VP failure?
I personally don't suggest Power Service products. Causes more issues than it fixes.
Time to go play!
What? I'm chopped liver? Don't I get lunch or dinner too?
Trying to decide on what tires to buy...
I rarely get much more than 30-35k from a set of tires from all the dirt roads I travel. Wear gets worse as I climb mountain dirt roads with trailers in tow. If only Idaho would pave all there forestry roads I would be getting well pass 50k a tire then. Hence why I don't get wrapped up with name brands. I would rather buy the absolute cheapest tire and lightest tire I possible can. Because even the most expensive Cooper STT I bought at $1,400 years ago managed the same distance and degraded my MPG number (which cost me more when you look at operational cost). So Just looking at the Cooper STT's I could of bought two sets of HiFly's and covered 60-70k miles for $100 less. Also just found out my local Big O Tires is no longer. They switched names to Tire Factory of Ontario, Oregon and still going to provide me the same deals as I always had for the last 24 years.
failing throw out bearing
If the bearing was binding up from sliding on the tube the master cylinder would most likely explode. Don't ask how I know this one. As for riding the pedal I don't think it will change much of the life span of the bearing but it would indeed change the life span of the clutch (slippage). The fact the bearing is constantly turning loaded or not as soon as the grease disappears the bearing will fail pressed or not. Thinking a bit more about this grease disappearing... The only thing I could figure that would do that is excessive heat in the clutch housing making the grease sweat out of the bearing? (educated guess...)
P1690 thrown
It would be best to isolate the lift pump using a relay like the old school AirDog/FASS do. Just use the ECM for trigger of the relay and then get the power from the BATT lead (red one not the black one) in the PDC.
Not really. Because with your foot on or off the pedal the bearing will continue to turn. It comes down to how much grease was added to the bearing when its sold. You'd be surprised how much force just the slave cylinder pushes again the bearing.
Time to go play!
Even MoparMom and Diesel went out on Smokey Boulder Road and played yesterday.
Like myself I'm usually buying some sort of off brand like this batch is HiFly (China made) for about $650 bucks. So far really good A/T tire works well in all conditions including snow and mud. Taking the occasional spinning free in 2nd and 3rd gears with slightly heavy throttle.
RV Storage Spot
Not that particular tree.
ABS Sensor
Glad you found you final problem and now the lights are off.
what are your egts at idle?
Just about the same here too.
ABS Sensor
Bad connection somewhere. The Anti-Lock Controller unit is detecting a loss of signal or variance of signal.
Edge EZ has to play by the rules of the ECM. Edge Comp can play outside the rules of the ECM because of the wire tap.
VP44 might be bad
It any case the ECM has to be reflashed for your vehicle. Even buying a used one to make sure the correct software is installed.
P1690 thrown
DTC P1690: FUEL INJECTION PUMP CKP SENSOR DOES NOT AGREE WITH ECM CKP SENSOR Monitor & Set Conditions Fuel Injection Pump Crankshaft Position (CKP) circuit is monitored when ignition is on and engine is running. DTC may be stored when no signal exists within specified window parameters with no Camshaft Position (CMP) sensor or CKP DTCs present. Possible Causes AC Noise Across Fuel Transfer Pump Other DTCs Present Wiring & Connectors Fuel Injection Pump Static Timing Fuel Sync Signal Circuit Open Fuel Sync Signal Circuit Short To Ground ECM Testing 1. Measure AC noise to ECM by connecting DVOM between ground and terminals No. 48 and 50 (Red/White wires) at ECM harness connector. If AC voltage is 25 mV rms or less, go to next step. If AC voltage is greater than 25 mV rms, replace fuel transfer pump. See appropriate REMOVAL, OVERHAUL & INSTALLATION article. 2. Turn ignition on with engine off. Using DRBIII® scan tool, check for DTCs. If no additional DTCs exist, go to next step. If any additional DTCs exist, repair other DTCs first. See DIAGNOSTIC TROUBLE CODE DEFINITIONS . 