Edge Comp: Dropped from 5x3 to 5x2
Like all winter 5x3 the injectors barely hazed but now 5x2 its a light haze and 5x3 lays down a good strong black cloud. Just really odd...
Yea. As of today I had to drop my sub-level again. Getting to smokey as summer time started coming on and noticing more and more smoke as I would be towing and/or launching with a heavy foot. I'm wondering if others have notices anything like this with warmer weather? No ill-effect to MPG's at all but the smoke level is slightly higher now than was during the winter time. I'm also wondering is the injectors changing for like a break in process and flowing more?
New Injectors
Hey at least 12V you can change like spark plugs on a in-line 6 cylinder. 24V is bit more messy and trouble.
Poor ac cooling as ambient temperature increases
Hua? It's replaceable. The whole tube has to be replaced. I'm also 2002 Dodge truck and the tube from RockAuto or Autozone is cheap like $30 bucks. Just release both ends and replace.
Truck Pic: My Tow Team
Matter of fact I got off the phone late last night and have to head to Grangeville, ID and drive it home today. Then the Fire Chief and crew have to start out fitting this truck for fire service. Lots to do. But I do love that Big 400 Cummins lots of power and pulls mountain roads like nothing. Crap... You know... We kind of killed the thread and topic. But good ol' BS'ing of diesel trucks though...
found out what happened to 5th gear
I think you exceeded the transmission ability to hold the torque. I know you oversized tires don't help either...
LOL... Well I don't own it but I get to drive it. It's even a Cummins...
Orifice tube are super easy to replace. I know I know with your limited function you not capable dang I really do wish sometimes I was closer to help you out.
Mine always starts out a bit warm sided but after few miles and giving it time on low setting it cools down good (40-45*F) from the center vents and then I crank up the fan speed and push the cold into the cab. With high humidity you'll want to run more MAX A/C than normal.
Anyone Been Here?
No worse than Pollock, ID http://en.wikipedia.org/wiki/Pollock not the... http://en.wikipedia.org/wiki/Polack Then fun ones... Grangeville, Id is Strangeville Horseshoe Bend, Id is Horse $h!t Curve Lapwai, Id is Crap way Few other local slang names for towns...
200000 miles
Yeah because you gotta drive so far to fine warm weather so you can go camping or boating.
Failed to Start
It's a age thing really common to see from older fuses. They tend to crack and open up from loads and then cool and make contact again like my cases it did that exactly. Because it ran for about few minutes before fuse opened up again and tripped the check gage light.
Anyone Been Here?
Ummm... I'm glad that's not in my neighborhood.
New Injectors
Hey MnTom is there a 6 or 7 hole injector for the 12V??? It would do YabbaDoo better I would think with a nice wide spray pattern.
I am going to Ohio
Don't feel bad... I'm going to be heading out and seeing Hex0rz soon. I'm just going to the truck to Hex0rz place to save on the fuel budget.
Baby got new shoes....
Aaaahhh... Aligned? 4WD can only have the toe set. Don't have any tire wear problems so... I must be really really close.
Raptor 100 changed pressure again
I would pull the regulator and inspect it for damage or sticking of the springs.
Hard Starting after Fuel pump Replacement
I know this site doesn't help the availability of part trucks or even used trucks for sale. I would just leave your name alone...
power steering help
Also it could be the power steering fluid is breaking down and/or the fluid is getting loaded with debris and plugging up small orifices in the power steering gear box. I would attempt doing a fluid flush and see if it clears up.
Billet flex plate and input shaft?
Funny how the automatic transmissions have to do so much beefing up for input shafts where manuals really don't require it and do quite well without upgraded input shafts.
200000 miles
Just past 230k... Just another 8k to get to the moon. http://en.wikipedia.org/wiki/Lunar_distance_%28astronomy%29
Failed to Start
Hey Gang... while I was out on my trip to Hot Springs campground with MoparMom the first night we stayed in Emmett, ID. The next morning got up and pick up our stuff in the RV and to go and leave. Jumped in the seat and got half a crank and dead. Popped the hood. Everything appears fine. MoparMom getting worried we are stuck in Emmett, ID. Like I told her don't even sweat it I've diagnosed this a million times. So... 1. Swap starter solenoid relay with trailer relay (Nothing) 2. Swap the Starter solenoid fuse with Engine Control fuse (Start) So I hopped back in the truck and start out and (Ding Ding Ding) and volts fell to zero, and few other gauges died. Hmmm... The fuse I swapped with was most likely the PCM and fuse must be cracked being the cluster worked for a few minutes and died. So since I'm still in Emmett, ID I went over to NAPA walked in with my fuse and bought a new 30A fuse and plugged it in. No biggy. I figure I would share this tidbit with you all so a simple failure doesn't just make you jump for a tow truck but to do some diagnostics first and figure out if you really need that tow truck.
I didn't know to explain it. first off my truck has never seen a alignment ever. But when I would change parts like track bar and ball joints it moved a bit off center so I do just as W&F said twist the drag link a bit (1/4 turns) and test again. Straight as arrow now.
New Injectors
As far as I know 12V is a 5 hole injector stock. Then 24V is a 7 hole stock.
Returned Home: Camping at Hot Springs
Actually we got to lazy too even hike over there and crawl down the trail. We did go over and look at it but with the weather in the low 90's it was just to hot to go sit in hot water.
