Baby got new shoes....
Sounds right. I know most one ton's came with either 235/85 R16 or 215/85 R16.
Returned Home: Camping at Hot Springs
None missing here...
New CO emission reduction plans
Other way around out here. Before the forest was kept health but selective harvesting and thinning of the forest. Now it too expensive for logging companies to meet the requirements of USFS or BLM so logging has come to nearly a stand still in Idaho nothing like it was 20 years ago. Now USFS has this idea fire is a natural clean up solution. Really???
I think it more of stability than load bearing. Keep the center part of the ceiling from wiggling too much during transit. I wouldn't want to test that roof with any kind of human weight. I would consider adding them back in if they are truly missing.
Hey Gang.... MoparMom and I just got home last night. We ran away from home with the RV. Went down south to Emmett, ID for the first night. Pick up a few things and a new BBQ grill for the RV. Then head back up Hwy 55 and turned off at Banks, ID and went to Hot Springs campground. http://goo.gl/maps/9nFRG Nice campground. Has water and vault toilets. Pull through spots for larger RV's or back in spots as well. There is a small hot spring on the other side of the highway but it a good hike down to it. Solar Power Update As for a good test run for the solar panels and inverter they worked awesome. I flipped on the TV in the hot part of the afternoon and started watching older DVD movies I brought along since there is no TV signal down there. Solar panels kept the batteries charged up to 12.8 volts to 13.2 volts most of the time while watching movies. Even charged up cellphone, cameras, and a laptop. I did figure out that my outlets of the RV are on there own circuit so I could do a bit of wire magic with a SPDT switch and make a transfer switch to power the RV outlet with the inverter and isolate the city power if forgotten which protect the inverter from city power back feed. Water Update We did extremely well with even water. But were getting close to running out of water. MoparMom suggest I go back into Crouch, ID and hit the hardware store and figure out a solution. I did! I've got a anti-freeze connection in the pump cabinet so I got me 3 feet of 1/2" ID vinyl tubing and a brass barbed connector to splice the two piece together. So now I've got a tube long enough to dip into my 5 gallon water jugs I keep as spares in the RV.
Fuel Efficiency of the 04.5-07....
It seems that even CR engines are affected by the warmer air.
Seatbelt light
I just take a small piece of wire an bridge the connector there there is no cut wires.
Hard Starting after Fuel pump Replacement
Fighting a up hill battle... I've got the same problem locally here. Everyone does the same thing and ask for the problem to be fixed but I suggest a better lift pump and a fuel pressure gauge and you get "Hua!?!?"... Truck ran this long without all that. Yeah you might get lucky now but wait till your luck runs out and eating VP44 for lunch on a monthly basis. Then most owner just sell the truck. But yes I would suggest again the fuel pressure gauge.
Raptor 100 changed pressure again
Still seems to come back to the regulator of the pump is screwing up. Something about the old school method of check ball and spring worked so much better compared to the current method of adjustable regulator.
When dealing with spacers make sure to double check you have enough stud to do the job properly. If not I would re-stud the rear axles with proper length for the spacers.
Time to go play!
Yeah I do when I'm the one eating chopped liver....
Truck Pic: My Tow Team
Might be a long time... I'm still waiting to get to 500k on my current truck so after I wore mine out I'll buy another. Then sell the 96 and retire the 02 to dirty jobs like firewood work. Then buy something else maybe a 4th gen...or 5th Gen depends whats happening by another 10-12 years.
I hate to say it Cody (GreenRiverCummins) your heard is bigger then mine. I've only got the two trucks now. I did at one time have to Dodge Car's and to other Dodge trucks too. But with economy and reliability I needed to drop the older stuff and move on with newer.
I was out getting the lawn mowed and wanted to mow around the trailers so while I had in the yard I shot a pic of my Tow Team.
Yea... But you missed one. Gov't supported by volunteers and work for free. Not the currently over paid bunch of dumb 's...
Fire Call: Vehicle Accident
More here... http://idahostatepolice.blogspot.com/2014/06/fatal-crash-on-us-95-near-pollock.html
Really common with isolators. As for the change it common to see adjust able Raptors and AirDogs do this where the over complicated valve starts sticking and hanging up so the pressure gets lower and lower. So now you adjust it the pressure is higher and all of sudden it will pop loose and be too high. So I suggest you pull the valve and inspect it for damage.
Toyota Camry vs. Logging truck (Unloaded). The Toyota Camry had 3 young adults college age which appeared to be heading back toward Montana. I'm not certain what happen but the Toyota drift over the double yellow line and met the logging truck head on. This wiped out the front axle of the logging truck and he drifted down the guard rail to the turn off at Rainbow Bend road. The Toyota was bounced off the logging truck and thrown back to the East side of the highway. All I can say is everyone in the Toyota took on serious injuries. Please people, slow down. Pay attention to what your doing while your driving your vehicle.
failing throw out bearing
This was during my install of my Southbend clutch and the throw-out bearing gotten jammed up on the end of the shaft and hooked. So no matter how much I started to push the pedal it built pressure till BOOM! It exploded and blew the whole side wall off the master cylinder out. So I had to replace the master cylinder and then pull the transmission back get the throw-out bearing un-bound and sliding on the sleeve. Never had another issues after that.
How about the USFS out here in Idaho lighting controlled burns because its too expensive for logging companies to meet environmentalist requirements to log now. So USFS idea is to burn our forest instead of logging and cleaning up. You should see the massive scars of forest that are nothing but burnt tree poles. But there contrl burn files the canyons full of smake and CO2 emissions.
I don't care if the fuel you buy is gasoline or diesel or any other liquid hydrocarbon. It all based on the chains of carbon and hydrogen the shorter the chains the lower the BTU's. Hence why gasoline is lower BTU's than diesel because diesel is a longer chain. Still in all the carbon is converted to carbon-dioxide, carbon monoxide, etc. Hydrogen burns and joins with oxygen again during the burning and creates water typically.
3Rd Gen Or 4Th Gen Steering Upgrade For 2Nd Gen?
No pavement queen here used offroad quite a bit. I won't jump for any "3rd Gen Upgrade or modified track bars". Most all ball joint and track bar issues are typically caused from over sized tires and lift or leveling kits. I cleared 185k miles on stock track bar and ball joints. Now on my second set and just inspect the front end a week ago and its still tight no issues. The reason why I say this I've seen so many cut or modify the ball end of the track bar. Then what happens is you now stuck hunting for those particular parts. I've seen a few local truck go absolutely to junk because they upgraded to a aftermarket trackbar kit to "fix the 2nd gen issues" and then no longer can get the modified parts now.
Just remember one thing... "Nothing can be create or destroyed." So if I was to measure all the carbon in the world today it will be the same amount of carbon hundred years from now.
Time to go play!
Oh. I seen it. In other words she's "My Mom"...
Quadzilla removal
I just sent Ed a email hopefully he can help out...
