Hey from Reno, NV
Let me know i'll be happy to meet up with you some time in Caldwell...
New Injectors have increased the MPG's
Another site I have my hand in is the SmartyResource.Com site you might want to stop over and take to Brian or Dylan they should be able to help you out.
Frantz Filter Systems
I'll call here in the morning to see what's up...
FASS DDRP Dely wiring help....
All right here... http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/25-fuel-system/49-fuel-pressure-specification-for-bosch-vp44-injection-pumps
Code 1689
Another set of questions...Q: Do you have a fuel pressure gauge?Q: What's your fuel pressure like from Idle to WOT at highway speed?Q: What fuel system are you running?
Geez... I know I talked to Deborah... Well hang in there and I'll try again to get ahold of her and see what she'll do for pricing.
False boost reading on ScanGauge
Remove the Quadzilla XZT from the truck and rehook the MAP sensor back to the ECM stock lead. If the value is still off then it might be a bad MAP sensor. If removing the XZT from the truck fixes it then the boost fooler is bad in the XZT. Disconnecting the batteries does only one thing. It wipes out the APPS sensor calibration. As for resetting error codes or software it will not do that. To reset the software you only need to turn the key off and back on because the ECM goes through a full reboot process.
Tires: Treadwright
I'm also looking for another set of rubber for the beast. My tire dealer has a new line of tires which where cheap is price. $626 for set of four 235/85 R16. http://www.bigotires.com/Tire-Detail/HIFLY/VIGOROUS-AT-601/23452
2002 Edge Comp Wiring Help
Man I hate when people do that. It would be best to contact Edge Products and just get a new wiring harness and not use that hacked up wiring. I'll take a look at mine and let you know how its hooked up but I will warn that pin assignment on the MAP sensor is different from 01 to 02. I'm working with stock 02 wiring but using a Cummins 01 MAP sensor adapter.
Stock lift pump psi Qs
Holley pumps tend to fail in the motor brushes or the shaft seal. Back in the day Holley blue and blacks were very common. But failure was also very common too. Vulcan Performance Big Line Kit is what will do that exactly as for moving the pump towards the fuel tank. Includes all the electrical for the pump, plumbing and even the mounting bracket. But all this never cured the lift pump life span issues. Most the pump couldn't hold up to the additional strain during the cold winter months as the fuel thicken up to nearly jello state. AirDog and FASS where the first two pump to come forward that held up to weather conditions.
Back to stock injectors for a short time
Personally I think they would be too hot to use at least for me. Just running around loaded with firewood and getting a heavy foot I can tip the 1,200*F in exhaust temperatures. This why I'm looking at the RV as the next test. Load it up!
Just gave Deborah a call and her know there are people interested in Frantz filters...
Someone needs to straighten these people out
I'm all for any 2 cycle oil in diesel fuel. It's better than dirty waste engine oil or ATF which both have side effect with ash content, debris content, chemical that work against combustion process. Being that today's fuel is 520 HFRR and Bosch requires fuels to score lower than 450 HFRR.
I wouldn't say that. It just my Rv275's were already well used when I got them so its not exactly a fair challenge. But still in all both gave good power and performance. Just the new +50's are more efficient than the wore 275's. The other reason I went up was assuming that a custom injector would net slightly better gain than a factory Bosch injector. I think I'm right on that... Time will tell.
Yes. You got to roll off enough paper to fit within the can of the Frantz Filter. So typically what I do is use it to drips or spills of used oil on the floor with the paper I roll off.
Refer to: http://forum.mopar1973man.com/threads/7821-Screaming-Beavers I know my ScanGauge isn't exactly right on the money but even with the 2 trips of firewood hauling I did I still pulled a nice 16.5 MPG. What is quite amazing is my pyrometer temperatures are roughly 50-100*F cooler than the RV275's and even my boost pressure is lower. Even with all the weight from the wood it was like 600*F worth of pyro and 5 PSI of boost at 55 MPH. I really do want to hitch up the RV next...
Hey from Reno, NV
Welcome neighbor. Just north of you in the great state of Idaho. So you might end up coming this way sometime working in the forest. But once again welcome to the family.
You could back down to 200:1 and be good! Personally I run WalMart Supertech 2 Cycle Oil and have been for 128K miles. I add in 1 ounce to 1 gallon every fill up. My VP44 injection pump has over 163K miles and no sign of wearing out.
Roadtrip Adventure spare parts list!
Bingo! Wild and Free & ISX hit the nail right on the head. As you notice there is no extra parts in my photos. I do carry some basic tools typically but nothing else. I typically go through a full one month inspection on my truck and deal with everything. Check fluids, axles, brakes, transmission, etc. I treat my truck as if its a airplane. Because with a airplane if there is a failure you going to crash. Well in my case like Wild and Free I get the sub-zero temps and where I live it might be deadly trying to walk to get help for a vehicle failure. No cell service so AAA is meaningless. To this day my truck had NEVER seen a tow truck and never left me stranded on the highway I've always gotten home. Like for example. http://forum.mopar1973man.com/threads/7736-Replaced-Straight-Pipe On my inspection I took note of my pipe starting to get small pin holes so I knew that it was low priority but I needed a new piece of exhaust pipe for the truck. So I just planned next time I headed to town pick up the pipe and Get R' Done. You bee so amazed how reliable your beast can be if you do once a month inspections.
I'm also running a Frantz Filter on my truck. Amazing gal here in Nampa, ID that builds them. Deborah Walker is the owner of Frantz Filters. Very good filter system I change mine out every 5K miles and change oil every 10k miles. Contact Info. Deborah Walker - Frantz Filters 208-467-3726 dwalkerharley@wefilterit.com http://www.wefilterit.com/
Screaming Beavers
Very good you noticed it. The first load I was having trouble walking over the 3 snow drifts to get the wood with my bald street tires so when I came home with the first load I ate lunch and swapped those on and head back out. Stihl 046 Magnum (20 years old) and a Stihl 461 (brand new). Not sure on the weight but even last night the truck was sitting level will a full load. If I was a gambling man I would have to say about 2,200 pounds or slightly more. I was enjoying breaking in the the new saw on some light duty cutting. The first load was only one tree. Second load was 2 slightly smaller trees. All of it is Alpine fir I'm right at about 5,500 feet cutting at the snow line. In a bit I get a picture of the pile in the yard of how much wood I got with only 2 loads.
Here is what I carry...
Screaming Beavers
This is going to be a quick post for my first wood haul of the season I'll post more later on I'm tired. :sleep:First load.Second load...
driving on the water
The weather here turn hot! I mean hot as 90-95*F and the snow melt is kicking up the river in a quick hurry here. Nothing dangerous yet but quickly rising in flow. Like last night I slept out in the RV being I had a friend over and the river is getting louder through the evening as the water is rising. Yeah out here the river rises at night and falls during the day. It takes 12 hours for the melt flow to get to me. As for the company I getting ampped up to start hauling firewood this morning. (Screamin' Beavers!)
After the Heater Core & Evaporator Install
Well at least you don't have to pull the HVAC to fix that...