3. Using scan tool, check Good Trip Counter for DTC P1690. If Good Trip Counter for DTC P1690 is displayed and equal to zero, go to next step. If Good Trip Counter for DTC P1690 is displayed and not equal to zero, go to step 5 . 4. Turn ignition off. Disconnect FPCM harness connector. FPCM harness connector is located on end of fuel injection pump. Check for poor connection/terminal contact at FPCM harness connector. Repair as necessary. Disconnect ECM harness connector. ECM is located on driver's side of engine, just in front of fuel transfer pump and contains a 50-pin connector. Check for poor connection/terminal contact at ECM harness connector. Repair as necessary. Using DVOM, measure resistance of Dark Green wire between terminal No. 8 on FPCM harness connector and terminal No. 18 on ECM harness connector. If resistance is less than 5 ohms, go to step 7 . If resistance is 5 ohms or greater, repair open in Dark Green wire between FPCM and ECM. 5. Turn ignition off. At this time, conditions required for DTC to be stored are not present. Inspect wiring and connectors between FPCM and ECM. FPCM is located on top of fuel injection pump. ECM is located on driver's side of engine, just in front of fuel transfer pump and contains a 50-pin connector. If no problems exist, go to next step. If any problems exist, repair wiring or connectors as necessary. 6. Check fuel injection pump timing. See CHECKING FUEL INJECTION PUMP TIMING under FUEL INJECTION PUMP TIMING in ON-VEHICLE ADJUSTMENTS - RAM PICKUP - DIESEL article. If fuel injection pump timing is okay, go to next step. If fuel injection pump timing requires adjustment, adjust fuel injection pump timing as necessary. 7. Ensure ignition is off. Disconnect FPCM harness connector. FPCM harness connector is located on end of fuel injection pump. Disconnect ECM harness connector. ECM is located on driver's side of engine, just in front of fuel transfer pump and contains a 50-pin connector. Using DVOM, measure resistance between ground and terminal No. 8 (Dark Green wire) on FPCM harness connector. If resistance is 5 ohms or greater, replace and program ECM. See appropriate REMOVAL, OVERHAUL & INSTALLATION article. If resistance is less than 5 ohms, repair short to ground in Dark Green wire between FPCM and ECM.
It could be the pyrometer amplifier in the Edge CTS going south. One of the few reason I bought separate gauges.
Quadzilla removal
Attempt to catch up with Ed Grafton (Yankneck) he'd most likely know where to find such a thing.
P1690 thrown
Upload it to YouTube and copy the URL and post it here. The site will automatically parse the URL into a video box. Here is the code.. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/obdii-error-codes_94/p1690-vp44-ckp-sensor-does-not-agree-with-ecm-ckp-sensor-r136/?do=getLastComment&d=4&id=136
vp44 or other issue?
Valve lash? (intake 0.010" and exhaust 0.020") Injectors pop tested? Using cetane booster or a fuel additive?
Anybody install a CNG (Compressed Natural Gas) kit on their Cummins?
Well I found this... http://www.cngnow.com/vehicles/refueling/Pages/refueling-at-home.aspx I have no idea how much it cost for the unit but it seem to be gaining some momentum.
4th gear hunt back again
Alternator typically is the the cause of all torque converter lockup issues. I was shock with Pepsi about the brushes being wore out but totally forgot about them being a cause of AC noise. I've now heard of 2 cases of alternator brushes being a cause and rest of them tend to be diode issues.
VP44 idle speeds are controlled by the ECT sensor. So the warmer the coolant temperature the lower the idle speed. Sorry, but just lower idle speeds don't mean there is a problem with the VP44.
Replacing pinion seal on a Dana 80.
Here is a article on how to do it. http://forum.mopar1973man.com/index.php?/topic/1598-diy-pinion-seal-replacement-dana-80/
Truck curb weight!
Man... I would do anything for weights in the 6,800 to 6,900 pound range.
What Happen ?
From what he told me it was tap water. Both trucks where done with tap water one with problems and the other without a issue?
