Crankcase Vent on 1998.5 Cummins
As far as I knew they all came with at least a hose some with a slobber bottle. If it comes out the tappet cover and the gear case is a rubber plug you have the modified version. http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/29-tsb-technical-service-bulletins/44-tsb-09-002-02-oil-overflow-from-the-front-crankcase-breather
Toy Hauler problems befre big trip...
Here is a replacement option... http://www.rvgauge.com/
Any Benefit to using deep cycle RV Batteries on the truck?
The only bonus is deep cycle batteries have a slightly deeper sump for lead sulphation to pile up in the bottom. But if you properly maintaining your batteries you'll clear 10 years on the cheap no-name batteries.
Oil Consumption...
Thing is I don't see (personally) any reason for synthetic oils in these trucks. When there is members like CajFlynn putting over million miles on a truck on dino oil. Then flip the page and watch Dorkweed run 84k miles on a single oil change with WalMart oil. (Blackstone tested every 7k miles). So with these two members you can learn a lot...
P0336 code
Just do the diagnostic the best you can. But when a error code is thorwn 9 times out of 10 the code it throw for its device. http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/59-obdii-error-codes/175-p0336-crankshaft-position-sensor-signal
High Water Temps w/ High EGT
Hard start after sitting
ECM uses a modulated signal that is a 50% duty cycle. So the ECM during cranking is going OFF - ON - OFF -ON in a rapid pulse. Cranking pressure should be 7-12 PSI optimally. So you need a mechanical gauge to see the pulse because most electric gauges or digital gauges filter the pulse so you don't see it or don't function during cranking.
stock boost question
Not true. I've ran a Edge Comp now since 2006 on 5x5 till I upgraded to RV275 injectors and toned down to 5x3. Basically the box is wide open 120 HP with defuel mode of 67% of stock fuel till 10 PSI of boost. But I drive daily on this setting even towing. Empty I'm getting 22-25 MPG easy. Loaded with a trailer 7,000 to 8,500 pounds still manage 11-14 MPG. You should this will give you better power and fuel management than you don't have now. As long as you have gauges and a good fuel system right off then a enhancement box like Edge is just fine and these trucks handle the enhanceent just fine. But like I said you get better fuel and timing management over the stock ECM program which is built around the EPA rules.
I got a fancy made fan wrench for the Dodge Cummins from JL Welding. One to hold the pulley and the other to twist the fan nut.
Even after doing the http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/26-engine-systems/42-crankcase-vent-mod I still have to pull my radiator every few year too flush the face of the radiator out of caked in dirt and mud. Mine is not a strict pavement queen it spends quite a bit of time offroad.
ISX got it. You going to need a Edge Comp or something to do boost fooling. Other than that the whole idea of changing the wastegate goes out the window. What happens is as the engine sees above 20 PSI its to defuel and shut down by 25 PSI it will/should throw a P0234 code for overboost code. So if you wanting any more boost your going to need a fueling box like a Edge Comp or similar for boost fooling. As for controlling EGT's is easy drop 1 gear and kick the RPM's up and the EGT's always fall.
MnTom is Broke Down near Standish Michigan. Is anyone near?
Too much propane...
Wheels won't turn when sitting still
Try kicking the RPM's up to see if it is a pressure issue while turning. Me personally, I wouldn't bother with the name brand hype I would just replace with a factory power steering pump and gear box. 232k miles and ticking on the clock and still not even a leak on my factory pump or box yet. All the rough road miles and forestry roads.
Doing a site search turned up this... http://forum.mopar1973man.com/index.php?/user/1502-sngsht/ I sure wish people would list there city and state more...
Load distributing hitch bars?
If I'm not mistaken it based off the actual hitch weight at the tongue. So typically a 7,000 pound trailer would have 10-12% in tongue weight so 700-840 pounds on the tongue. http://auto.howstuffworks.com/auto-parts/towing/equipment/hitches/towing-weight-distribution-systems.htm
Installing Fifth Wheel Hitch
Done. As requested.
Low power and milage from day 1
Here what I can tell you. 3200 Governor spring BHAF Straight pipe 4" Custom cut fuel pin HX35W turbo Is worth about 224/571... http://forum.mopar1973man.com/index.php?/topic/4622-relentless70-dyno-run/
Ram 1500 gasser overheating
Fan clutch is possible. How about the face of the radiator is it packed with mud, bugs, etc. You'll have to remove the radiator to clean it good from both sides. How about the core tube are they all plugged up with corrosion blooms from old corrosive coolant? Water pump rare to fail but typically you would see the pump weeping water. As for the pump vane being gone or broke would be cause from corrosive coolant eating them. So when was the last coolant system flush and fill last done?
Mike, intercooler boot...
Yea... I did call. Yea its a 11mm socket. I would of just spray it with hair spray and put it back on. Torque it correctly there is a actual in/lbs number for the clamps.
do you trust your michanic?
I'm sorry but I lost my faith in dealers and shops long ago. The only shop my truck with see is a tire shop and alignment rack. Beyond that I do my own work on the truck. But that was totally just a botched job there and someone really didn't care. Glad you found the problem and took care of it properly.
2003 Subaru Impresa 2.5L - P0420
Update: I notice the postal lady can by this evening in her other car. Now I stop by this evening and check the error codes the P0420 is gone. But now replaced by a P0130 code... But both oxygen sensors have been replaced already. http://www.obd-codes.com/p0130
Well that little car came by today and delivered the mail and kept heading north. I'll find out more later on today.
Smoking Trucks / Coal Rollers?
Hold up... Time to chill out... (Closed.)
No. Not really. All the PSG is encased in plastic and the actual heat sink is downward into the fuel not upwards to the air. So adding a heat sink and blower won't do much because if the fuel is 140*F its got direct contact with the aluminum plate that is in contact with the electronics. Food for thought. I'm up here in Idaho seeing temps above 110*F in the summer and well in the minus numbers in the winter. My VP44 has no cooler on it and been running just fine since 2004 when it was replaced at 50k miles. Currently has 232k on the clock.
