not it. As for another odd thing noticed yesterday hauling back with firewood. I've got 8 miles of full time exhaust brake usage and about another 6 of part time exhaust brake usage from my cutting hole to the highway. By the time I get to the steep part of the grade and the EGT's are really low 200 or so. I start to notice a haze of blue smoke only when the exhaust brake is used. Then once I hit the highway I see one poof of blue and then it turns black and gone never to seen again. This has me thinking injectors for some reason.
  10. I went into Harbor Freight and picked up the mini's and the standard blade fuses. Each is like 60 piece assortment of all common fuses for $9 buck I think. Still carry the factory tire jack works really good. Used it many time including trying to get unstuck from a mud hole. Fan belt I left at home on the shelf. That part of the inspection process and dealt with accordingly. The only thing part wise I carry is the fuel filter for the sole reason you never know if it might just get you some time bad fuel or gelling issues in the winter. But all these years I've never had to use it. Brand new fleetguard filter 3 micron for the AirDog. I look at from a different light. If the truck going to fail me it most likely going to fail with part required that are not carried. So I look at the safety factor more so. So OK the truck died, no cellphone signal, no radio signal, etc. Your on your own walking. Grab the SAR's bag typically have my pistol on me. If MoparMom is with me then grab the other MRE and water and get walking. If I'm on the highway I can most likely flag down help. But if I'm off in the backwoods time to do the heel-toe express.
  11. Trailer tires aren't inflated to max either. Load Range C's with max pressure of 50 PSI but only 40 PSI in the tires. I figure I'm right close to 7k total trailer weight. Roughly figuring 2 cords (2,200 pounds per cord) plus 1,800 pounds dry trailer weight. Right at 6,200 pounds. I'm not driving it to Grangeville or Council to scale it...
  12. Even with the colder weather I'm still seeing smoke on 5x3 and 5x2 is a bit cleaner but not always. I'm starting to wonder if something about the fuel has changed.
  13. Like right now I've got my desktop computer shut down and pulled out the laptop a really nasty thunderstorm just rolled threw here. Several bolt made contact with the ground. So now if I wait till later I will be too busy with working wildland fires, if that doesn't happen then it gets so hot and dry the forestry bans firewood cutting because of fire danger. So I always get out after the thaw while the weather is cool and wet and get the job done. I can split the wood at home during the early morning hours and late evening not have to kill myself in 100*F weather. Yes it gets hot here seen plenty of 100*F here and better than 110*F in Riggins, ID.
  14. Don't I wish... I burnt about 9 cords of wood this last winter. I'm aiming for about 10-15 cords split and stacked. I don't gain access to the wood till at least late May and its closed up by snow as early as mid October. So I rather be up there like today light off and on rain showers (nearly snowing) with temps as high as 38-43*F. return to the canyon floor its like low 70's today in Riggins, ID. MoparMom was worried about us today being the rain storm she had it dumped buckets and only seen a light shower at lunch time. Lasted only about 30 minutes and back to work.
  15. Already broke in well. As for wood yes its all Alpine Fir this load. We've got our eyes on a huge spruce tree back another 20-30 feet more in the same spot. I get a bit of red fir now and then but don't favor it much being its a dirty wood and I tend to clean the chimney more. Firewood is the only form of heat here no electric heaters and no propane. All I can say is coming down a 12% grade about it in 2nd gear and the exhaust brake a rattling. She was heavy. Go Big or Go Home... I just went home BIG!
  16. Here is my setup... Backseat tray. Backseat tray has first aid kit, drinking water, MRE, fire extinguisher, fuses, fuel filter, toilet paper, kleenex. Behind my driver side the back pack is my Search & Rescue bag with more clothes (jacket, gloves, beenie, socks, etc.) fire starter, water, MRE, more first aid, etc. Then the bed of the truck In the bed is my socket set, 1 gallon of engine oil, 2 cycle oil, jumper cables, ratchet straps and few rags. I normally don't carry any parts. I tend to do monthly inspections and deal with issues when first detected and repair them promptly. I've never been towed nor had a failure that left me on the side of the road yet. Ps: Forgive me it's dirty I just got back from the woods hauling firewood.
  17. Just yanked home a nice heavy load of firewood on my BigTex trailer. I'm used to hauling heavy I tend to favor my 4th gear (1:1 Ratio) more so like Diesel4Life suggest to lock out overdrive which is the same 1:1 ratio as well on the Auto if I'm not mistaken. Biggest thing is not to be in a hurry taken your time slow down. Stopping large loads might take considerable distance compared to a empty pickup. http://forum.mopar1973man.com/index.php?/topic/8657-firewood-hauling-my-big-load/
  18. Well Gang... I spent Father's Day with a friend in the woods cutting firewood for 2 days. I figure I share a picture of my haul. This is 2 full trees this load. Yesterday we did 4 smaller trees for a full load. But this is the heaviest load.
  19. Double check the starter solenoid fuse I just had mine crack just a week ago. http://forum.mopar1973man.com/index.php?/topic/8638-failed-to-start/?hl=start
  20. Congrads Mitch!!! As for the FASS in the power window fuse you could... I really don't lke stacking like that. (Personal thing). As for the alternator just have it bench tested before leaving the store and verify the AC volts are below 0.1 volts.
  21. I'm also running full coverage on the truck but I'll have to ask MoparMom about the insurance payments I can't remember right now. CRS moment...
  22. Like here today its high of 53*F and raining. But yesterday its 90-95*F. A whole 0.0046 lbm/ft3 difference I really doubt the air density difference. I get more change in air density in elevation that I do in temperature.
  23. New Meadows ITD mixes salt with the road gravel. Usually truck in few tons of salt and mix with the gravel. This why they have a big shelter covering the road gravel to prevent rain and snow from rinsing the salt out. Rarely use liquid de-icer. Even that isn't liked much up here since the liquid deicer eats brass and copper wiring parts.
